Question about Samsung Televison & Video
Samsung HL-T6176 DLP How to Adjust (center) the picture
my screen needs to be adjusted so that the picture is centered and my picture also looks like it is bowed
I would love to tell you how I fixed the above issue and if you would like to subscribe to my site I will tell ya.
Posted on Mar 13, 2008
Can I diagonally adjust (clockwise/counterclockwise) my Mitsubishi DLP TV? The picture is off center
You need to align the optics mechanically. If you changed the dlp chip and its not centered then the chip is not shimmed properly or the reflection mirror behind the lens needs adjustment. You should get a service manual for that chassis and follow the directions. there may be an electronic method but I am not aware of one.
Sep 05, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Samsung ht-l5055 picture off center
dlp chip need to be adjusted, very sensitive to adjust.
Jan 19, 2014 | Samsung HLN567W 56" Rear Projection HDTV
The picture of my Samsung DLP tv is getting darker. We have had several power outages over the past few days as a result of the hurricane. Do I need to make an adjustment?
Yes, or it can also be a burned fuse, you can take it to a service center and repair it yourself.
Or maybe the power outage just disconfigured the Tv try resetting it.
Aug 30, 2011 | Samsung DLP HL-P5663W 56" TV
White dots on tv screen
The DLP chip has failed and needs to be replaced. You can call 1-800-samsung to find the nearest service center. Samsung is covering the cost of this repair on certain models, so ask them if yours is covered.
Aug 10, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung 50'' DLP PRblems
Okey dokey... you'll need to remove the back cover on this set and make an adjustment to a part called the "DMD board". The DMD board is a large, flat, vertically oriented board with a perforated thin steel cover over it.
Basically, there is a tiny tiny 'tv screen' on the front side of this board and by moving this board around you can 'fine tune' the picture position. All that is typically required is to loosen the screws around the perimiter of the board (JUST SLIGHTLY! You don't want the board to fall out of position!) and slide the board around, preferably with someone watching the screen, until the picture looks perfectly centered.
Something to keep in mind is that the TV will not operate with the back off due to their being a small switch with a blue lever on it whose purpose is to prevent the TV from powering with the lamp cover off. Just tape this switch up so your set will power and then you can rock and roll. Good luck!
May 18, 2009 | Samsung HL-T5087S Television
Samsung dlp replaced color wheel
Need to get in the service menu.
That is not for customer for only autherized samsung service man konws about that.
Please contact samsung service center with phone.
Aug 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Lines, colors, delayed images
Had the same problems.  This was after the a power outage.  Had green vertical and horizontal lines, like a checkered shirt.  But I searched online and found the simplest solution.  Just unplug the power.  And it worked.
Jan 02, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP Vertical Hold
Problem is either bad connect inside or heat-related failure....
also called thermal break.....you will need help from a knowledgeable SAMSUNG tech.....prefer authorized service
center, then you can give feed-back to SS customer service if needed.......................T.
Dec 10, 2007 | Samsung DLP HL-P5663W 56" TV
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
How to manually adjust the centering of the picture
On newer televisions the centering adjustment is only in the service menu. I wouldn't suggest anyone accessing it unless you understand all of the abbriviated alignments.
Feb 21, 2007 | Samsung TX-R2035 TV
Televison & Video Logo
279 people viewed this question
Henry  Thomas
Henry Thomas
