Question about Kodak Easyshare M753 Digital Camera
Using rechargable battery with new camera for the first time
Am I supposed to assume that it is necessary to charge the battery before using my new camera for the first time??? There's no mention of it in the instruction manual!
  • 185 Answers
If you are using a rechargeable battery, yes you should fully charge it before you use the camera for the first time. Rechargeable batteries are normally supplied without a charge from the factory, but not always. Fully charged batteries may be in storage for a long time before the camera is purchased and unlike modern dry cells, rechargables will not hold a charge for years.
Fully charge your battery, then run it until it has completely exhausted. If you plan to put the camera in storage at some point in the future, always recharge the battery every couple of months or so, to keep it in good condition.
Of course make sure the supplied battery is in fact rechargeable and not a lithium which should not be recharged.
If you found this info useful, please give me a thumbs up...
Posted on Mar 11, 2008
6ya staff
SOURCE:
My camera wont charge
It's not supposed to charge. The X014 uses standard AAA batteries. If you use rechargeable batteries then they must be recharged outside the camera using a separate charger.
Feb 21, 2011 | Vivitar X014 Digital Camera
Im tommy from nigeria,i use hp camera cb350 but it's a battery killer.i use energizer 2500mph rechargeable.after charging the maximum shots it takes is between 5 to 10,where as some of my friends takes...
Hi, Below are the tips to you : Digital camera use high current to make it works. Your 2 units battery 2500 mAh are normally worth for your camera. Your battery will get its full capacity after charged for 13-15 hours from designated charger ( I supposed you to use energizer charger).In your camera set your flasher to auto mode. This will save the power rather than use the flasher manually / all time. If after fully charged the battery and you still get the same performance. You may have wear down battery and need replacement. New battery required 24 hours charging before use at first time. Now install your new batteries. If you still get same problem, you've got problem with your camera internally.
Dec 04, 2010 | HP CB350 Digital Camera
My camera shows that battery is low even if battery is new
Clean the battery terminal connections with rubbing alcohol and a cotton swab
Sep 29, 2010 | Nikon COOLPIX L20 Digital Camera
I just charged my camera's batteries and an error
Your camera is telling you that the batteries have insufficient power. First thing to check is that the battery contacts on both the batteries and inside the camera are bright, clean and free of grease or oil.
Assuming that you're using the original NiMH rechargeable batteries which came with the camera, then you almost certainly need to replace them with new ones as they cannot be reused indefinitely.
To test whether the problem is with your rechargeables or with your camera is very easy. Just buy a set good quality, non rechargeable, alkaline (e.g. Duracell) AA batteries. If the problem disappears then you know that you need to buy new rechargeable NiMH batteries next time.
There is also a small possibility that you have a faulty recharger but it's unlikely. The only way to test it without special tools is to try getting your NiMH batteries charged in a borrowed recharger. If the batteries get fully charged then the error message on your camera will vanish and you'll need to buy a new recharger. Just make sure that the charger is designed for NiMH though or you will damage your batteries and possibly the charger.
Jan 15, 2010 | Canon PowerShot A560 Digital Camera
It does not charge, where can I buy a new one?
There's nothing wrong. The camera isn't supposed to charge batteries. If you use rechargeable batteries then you must charge them using a separate charger.
Nov 26, 2009 | Vivitar ViviCam 8400 Digital Camera
Problem with Nikon Coolpix Digital Camera internal battery
Hi
This is a design glitch with these Nikons and many people are complaining about it. The clock battery is supposed to take a small charge from the main battery - enough to maintain the settings when the camera is not in use. However the clock battery that is used is not sufficiently strong enough to hold a charge for an adequate length of time.
As this is somewhat of a design flaw it is unlikely that a new clock battery will make any significant difference to the problem you are experiencing. Neither is it a user serviceable job and for these reasons I do not recommend that you try to replace the clock battery.
Nikon themselves say the following;
"The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset.
Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Hope this helps. Thanks for using FixYa.
Oct 26, 2009 | Cameras
Rechargeable batterie won't work in my Camera.
Not sure what camera you have, but some cameras require a very steady power supply voltage. Also not sure how old your rechargeable batteries are either, but batteries (alkaline and rechargeable decay over time. With the rechargeable ones, the more you use it, the less it can charge to full capacity over time. For example, if your rechargeable battery is supposed to charge up to 1.5V, over a period of a year with constant recharges, you can test with a volt meter and see that it never really goes back up to 1.5V, but more like 1.48V, 1.45V or maybe even 1.4V.
Depending on the camera or other item you use rechargeable batteries on, it can adapt to low voltages with special circuitry inside (but only to a certain limit, when a battery is old, it is old).
You can try buying a new set of rechargeable batteries and use it few times and see if this fixes the issue. If not, your camera may be faulty and just draining the battery (not too likely, but it happens).
Check out this site for some useful info.
http://www.steves-digicams.com/nimh_batteries.html
Apr 30, 2008 | Canon PowerShot S5 IS Digital Camera
Aiptek DV3300 do not turn on
Maybe the rechargeable batteries aren't providing enough power. I'm assuming the batteries are recently, fully charged. Rechargeable batteries can lose their charge over time even if they're not being used.
Nov 29, 2007 | Aiptek MPVR Digital Camera
Why won’t my camera recharge my batteries?
Not all cameras can charge batteries. CAUTION: Rechargeable batteries must never be used in the HP Photosmart 210 and 215 series digital cameras. The overload protection and control circuits are not designed to handle the kind of power intensity delivered by rechargeable batteries. If the camera is a model that does charge batteries, ensure the batteries are rechargeable: The only acceptable rechargeable batteries for HP Photosmart cameras are NiMH cells. Neither lithium nor alkaline cells are rechargeable, and they will not be charged in the camera. The camera must detect the type and condition of the batteries The camera will only charge batteries when it detects the batteries are rechargeable and in good condition. New rechargeable batteries, and/or batteries than have been unused for a long time will not be recognized as good batteries. If the camera fails to charge NiMH batteries, charge them in an external charger once, then use them in the camera. If this does not correct the problem, the cells are old and/or damaged and new cells must be purchased.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Kodak Easyshare M753 Digital Camera Logo
83 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
