Boot error need help
My friend booted up his pc today and got this msg
intel r grantsdale pci g acceerated
build number and few other things,
it never done this before, what causing this or how can i fix it?
  • 3 more comments
  • casican Mar 12, 2008
    i think its a dell dimension 3100
    its has 80gb hd / 256 ram that came with it and 1gb ram that was self installed , its not new its atleast 2years old , its never had this problem before
    if you still need more info, just ask and il try get the papers that came with the pc
    help is much appreciated
    ~thx
    when i boot it up it brings up that black screen with intel r grantsdale msg and cant get passed it
    found the service tag and have it typed in, what am i looking for?
    http://support.dell.com/support/topics/g...
    where can i download the diagnostics cd, will the cd start from boot? " is this it?"http://support.dell.com/support/download...
    will it scan the pc and find the problem?
    this is all quite confussing to me :(
    ~thx
  • casican Mar 15, 2008
    ok il try to remove the ram asap and try that, cant right now, pc is at my mates house
    windows xp home was originaly on it, then when i sent it away to get the hd wiped they installed xp pro, "when i started the pc up after that it give me a choice to choose between pro or home but i couldn choose home option
    service tag on the back is 6n4w22j
    the memory was installed over year ago
  • ambrienza526 Feb 15, 2009
    i tried to install more memory. computer would not boot up. I have removed the new memory and only have the original in now, but it still will not boot up, but now it beeps. The monitor is not getting a signal. I made sure that the memory was tight. I can't figure out who to do now.
  • TERRI RODDEN
    TERRI RODDEN May 11, 2010
    is this a new build ? need more info .. motherboard? memory?
  • 148 Answers
The error refers to the cpu
Posted on Mar 12, 2008
  • TERRI RODDEN
    TERRI RODDEN Mar 12, 2008
    go to http://support.dell.com/support/index.as...
    enter the service tag from your computer and run a diagnostics on this system.
    does the system still boot ? If not you will need to d/l the diagnostics and run it from a cd.
  • TERRI RODDEN
    first things first ... remove the memory that was added and leave only the original 256 MB that came with the system. Will it boot?
    What is your service tag # ? Is this windows xp ? How long ago was the memory added? Has any other hardware been changed or added ? Will the system boot in safe mode ? (Hit the F8 key on start up and choose safe mode). If you are determined to do this yourself ... we may have to do a chat.
I have a dell dimenision 4700. when i power on, i get.intel(r) grantsdale -G PCI accelerated SVGA BIO build #3329 pc dev. system want boot up
"Hello, If that is all the computer does then the hard drive is bad or the software on the hard drive is messed up, you will have to repair or reload the software."
Oct 10, 2015 | Dell Dimension Computers & Internet
I have a Dell Optiplex GX 280. When I turn on my computer a black screen appears. What can I do?
check the hard disk to be powered and the plugs to be on ...and try again ...Go to bios settings by pressing del on start ..or the F key suggested on the screen on boot..In here locate the optimal factory defaults and engage them ..confirm and after that save the settings by pressing the F10 key and confim
This will make all devices to be set to the factory defaults..After that if it still does the same it means the windows installed on it ..is corrupted..or the hdd with the operation system is corrupted and the windows files can not be read so the boot can not continue...First try to insert a boot-able cd ..with the operation system on it ..and try to reinstall it ..Format drive C during the installation in ntfs quick mode..This will eliminate all bugs and strange things ..If the installation goes well ..it means the hdd is ok ..and will work ,, remember you will need all drivers for it and need to install them in order to function proper..so , the thing to be done is to get to the manufacturer support site and download them by model and operation system before beginning the operation ..cause once the installing being done ..you can not connect to the net without the LAN driver....
If the installing can not be done ..and during installation you are informed that the hdd is inexistent or ..corrupted...than you will have to change it ..
Cause it seam to stop the boot on the video card information it will be a good start to check the video card too ..specially if it isnt an on board one ..but a pci ..It may be damaged and this to be the reason for not booting right ..
Nov 10, 2011 | Dell OptiPlex GX280 PC Desktop
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
Error: Intel(r) Grantsdale-G PCI Accelerated SVGA BIOS Build Number: 3314 PC Dev 04/12/ 2004
-Uninstall the video driver under ADD and REMOVE programs
-Download the latest video driver from support.dell.com, use the service tag of the system andlook for the correct video driver and reinstall video driver
-Reboot system
Oct 06, 2008 | Dell Dimension 2400 PC Desktop
DELL Optiplex GX280 PC don't boot
This is what I did & it worked to solve this error message on my Dell Optiples GX-280. Intel(r) Grantsdale-G PCI Accelerated SVGA BIOS
Build Number: 3314 PC Dev 04/12/2004 17:02:24
DECOMPILATION OR DISASSEMBLY PROHIBITED
Copyright (C) 2000-2003 Intel Corp. All rights reserved. I uninstalled all the ram except for one chip. I rebooted the system to to see if the one chip worked (ready to repeat the process if it didn't & thinking maybe it could also have a bad ram slot). The 1st chip worked & it went right into bios(clapping hands!!!) I then turned off & on the system...each time adding a new ram chip to see if any were bad, but to my surprise...none were...they all worked just fine after that(clapping hands & shaking head!!!)! Just to let you know...I had 4 sticks of DDR-2 4200 in it when I did all this...I know I know...it takes DDR-3200, but it will just clock it down to 3200 & still works just fine...trust me. Computer works fine now with no error messages what so ever...hope that helps~; )
May 11, 2008 | Dell Optiplex GX280 (99301) Motherboard
Intel motherbord
Does it show any error msg?
Feb 26, 2008 | Watches
Foxconn Utility CD for motherboard Intel 915 series p/n: 91-185-915-MB-OM W A N T E D
Hi Witalorant,
I have searched the driver for your motherboard chipset and found one similar for the one you were looking at, i copy and paste the link here for you to download it and install it to your unit.
Click the link below and see what driver you need to download when the page loaded..
INTEL 915
Hope it helps.
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
Feb 10, 2008 | Foxconn 915P7AC-8KS Motherboard
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
