Question about Samsung HL-S5687W 56" HDTV
Samsung DLP My TV is 2years old.The tv occasionally shuts itself off. So far I can turn it back on. I thankyou for any imput. Fred
  • Hitco Mar 14, 2008
    thank s pkaiser74. I pulled the back cover off and there must have been just enough dust on the blades of the cooling fan for it not to work properly. thanks again, hitco
  • r8rh8r21 May 03, 2009
    My tv kept on shutting itself off. I found some feedback online that suggested that I check the lamp cover in the back. If it was loose, tighten it. It was loose and to my suprise, after I tightened it, the tv quit shutting off. But about 4 or 5 months later, it started doing it again. This time around, it shuts off when I first turn it on. I turn it back on and it will shut off again. After going through this routine about 8 - 10 times, the tv decides to work just fine. But if I shut it off for about a half hour or so and turn it on, I find myself starting all over again. 2 weeks of this and now it is getting worse. Turn the tv on now and it will shut off right away. Getting real low on patience. Please help!
  • 92 Answers
Try this and see if it makes a difference
open the lamp door look for the blue switch(bottom left i think)
take the loose wire(blue and white) wrap it over the switch to hold it back
and while your back there make sure you dont have a lot of dust blocking the vent on the back cover
Posted on Mar 12, 2008
Samsung tv turns off on its own model hls4266wx
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Mar 12, 2010 | Samsung HLS4266 TV
    I have had this Samsung DLP HL-P 4663W for about 3 years now.
  • Sep 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
    Imput problems with Samsung DLP TV
    The parts required for this are available but difficult to find. The overall repair is not that difficult for anyone that has fixed these before. You'll spend more time getting to the jack than replacing it. Try calling Samsung parts and give them the model as well as the circuit designation of the jack. This designation will be written on the PC board. For less than $5 you should be able to get the jack. Ask a local service shop to install for you and you are off and running.
    Dan
    Aug 12, 2009 | Samsung DLP HL-P5663W 56" TV
    42 inch Samsung DLP TV shuts off by itself. I can turn it back on and sometimes it stays on and other times shuts off within seconds. Some days it stays on all day without a problem. Other days it shuts...
    I bypassed the safety switch (it was bad) and vacuumed and blew out all of the dust. So far with this set, 3 years old, I have replaced the bulb twice,it exploded both times, and the color wheel which also exploded! We love the picture but the next time it goes out, it goes out to the trash and I will purchase a top of the line LED/LCD set. No moving parts!!! Samsung designed and manufactured a whole bunch of lemon sets and will not admit it. I have found several hundred complaints about their DLP sets and only a few on other brands.
    Jul 31, 2009 | Samsung DLP HL-P5663W 56" TV
    Zenith 52'' dlp tv won't turn on
    after an hour tv shuts off and you have to wait to turn it back on
    Jun 12, 2009 | Zenith Televison & Video
    My 56 inch hi-def projection samsung tv turns off automatically
  • Mar 06, 2009 | Samsung DLP HL-P5663W 56" TV
    Samsung DLP4663W
  • Oct 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
    could be the lamp, and is about time for a new one
    http://fixyourdlp.com/blog/?cat=4
    Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
    Samsung dlp hdtv turns itself off
    Have a 46 inch behaving the same way. I have the extended service contract, so they are getting a calll tomorrow. I ll post what they say
    Dec 27, 2007 | Samsung DLP HL-P5663W 56" TV
    Samsung HL-S5687W 56" HDTV Logo
    608 people viewed this question
    Henry  Thomas
    Henry Thomas
