Question about Danby DCD5505W Electric Dryer
New danby, never used
Hooked up power, turns on, but will not start, in any selection, timed, or other, beeps one long beep.
  • 110 Answers
I WORKED ON A CUSTOMER WHO DONE THAT AND FOUND OUT IT HAD AN OVERHEAT PROTECTION SWITCH THAT NEEDED TO BE PRESSED DEPENDING ON YOUR MODEL NUMBER.
Posted on Apr 02, 2008
SOURCE:
Danby portable air conditioner will not turn on. Just beeps and the display will not power on. Emptied the water, no effect.
I have had the same problem with mine. Try to tape the small water container drawer shut. Restart the unit and see if the beeping is beepless.
Jul 26, 2011 | Danby DPAC120068 Air Conditioner
Gives beeping noise at regular intervals
On my Danby this was a reminder that you had nuked something and had left it in there. If it stops when you open the door then this is all it is. It should beep about once every 15 or 30 seconds.
Other than that I don't know of any other regular timed beep that my Danby made.
Jan 23, 2011 | Danby DMW1153 Microwave Oven
I have a Danby DDW1899WP portable dishwasher. I just got it yesterday. I had a lot of dirty dishes so I did 1 cycle first and it worked perfectly, I was impressed. I then started a 2nd cycle for the rest...
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
Nov 14, 2010 | Danby DDW1899WP Portable Dishwasher
Randomly beeps for no reason at all. Can go 2 or 3 days then will start beeping. Day or night usually through the night.
hey i have the same problem. how log does it do it, how many beeps and how quicky. We have a danby also the 1.1 bought it about 3 years ago.
Aug 04, 2010 | Danby DMW753 Microwave Oven
My microwave beeps for no reason even when not in
There is a reason. Try to reprogram the unit. Start w/menu: date, time simple stuff. This should take care of it.
Nov 05, 2009 | Microwave Ovens
Danby Window air conditioner -Deafening beep
the beep is not something you can turn down because it not a user feature it is an alarm if you want you can disconnect the wires to the diafram
Jun 05, 2009 | Heating & Cooling
I have a danby designer microwave oven modle # DMW753W SIN # 170705120067 the timer keeps beeping and won't keep time.When you try and use it it will not shut off. we got this as a gift for christmas...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for maybe an hour.
If you still have trouble, contact Danby Customer Service US / Canada.
Nov 05, 2008 | Danby Microwave Ovens
Oven control panel
Lok at your manual tp view all the possible control options. However, the solution could be; The touchpads, in conjunction with the dial, are used to select an oven mode,
set the oven temperature, set the time(s) and to set up your range. To use the
touchpad, press the center part of the pad with the flat part of your fingertip. A
beep will sound to indicate that the selection has been made. Turn the dial to the
desired setting and press START.
Pull the plug or flip the circuit breaker, wait five seconds and plug in the range or flip the circuit breaker to on. Always set the clock after installation or after a power failure. Once power returns to the oven, the clock defaults to 12:00 am.
Clock time display can be turned off. The default display is on.
1. Access SELECT FUNCTIONS Menu.
2. Turn knob clockwise until CLOCK DISPLAY is displayed.
3. Press START.
4. Turn knob to select ON or OFF
5. Press START to accept new selection.
Reset the Factory Settings This feature is used to change all the “Select Functions” settings back to the original factory settings (or defaults).
2. Turn knob clockwise until RESET DEFAULTS is displayed.
3. Press START. Display reads SELECT FUNCTIONS.
Dec 03, 2007 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Danby DCD5505W Electric Dryer Logo
90 people viewed this question
Top Danby Dryers Experts
Marvin
Marvin
Ekse
Are you a Danby Dryer Expert? Answer questions, earn points and help others
