Question about Samsung HP-T4254 42 in. Plasma Television
I have a white bar on the right side of the screen.
I have a major problem with my Samsung HP-T4254 Plasma.  Where the grey bar is located on the right side of the screen during 4:3 aspect programming, there is a white area that looks like white vertical lines.  Up close they are made up of 3 seperate lines of RGB.  It doesn't go away and it covers over HD programming.
  • 58 Answers
This is caused by either a bad address board (low $) or a bad plasma panel (high $). The only way to know is to replace the corresponding address board and see if it repairs the line. Hope this helps.
Posted on Apr 02, 2008
Samsung plasma tv HP-T4254 has sound but no image
Check and make sure your high def cables didn't come unhooked
Aug 28, 2014 | Furniture
I have sound but no picture
are you watching a local channel or a movie using a dvd player?. then the screen totally black or with white screen only?just let me know first so i can give further solution.
Oct 11, 2012 | Samsung HP-T4254 42 in. Plasma Television
Horizontal lines on Samsung 42
Hello horrizontal ines are controlled by your buffer (drive boards) or your ysus board. They are located on the side of the tv and are 3 boards that are connected together and connect to the side of the plasma screen. the two drive boards separate the top and buton. if the lines are on the top then you might try replacing the top buffer and vise versa. if that does not work then its your y-sus. be very carefull replacing these they are very sensative.
You can get get parts for this tv at www.interliquidparts.com
Nov 26, 2011 | Samsung HP-T4254 42 in. Plasma Television
I hace a samsung flatscreen that the screen flickers with no picture and turns itself on and off.
Hi this is a power supply issue. Your power supply is not strong enough to power your tv anymore.
Nov 19, 2011 | Samsung HP-T4254 42 in. Plasma Television
Can't get my samsung hp-t4254 42" plasma tv to
make shure that the computer is set up to display on the screen. To check and see right click on your desktop, click on the option that says screen resolution, and then change your settings from their. The tv will not register that you have a computer plugged into it if the computer is not sending the tv a signal.
Mar 05, 2011 | Samsung HP-T4254 42 in. Plasma Television
Would like intruction manual for 42 inch samsung plasma-serial no-Z5RX3STS400333K
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010200&prd_mdl_cd=&prd_mdl_name=HP-T4254
Mar 07, 2010 | Samsung HP-T4254 42 in. Plasma Television
Samsung plasma mode HP-T4254 turns off by
POWER SUPPLY BOARD IS FAILING, COMMON PROBLEM. CAN CALL 1-800-SAMSUNG FOR NEAREST SERVICE CENTER.
Dec 10, 2009 | LG 50PX1D 50 in. Plasma Television
Same as ericgustafso. My Samsung HP-T4254 42 in. Plasma TV randomly turns on and off. The short while it stays on, the picture and sound are perfect.
the capastor on the mains power board are on way out check them look for raised tops ( they look like little bateries with white line) if you are going to replace them yourself take picture so you put back same way
Nov 28, 2009 | Samsung HP-T4254 42 in. Plasma Television
Samsung hp-t4254 plasma
Hi Rickpo:
After installing the $11 kit and the additional $13 kit recommended by (http://preher-tv.blogspot.com/2010/01/samsung-hpt4254-no-power-repaired.html) mostly surface mount diodes (also available on Ebay), the Samsung HP-T4254 came back on, but would only play for 4 minutes. I found DX801 flowing both directions, replaced it with a diode from Fry's. Works great, $26 total repair costs :-)
Jan 13, 2009 | Samsung HP-T4254 42 in. Plasma Television
Blue haze on my plasma screen
The driver boards on that side of the set need to be replaced, about $400 for parts.
Jul 02, 2008 | Samsung HP-T4254 42 in. Plasma Television
Samsung HP-T4254 42 in. Plasma Television Logo
610 people viewed this question
Jerry Greenberg
Jerry Greenberg
