Question about Rosen inVUE II Video Ent. Sys '00-'02 Chevy Suburban w/o Sunroof
Car won't start
I have an 89 chevy camaro. the starter is good. i found out that all the wires are getting power. but the wire that goes to the silenoid isn't getting power. can you help me. i was told to check the relay switch. i don't know where that is. or that it could be my nutral switch. again i don't know where that is. Help please!!!
    Problem Solver:
  • 5 Answers
Your neutral switch is in your gear shift. it's just a little button on the shifter if it's an automatic... and if standard it''ll engange when you push the clutch in... your ignition switch might be fried if you are turning the key and the wire is getting no power..
Posted on Mar 12, 2008
SOURCE:
WHEN I TURN THE KEY ON MY 1997 CHEVY CAMARO IT DOES NOTHING WON'T EVEN CLICK THE STARTER. THE BATTERY IS GOOD AND HAVE LIGHTS AND POWER TO THE AIR CONDITION FAN
Not sure that it's my same problem but I found that my 2002 had a chip/resistor in the key. We measured the resistance and then went under the dash locating the red(hot) wire to the ignition switch, then cut it and built a resistor to the specs of they key and inserted it into the starter wire. Simply put, you are making the starter sense the resistance and start the car when the key is turned. Hope that helped. We searched it through google and it told us how to build the resistor. There was also a spec and directions to determine the resistance of the key.
Jun 08, 2014 | 2002 Chevrolet Camaro
89 Ford F-350 won't start
Check all cable connections for corrosion and clean everything you have connections from the battery to the starter relay the actual cables to the starter and also check the starters ground strap at the nose of it if it's frayed or broken you found it this is a contact problem and clean and tighten everything do not use wire brushes 4/0 that's 0000 steel wool =liquid wrench=pb blaster will all help the wire brush rips apart the terminals and battery post causing loose connections they must be tight no air gap good luck stephen
Dec 15, 2017 | 2004 Ford F350
Won't start. Have I missed something?
Starter is good,battery and connection,Cap is good no cracks.
Apr 23, 2013 | 1987 Chevrolet Camaro
1986 camaro v8 tunedport will not start wipers lights etc work brand new battery.i get no crank at all. neutral safty switch mabe??what do you think????
if you use a test light and check for voltage on the big wire at the starter this will tell you that the wiring from the battery to the starter is good.now check the small wire at the starter while someone tries to start the car you should have power to that wire.if you do then the wiring from the ignition switch to the starter terminal and everything in between is good.the problem is the starter solenoid or the starter.its a good idea to replace the starter as a new solenoid comes with it as apposed to changing only the solenoid and the starter goes bad shortly after.if you don`t have power to the terminal then check the neutral safety switch.
Apr 05, 2011 | 1986 Chevrolet Camaro
89 camaro v8 5.7L, tune port fuel--Not getting power to injectors
sounds like the injector got stuck close because of sitting so long....take em out and cleasn them up real good an try that it should work make ensure the wires have a good solid connection and no bent pins.
Oct 05, 2009 | 1989 Chevrolet Camaro
Small block chevy wiring
You should have a purple wire that goes to the starter,plus the red one from pos on battery. I believe you will have a red wire and a black w/red stripe or red/ w black stripe gong to the alternator.
As far as the distributor I think factory was a big pink wire. But you can also just run a wire from the fuse box that would only be hot with key in on position. If you need more help please ask.
Make sure you have your seat belt on and hang on to the steering wheel when you drop the hammer on that 383cu.
Good luck and enjoy.
Apr 07, 2009 | 1988 Chevrolet Camaro
Camaro wont start only clicks
i would start by replacing the selenoid and having the battery and starter tested. then go on to plugs and wires
Apr 02, 2009 | 1989 Chevrolet Camaro
89 iroc camaro starter wiring connections?
I'm assuming there are 2 wires. On most starters there are 2 threaded posts. One will be chassis ground the other one will be electrically isolated on an insulated standoff, this will be the positive (usually red) wire from the starter relay which is usually somewhere close to the battery. If there is only one wire then it will be the postiive and bolting the starter in is "connecting" the ground. Make sure the mounting area is clean.
Mar 29, 2009 | 1989 Chevrolet Camaro
1990 chevy camaro wont turn over
Check to make sure that the purple wire is hooked up to the S terminal on the starter solenoid.
Jan 17, 2009 | 1990 Chevrolet Camaro
Car Audio & Video Logo
49 people viewed this question
Top Rosen Car Audio & Video Experts
Pierre Laplante
rd2xpld
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
