Hey, I have a piece of photo paper hung in the printer. It was a short piece that got hung. You can't see it anywhere in the printer. I've tried pulling the paper out,opening the top, and that's as far as I know to go. Can you help me? I sure would appreacite it if you could. Thanks Mrs. Peggy Lipscomb
  • 13,434 Answers
What printer do you have exactly?
Try pressing the paper feed / print button to get it to draw another paper in and push the other out. You might want to make sure there is no extra paper on the printer so more paper doesnt get stuck in.
Get back to me if that doesnt help.
Posted on Mar 11, 2008
    Sergeant:
  • 349 Answers
If it is a laser printer you can lift the roller & cartridge out, then remove the paper jamb,if it is not a laser then try running another sheet of paper through, if you have not done so as yet, apart from that i am not sure
good luck
Terry
SOURCE:
I have a Canon MP210 scanner/ printer that is telling me I have a paper jam but there is no paper in the machine. I've turned off the power and turned it back on, I've looked for a small piece of...
Your printer might be out of paper.. so try this..... press Black/Color button... if it doesn't work turn off your printer and press paper feeder on the back side and press the power button with holding the paper feeder. Don release it until the process of printer is complete... thanks
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Printer jam E2 with no paper
Are you sure there is not even a tiny piece of paper caught between the rollers? Most machines sense the resistants and give this message.Try rolling the rollers by hand,air spray the insides , lubricate the gears, you got nothing to loose.Good Luck.
Sep 08, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error: "paper jam", in brother dcp 8040, but not paper jam helpppppp?'
Hey try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Apr 24, 2009 | Brother DCP-8040 Copier
Hey..when i'm printing my document... the printer can't get the paper.. i mean d nia makagat ung papel..so how can i solve this prblem..pls..i need the answer urgent
not all your text is in english! but here goes. Is it possible4 that the plqatten lever is in the open position that if the lever that separates the roller to allow thicker paper.. try moving it towards the -ve mark. Make suer you are using the correct paper and it is in the paper holder correctly.
try pushing a stiff sheet of poster board paper through the roller to make sure there are no torn pieces of paper stopping the paper path
Apr 22, 2009 | HP DeskJet 845c Printer
Paper jam ;prints on paper but paper won't come out
hey, go over this:
alternative :
Mar 24, 2009 | Dell 1700n Laser Printer
Paper jams when i use 220gsm paper
hey, try this:
alternative :
Dec 28, 2008 | Epson Stylus Photo R340 InkJet Printer
Paper feed
What the hell, I have a mid-term that is due and I need this thing to work, What a piece of ****!
Jan 10, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jam
Smashed up against right or left inside frame wall, where print head slides left and right.
Nov 21, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP 1510 - Photo Paper Jams
Hi, try using HP brand photo paper, HP makes their special photo printers and special photo paper for them.
The surface of the back of the HP's paper is rough, like sandpaper to avoid the paper being jammed in the cheap loading mechanism of their actual printers.
Oct 11, 2007 | HP PSC 1510 All-In-One InkJet Printer
Computers & Internet Logo
46 people viewed this question
Ekse
Alun Cox
