KONICA 7020 TAPPING SOUND WHEN PRINTING
Hi there, i have a konica 7020, there is a tapping sound thats occuring while it is printing. the sound seems like it is coming from around the toner area, its as if its a wheel that has teeth on it which is the problem i think. we just had it transported and then it made the sound. hope some1 can help..
  • 589 Answers
Either the toner bottle may have come out a bit, or the toner has become clogged / compacted.
This series copier was notorious for the toner chute / delivery system getting clogged / compacted with toner. Given the fact that the machine was recently transported, this is a very good possibility.
First check the toner bottle, and make sure it's pushed / locked all the way in. You will feel a "click" when the bottle is seated properly.
If it IS locked in, and the noise continues, DO NOT CONTINUE TO RUN MACHINE!!
A clogged / toner chute will undertone the system in a very short amount of time, and will result in a service call being needed, and possibly damaged to internal parts. In severe cases where customers continued to run them, main controls boards have been damaged due to increased loads on the toner / developer drive motors.
Unfortunately, to remedy the problem, you will need to place a call for a tech to come and clean / vacuum out the toner chute / delivery system.
Posted on Mar 11, 2008
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
I am trying to print with my bizhub 210 all i get is a page with a black block but if i coppy it is perfect what seem to go wrong please help
Sir/Mam, mite try to reload the drivers. Also check if the problem is with a certain program for example try printing adobe, then word then a web page then e-mail. try different computers. The way you explain it sound like a print controller issue. that circuit that interfaces the copier with the computer.
Jul 30, 2014 | Konica Minolta 950-281 Genuine Konica...
WHERE CAN I FIND A USAGE REPORT?
press the star button to print that info press print on that page
May 28, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Konica minolta 8031
same issue never found solution... Konica rep came out and said he didn't know what it is then told me to lease a new machine... lol
c-3c30 = Designed Obsolescence
May 09, 2013 | Konica Minolta Bizhub 8031 Copier
KONICA 7020 ERROR F26-2
You'll probably need to call a tech & have him Clean the sensor in the drum unit, chances are thats why you had faded copies in the 1st place,that sensor works with the tds sensor in the dv unit to add toner,good luck
Jul 24, 2012 | Office Equipment & Supplies
My Konica 7020 nmakes a slight grinding noise when printing and then it stops and says open conveyance 6 fixing unit guide 5 and remove paper. Thanks Randy
Most likly, you have a broken or you have a fuser driver gear that is missing a tooth from it or the gear is worn out. The problem could bee that the ball bearings in the fuser unit have stoped turning or not turning correctly.Causing the drive gears to fail.
Mar 21, 2009 | Konica Minolta Office Equipment & Supplies
Paper jam
I strongly recommend a service tech. It sounds like you will need a PM kit,fuser claws and a few DFP rollers.
Mar 21, 2009 | Konica Minolta DiALTA Di200 Copier
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
