System wont rec memory addition 512 mb addition to existing 512, it only shows 512mb on board, Have a ARock k8upgrade VM800 mb. What can I do? Thank you Ben
  • Anonymous May 11, 2010
    please list the existing memory and the new stick of memory --brand and model # , RAM speed .
    Sergeant:
  • 349 Answers
Well the first thing to check is to see how much ram your board can take,look in your mobo manual , it will not recognize anything above.
it also must be the correct ram ie sdram.ddr,ddr2,sod
search on the net if you do not have the manual
if all is correct, when you boot up go into the bios (dont change anything) then exit "saving changes",this may solve your problem
to go into the system bios you need to hit a key when booting up ,sometimes its Delete, but it will show on the screen as you boot what key you need to use.
good luck
Terry
Posted on Mar 12, 2008
SOURCE:
K8Upgrade-VM800 mobo will still not detect large hdd of 500GB and 1TB before or after BIOS 2.30 update
Hello the home page is here:
http://www.asrock.com/MB/overview.asp?cat=Download&Model=K8Upgrade-VM800
You are running windows xp and you need at least sevice pack 3
from windows update.
When installed the system should now be able to see large harddrives
FAT32 supports up to 2 TeraBytes.
Jan 15, 2011 | Asrock K8Upgrade-VM800 Motherboard
Memory 1 gb wil not accept
Check with your motherboard manual or the website refering to your model and make to see what type of memory it will support. After that what type of memory do you have, is it ECC registered or NON ECC registered as the asrock would only accept unbuffered non registered ddr2 rams. If you do have the coorect type of memory and after power the system on and no display or beeps is heard, then it could be a bad memory or incompatible ram. Check this link for your motherboard spec and memory support....http://www.asrock.com/mb/overview.asp?Model=K8Upgrade-VM800
Jan 14, 2011 | Asrock K8Upgrade-VM800 Motherboard
Asrock K8UPGRADE-vm800 is it compatible with Windows 7
unfortunately I dont see any windows 7 divers
http://www.asrock.com/mb/download.asp?Model=K8Upgrade-VM800&o=All
but that does not mean it wont work, after installing windows 7,, update everything, including the optional updates this will pull the drivers and install them for you!!
so yeah it will work.
Jan 09, 2011 | Asrock K8Upgrade-VM800 Motherboard
Drivers de placa k8upgrade vm800 de audio wdm via ac 97
Try this
http://www.asrock.com/mb/download.asp?Model=K8Upgrade-VM800&s=754
Jan 22, 2009 | Asrock K8Upgrade-VM800 Motherboard
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Sound drivers
Hi sameer_korla, you can download any & all the drivers for the ASRock K8Upgrade-VM800 from the link below.
Enjoy!
Thank you for using fixya!
Mike
Dec 17, 2008 | Asrock K8Upgrade-VM800 Motherboard
Memory
It means the most your motherboard will support per slot is a 256 RAM. Also, on older systems, some RAMs are not compatible with others.
Apr 28, 2008 | QDI Group QDI Advance 6T Motherboard
System wont show memeory upgrade
thing you need to know:
  • how much ram can the board take (you can't put more in)
  • the type of ram (sod,sdram,ddr,ddr2) speed is less importantas it will drop back to the slowest chip.
  • look in the motherboard manual to find out
  • search internet if you do not have the manual
  • static electricity can kill electronic compomants so ensure you have earthed yourself before going into the box or handling the chips (this is a bit late but educational)
sometimes you need to go into the bios (change nothing but "save on exit) the system should see the new ram
good luck
Terry
Mar 11, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
80 people viewed this question
Ekse
Alun Cox
