FixYa.com
Tags:
Flat Panel Televisions
Generic problem for all Flat Panel Televisions
42" Plasma TV Has 3" black vertical bar in the... (by 4 users)
posted by WebDTec on Mar 11, 2008
I have had my SuperScan 42" EDTV Plasma for 3 + 1/2 years. Of the 6 possible connections I have connected to it: (AV1)-CableDVR, (AV2)-Samsung up-converting DVD player, (AV3)-nothing, (AV4)-Pioneer 5 disc 500W Suround/DVD, (RGB1)-HP DV5400 Notebook PC via VGA cable, and (RGB2)-Mackbook Laptop using a Mini-HDMI to HDMI adapter connected to a HDMI/DVI cable. I have been happy with it's performance for the most part, knowing I didn't buy top-of-the-line so it has some trouble with darker scenes which tend to be somewhat pixelated on the S/s DVDplayer and the cableDVR (both are 480i), while the computers and the up-converting DVD are all higher resolution and have much better displays.
My problems are:
1.) For about the last six weeks when I turn on the tv and go to the cableDVR or the S/s DVDplayer the flesh tones are very much on the red side, which I can solve by going to Menu/Tint and move the number either up or down - once I have done this the flesh tones are corrected, even though I leave the number set at the same as before I moved it - in other words just the movement on the tint scale resets the color to display the correct values I have setup. This is a symptom of some part that is failing? I would like to know how to fix this.
2.) This just started last night. after having the tv on for about half an hour a black vertical line 3 inches wide appeared in the center of the screen. I tried turning the tv off and waiting various lengths of time from 1 minute to ten minutes with the results of either the black vertical bar was there when I turned it back on, or it would re-apear after 1 minute or so. I switch to all my devices and the bar is there for every device. Today I have just begun using my computer and the bar was gone for the first ten minutes, but then showed up again.
And the spooky part is, after 30 minutes I decided to look online for some way to figure out how to fix it, and when I got to this site, the black bar went away. But I'd still like to know what I need to fix it, as it will probably come back, and it's very hard to watch a movie with a 3" bar down the middle, and shrinking my application widows to fit on either side of the bar is also a distraction.
3.) (minor) Does anyone know what the remote codes are for SuperScan? I bought it from Sears and the sales guy said it was Hitatchi with the Sears Plasma name of SuperScan, but I don't know if that's true or not and none of the Hitachi codes work for it either.
I've contemplated buying a new TV and it will take six months of eating less and buying less gas for the car to save enough on my disability payments.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by j01weeks, posted on Aug 24, 2008
I have a Sharp TV and flat screen. And a few days ago I started to have a black bar that covers almost most of the screen the sound is good, the only time the bar disaperars is when I use the remote for valume or to find a solution to the probel can you help me.
Comment by JeremyGoodma, posted on May 29, 2008
I have the same issue with my 47" Magnavox Plasma. I have disconnected everything and have left the TV off for several hours ... however the bar still appears?
Comment by Guest, posted on Apr 01, 2008
I having the same issues with my 50 inch Panasonic.
Best Solution
posted on Jul 01, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have the same problem with my panasonic plasma..I can clearly see 2 side bars when the Tv is off..the left one is more obvious to see..When I watch a movie at night I can't see it. I have no idea how it did happen but I talked to circuit city and they are willing to replace it since it is still under a month..it is anoying though to have to deal with such problems. I bought my TV june 21st.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 17, 2008
Not Rated (0)
hamish-ct
Rating: 0%, 0 votes
Just happened to my 50" plasma which was also purchased june 21st. I hope they dont make me pay the shipping, its 200-300 each way!
This Problem Also Relates To: Audiovox JE2043 20 in. EDTV-Ready LCD Television Panasonic TC-32LX60 32 in. LCD Television Panasonic TH-37PD25U/P 37 in. EDTV-Ready Plasma Television Panasonic VIERA TH-65PV500 65 in. Plasma Television Panasonic TH-42PX60U Television Panasonic TH-42PZ700U 42 in. Plasma Television Sony PFM-42V1N (Silver) 42 in. EDTV-Ready Plasma Television
Can you Help with these Flat Panel Televisions problems?
iLO LCT32HA36 Television
iLO LCT32HA36
Can you give me the code number... Answer This...
Toshiba REGZA 42WLG66 42 in. HDTV-Ready LCD...
Bright colors flicker
Bright colors such as uniforms... Answer This...
Philips 50PF7321D 50 in. HDTV Plasma...
error code
green light a few seconds then... Answer This...
cannot get sky (pace box) to...
dont know how to tune remote... Answer This...
Sony BRAVIA KLV-40U100M 40 in. HDTV-Ready LCD...
No image from inputs 1 and 2
No video signal from inputs 1... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
