Question about Toshiba TP50H50 50" Rear Projection Television
Toshiba tp50h50 the picture waves until i hit the menu button and it is perfectly clear for a second then keeps waving. if i exit out of menu it clears up a second then continues the waving. sometimes it clears up for awhile after leaving it on for a few minutes. but when i turn it on its all white hiss for a minute then tries to come in but its all wavey unless i hit the menu button and its crystal clear for a second. now after letting it run for an hour it hasn't straightened out again. its all new cables and ive hooked up another tv directly to the cable and its fine. the big screen won't. if the cable company was sending us an hd signal and im not hd compatible could that cause it. Any suggestions, I've never seen anything like it.
Replace the power supply deflexion module sounds like a cap proplem on the board
Posted on Jul 04, 2008
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
Why bose wave radio touch pad does not work ?
There's a setting to turn the touchpad on or off. Yours has probably been turned off. Here's how to turn it on.
1. Press and hold Alarm Setup (Menu) on your remote until -SETUP MENU- appears in the display.
2. Press Tune/MP3 until TOUCH PAD- is displayed (8 presses)
3. Press Time- or Time+ to select OFF or ON
4. Press Alarm Setup (Menu) to exit the menu, or simply wait 10 seconds.
You're done!
Jul 22, 2014 | Bose Wave Radio
Getting message "Measuring tool doesn't respond"
Try cleaning contact pins of U-WAVE-T cable with 91% alcohol pads
If possible replaced batteries in gauges and U-WAVE-Ts
User's Manual:
http://www.mitutoyo.co.jp/eng/support/service/manual/pdf/99MAL110B5.pdf
Quick Manual:
http://www.mitutoyo.co.jp/eng/support/service/manual/pdf/99MAL216A7.pdf
Feb 21, 2013 | Mitutoyo 02AZD730D U-wave...
How do I set my Wave II, it right now says 6:07 am and it is actuall 2:45 pm
  1. On the remote, press and hold down Time - or Time + for one second until "Clock Set" appears on the display, then release the button
  2. Press and hold Time - or Time + until the displayed time matches the current time
  3. Wait five seconds for the system to automatically exit the "Clock Set" mode
Mar 13, 2011 | Bose Wave Radio II
I cleared one folder called WAVE with my computer and now there´s a messege on screen "data damage". the folder contains the preseted sounds inside. i need help.
Here's a hunch:
When the RC-50 was hooked up, your computer had access to the internal memory. The WAVE directory is where the wave data is stored. The RC-50 must have noticed that the wave data for patches that were supposed to have data was in fact gone.
So, you can probably just do a factory reset:
With the power off, while holding both single/multi and loop-sync, power the RC-50 up until it greets you with SYSTEM/PATCH use the PARAMETER buttons to go back and forth. In your case, you can probably leave "SYSTEM" alone and just select PATCH. Once you've selected which section of the RC-50 you want to reset, hit the WRITE button.
Aug 13, 2010 | Boss Rc 50
Roland Spd-s pad #1 change to different patches when hit
I think there is an option in the setup menu that makes the pad do this.... i remember reading it in the manual. sorry cant help more than that...
Aug 08, 2008 | Roland Spd-S Sampling Percussion Pad...
Toshiba 50hp66 picture waves
Please describe the 'waves' and what you are watching when it happens, is it on everything? e.g. normal TV and when watching a DVD? Are the Waves a grey close pattern going diagonally across the screen for some other sort of pattern?
John
Jun 13, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
TP50H50 Black Box on screen
you may have the set in text mode (part of the closed caption menu)
Feb 07, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba TP50H50 50" Rear Projection Television Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
