Removing old singer baseboard heaters
We bought a house with old Singer baseboard heaters.We now have a heat pump and are trying to remove the baseboard heaters.What is the best way to do this?
SOURCE:
  • 9 Answers
SOURCE: low heat output
first of all, have the thermostacts been checked,if not they will need to be checked,mainly dust can get into them.
if they have heating elements,ckeck to see if they are all in tact and have no dust on them.if this does not work then you will need new heating elements,which you might not get any more,if this is the case then im sorry to say that new heaters will be needed. i hope this helps and good luck.
Posted on Nov 21, 2007
  • 625 Answers
SOURCE: connecting 240 volt singer baseboard heater
Power from your panelbox goes to the wall mounted thermostat. From there a two wire goes to the heater. In the heater one overload wire goes to the heater. the other overload wire goes to one side of your LINE. the other wire goes to the heater wire.[LINE]
Posted on Nov 29, 2007
SOURCE: Baseboard heater giving off burning smell
I just ran into this same problem yesterday when I had a new baseboard heater installed in my tiny bedroom. When I turned it on it gave off a horrible smell that made me cough and choke. The stench went everywhere -- opening the bedroom windows and closing the door was not enough. I called the electrician this morning and he told me that it is the coating on the heater coil. He said they coat the coils when the heaters are manufactured to prevent them from corroding before they are installed. He said this would happen with any new baseboard heater I got. He suggested that I go stay somewhere else for a few days while leaving the heater on high to let the coating burn off. Since I could not do this, I had the heater removed again.
I wish I had a better answer for you. It seems crazy to me that a manufacturer would make heater coils out of a metal that corrodes easily -- I mean, it will start corroding as soon as the coating burns off, right? Plus, why use a toxic coating in the first place?
Posted on Nov 26, 2008
shastalaker7
  • 1515 Answers
SOURCE: Good day, I just moved into my new home on August
It sounds to me that the motors on the units in question, may need a few drops of oil on the bearings. I have seen motors in these heaters and most do have a place to oil them, they wouldn't have sealed bearings as the newer motors.Check the blower wheels also for dirt build up on the blades, as this will cause them to be out of balance and cause some noise also.
Sincerely, shastalaker7
Posted on Oct 30, 2009
  • 128 Answers
SOURCE: DPDT thermostat for Singer baseboard heater.
as close as I've found
http://keithspecialty.com/k/67-411.htm
http://www.heater-store.com/specialty-thermostats_91_ctg.htm
Posted on Nov 02, 2009
How to set heat for baseboard heat
They use a 120v thermostat you should be able to buy one wherever you bought the baseboard heaters. Be aware those heaters costs a lot of money to run and dry out your house like a desert buy a few room humidifiers when you get the thermostat. Make sure you use the correct size wiring to the baseboard heaters and the Tstat if you undersize the wires for the breakers involved you'll more than likely cause a electrical fire.
Oct 01, 2014 | Honeywell Heating & Cooling
I have baseboard heating and not sure if i bought the right thermostat there is a switch inside fir gas/oil or water pump/elect. modle # rth2300/rth221
No. Baseboard heaters will use a 120v or 240 thermostat. The thermostat you have is for 24v low voltage only. Hope this helps!
Dec 08, 2013 | Heating & Cooling
IS A HYDRONIC ELECTRIC BASEBOARD MORE EFFICENT THEN THE STANDARD ELECTRIC BASEBOARD HEATER
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
How do you reduce an electric bill in a all electric house?
The biggest wasters of electrical energy are Heat and A/c, water heaters,dryers and ranges. The more you insulate the less you have to cool or heat. If you live in a warm climate, consider installing an attic fan that runs on a thermostat or timer. During the summer allow it to run, during winter turn it off. Ceiling fans in rooms that are occupied create the illusion of being cooler, allowing the thermostat to be turned up.I'm not sure of the exact numbers but any thermostat setting on your a/c below 78 is more inefficient so try kicking the a/c up and the heat down. I'm a Florida boy so I can't tell you much about baseboard heaters. I know that anything that heats things up cost a lot in energy.
Consider installing a hot water heater timer. Commonly called a "Little Grey Box". Whenever your water heater is not actually being used it is still heating the water. A big waster. Once installed set the timer to cycle the water heater off during times when you commonly don't use it. Overnight,when your at work etc....
Somewhat antiquated, but a clothesline always uses 100% less energy than a clothes dryer. :) Short of this, try to fill the dryer all the way and make sure your dryer vent and lint trap are clear.
Microwaves draw 1/3 the energy of a range and run for 1/10 of the time. Microwave as many things as you can. In our house we have started microwaving canned veggies and boxed side dishes and such.
These are the big ones I've done at my house. A lot of the other things seemed to be more work than they are worth. Some actually end up costing you more if you don't own the house for decades.
There are many sites you can visit such as your local power company and possibly your local government pages.
Good luck. I'm in the same boat with the high power bill.
Mar 24, 2009 | Fahrenheat F2543 Baseboard Heater
Oct 31, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Honeywell HZ517 Baseboard Heater
You can try to disassemble the heater and look for something wrong like a loose wire: in order to do so: Unplug the heater and let it cool completely before disassembling it. Remove the rear grille and the control knobs. Remove the front grille by unscrewing the fasteners on the back of the housing. Remove the front grille by lifting the control housing and pulling the front grille toward you. The motor, fan, and heating element are now accessible for testing and repair. Remove the thermostat from the control housing and disconnect the wires. Remove the heat control's mounting screws and clips to access and disconnect wires. Good luck
Nov 28, 2005 | Honeywell HZ517 Baseboard Heater
Heating & Cooling Logo
193 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
