Question about Canon PowerShot SD1000 Digital Camera
Canon power shot sd1000 digital camera
I bought a camera last week, the guy said a laptop was ok to hook up to and download my pictures. I can't get the lead to hook up to my computer.
can someone help? The yellow and black leads do not fit into my Dell inspiron 1501. They seem to fall out as the entry wholes are too big.
mfranmendez@msn.com
210-402-0269
  • 477 Answers
Oh easy fix that is a av cable he provided you. their shoud be another cable with it called a data cable it hooks into a usb port. if you donot have the cable you can some times get them from a camera shop or maybe even walmart if you still cannot find one look on ebay they will have it their.
Posted on Mar 11, 2008
Canon power shot sd1000 won't connect to my computer anymore. The computer does not sense that there are pictures on the camera!
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Jan 02, 2013 | Canon PowerShot SD1000 Digital Camera
My cameras power seems to work but the screen is all pur black ?? what can i do to fix this???
I have canon power shot sd1000 camera. Every thing is o.k. except that recently the screen stays dark in picture mode and when on for taking pictures. pl let me know.
Feb 03, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
My pictures won't download on to mt computer
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
The card reader will most likely also still be compatible with any new camera you buy in future.
Kind Regards
Andrea
Jan 30, 2010 | Canon PowerShot SD1000 Digital Camera
Whenever I attempt to download pictures off my Canon Power Shot SD1000 onto my HP Pavilian dv6135nr laptop, the computer apparently is not picking up signal from the camera EVEN THOUGH after plugging in my...
does the laptop recognized you canon power shot? if not try installing the software of the canon power shot to your laptop, these camera comes with installation when you purchased it, try to install it, sometimes win xp does not recognized such devices
regards
michae
Nov 19, 2009 | Computers & Internet
My Canon Powershot SD1000 has a fully charged battery but won't turn on at all.
Does your camera turn on when it's in playback mode? I have a similiar problem with mine. It only turns on in playback mode.
Sep 25, 2009 | Canon PowerShot SD1000 Digital Camera
Cannonpower shot A590
Use a separate card reader to download your pictures.
Aug 30, 2009 | Canon PowerShot SD1000 Digital Camera
Canon powershot sd1000 malfunction
If the camera is not recognized on any other computers it's hooked up to either, your best bet is to take the SD card out, put it in a card reader, and plug that into your computer. If the card still works, you should be able to pull all of your pictures off--probably way faster than using the data cable too.
If your card is an SDHC card, make sure your reader can read SDHC. Most laptops made in the last 3 years have card readers, but they might not read SDHC cards. You should be able to pick one up for $5-10 at the store.
Jul 29, 2009 | Canon PowerShot SD1000 Digital Camera
I have the sd1000 power shot canon. i was taking a picture the camera took the picture as normal but when trying taking another shot i got an lens error restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
One thing, you mentioned that the lens error occurred after you wer able to take a good picture. This really sounds like your battery ran down during shooting, and did not have sufficient power to properly shutdown the camera. Focus on your battery as the potential cause first. Note that if the battery is older than a couple years, it may be time for a new one. Rechargeable are not meant to last indefinitely.
Jan 23, 2009 | Canon PowerShot SD1000 Digital Camera
Canon Not recongized by Computer
Try to change the USB connection type in the camera menu. There are several types like Mass storage, Pict. bridge, and the one you need is most likely PTP. Anyway, try all of those and maybe it will work. That is the most common problem when connecting cameras to Vista based systems.
Sep 14, 2008 | Canon PowerShot SD1000 Digital Camera
Canon SD1000 blurred pictures and blurred LCD, Camera wont focus! please help ive had it for 2 weeks
The best chance to use your SD1000 is to set to picture, push ISO (on top of the func. set ring) and set to hi. This works pretty well. Do not bother sending any camera to Canon, they charge the "standard charge" plus for all their manufacturing problems on all Canon cameras. Definately the worst customer service on the market.
Jul 07, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
43 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
