Question about Broksonic CTGV-5463TCT TV
My tv i need to program the channels on my broksonik tv. but i lost the remote. is there a way i can do it with a g.e. universal remote or the buttons on the tv itself?
  • ALFONSO DELATORRE Apr 13, 2008
    I tried with several remotes to no avail
  • Anonymous May 10, 2008
    Got a Broksonic with no remote. How do you program with a Phillips Universal Remote
If you hold both volume tabs in at the same time, a menu will pop up. Unfortunately, it will not help with the aux.
Posted on May 11, 2008
  • 95 Answers
What is the code for a symphonic tv and a rca remote. I also need insructions on how to program the remote that works with my tv. I lost the instructions
These are the steps on how to program your RCA Universal Remote Control to your Symphonic TV.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV button. When the TV button flashes proceed to the next step.
  3. Enter the three digit code. In your case, the code for the Symphonic TV are 064 or 076.
  4. Release CODE SEARCH.
  5. With the TV on, press another button, for example CHANNEL UP. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-5 using the other code number.
Jun 12, 2010 | RCA Universal Remote Control
Lost codes for v.old universal remote
All universal remotes work about the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 24, 2009 | Sony SLV-SE720 VCR
Lost channels on a Sony KV-1972R
Go to menu and select add/delete channels. Then select 02, or 03. Some channels that are selected the numbers will show green, channels not locked in will be red.
Jan 18, 2009 | Televison & Video
Lost remote programing directions
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Lost manual to rca universal remote, lost programing to operate remote
RCA Universal remote codes for the Mitsubishi TVs are...006,011,014,019,022,027,041,056,061,068.
First, turn on TV
Press and hold code search button on remote
Enter the three digit code you want
Release code search
Push channel up, if device responds, that code worked.. If not, repeat steps 1-5 with each code until you find the one that works. This information can be downloaded from http://www.thompsontv.com/rcarc.html
If you want a hard copy with codes for all TVs.
Aug 29, 2008 | RCA Universal Remote Control
I lost my remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Programing
Hope this helps :)
Jun 09, 2008 | Philips Universal PH301S Remote Control
Philips remote codes
Hope this helps :)
May 25, 2008 | Televison & Video
Can you help me program my remote?
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
Broksonic CTGV-5463TCT TV Logo
148 people viewed this question
Top Broksonic Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
