Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Water standing in bottom of dishwasher
What would cause this and how can i fix it
    President:
  • Kenmore Master
  • 2,651 Answers
Alot of water in botom?? its normal to have alittle maybe just ot about the filter cover. not enought fill bottom of tub though. if htat shte case, try removing clamp hook up under the sink and look for possible clooged drainline
Posted on Mar 12, 2008
SOURCE:
Backed up dishwasher
My Dishwasher is Backing Up with Water - YouTube
? 2:08
https://www.youtube.com/watch?v=JtbbEGo-X1w
Mar 4, 2014 - Uploaded by Appliance Princess
My dishwasher is backing up with water. What do I do? First thing you do, turn off the dishwasher. OK, I get ...
Is Your Dishwasher Not Draining? Try These Three Tips ...
https://www.discovercabrillo.com/is-your-dishwasher-not-draining-try-th...
Sep 23, 2015 - If you see a lot of standing water at the bottom of the dishwasher in your ... that prevents water from your sink backing up into your dishwasher.
drainage - What is causing my kitchen drain to back up into ...
diy.stackexchange.com/.../what-is-causing-my-kitchen-drain-to-back-up-...
Apr 25, 2014 - That air gap above sink level prevents water backing up into thedishwasher and prevents a vacuum sucking water back into the dishwasher.
I Fixed Our Dishwasher! Here's How I Did It... - Household Tips
https://household-tips.thefuntimesguide.com/2006/07/fix_dishwasher.php
Jan 19, 2016 | Whirlpool Dishwashers
Standing water in dishwasher
Good Afternoon friend, thank you for your post!
I understand that you have some standing water inside of your Frigidaire dishwasher. It is a normal operation to have anywhere from 2 to 3 inches of water inside of the tub of your dishwasher. If it is anything more than that you could have an issue with the drain pump or drain line.
You may want to check the drain line for any restrictions or clogs that could cause improper siphoning from your dishwasher. You should also make sure that the filter located in the bottom of your tub is clean, that could cause water to stand within your dishwasher. I hope this information is helpful. -Matt
Mar 11, 2015 | Frigidaire Dishwashers
Standing water in the bottom and a bad oder
First make sure your drain trap is not clogged, but if water is not moving out at all, then..
its a problem with the pump on the dishwasher(most probable) , or it can be a clogged drain hole.
If its a new expensive fancy computer model it could be the brains, but look above for the most likely cause.
Some dishwashers are easy to to basic fixes, pumps, motors, drains being plugged, others I would not touch..
Oct 07, 2012 | Dishwashers
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
Sep 20, 2009 | Tappan Dishwashers
Tappan Dishwasher w/ Standing water
Try draino first then take it apart on the inside bottom to see what might be clogging it.
Aug 04, 2009 | Dishwashers
My Dishwasher works but still leaves some standing water.
Check the filter unit located at the bottom (inside) rear for clogging. Sometimes food will accumulate in the filter and not allow the unit to completely drain.
Jul 23, 2009 | Whirlpool 24 in. DP840D Free-standing...
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher----GE Nautilus
1. Check drain pipe, air gap and drain for blockage.
2. Could be too much dishwasher liquid build up (i.e. too much Cascade used over time, clogging things inside the machine). Remove all standing water first then boil a big pot of water (3 to 4 quarts) and carefully pour in to bottom of dishwasher. Let stand until cool. Attempt to drain.
3. Turn off Circuit Breaker to dishwasher. Open kick plate at bottom and look around for the cooling fan for the motor and spin it free in both directions. Look for any solenoids and push them in to the other position. Attempt to drain on dishwasher.
4. If the above steps don't fix it and you are not handy, it's time to call in the repairman or consider getting a new one. If you are handy, do a web search on more detailed solutions for your model of dishwasher (typical failure points are valves, impellers, pump etc).
Dec 27, 2007 | Smeg 24 in. DWF614SS Stainless Steel...
Portable dishwasher
The first thing you might want to do is check the water pressure in the house. Ideal water pressure should be from 55psi to 75psi max. I have seen homes that had pressure around 125 psi which will cause pressure leaks in water heaters, softners, washer valves, r/o systems. Check to see that all, if any inlet screens are clear and free from any grit and sand. It's possible that your inlet water valve (wd10m0010) has become restricted. Other than that, the complete uncoupler hose assy. part number is wd24m0030. These parts are for the dishwasher model ending in gsc3400j00bb. They are the same for model number ending in 00ww. Good luck.
May 07, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
105 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
