Question about Panasonic DMR-T2020 DVD Recorder
Duraband DVR A160
This machine is supposed to record to DVD+R/RW however I've just bought a spindle of panasonic DVD+RW 4.7g and when i insert the disc it won't recognise them and says 'disc unknown' I've tried 3 out of the 10. I wonder if my machine is broken. It will record to DVD-R sometimes and then not play them back. We have had it over a year but only just started trying to use it. Thanks
    Top Expert:
  • Panasonic Master
  • 12,962 Answers
Your unit may be fubar. OR, it is possible that your unit is not compatible with the media you are using - try different brand to draw conclusions and be guided accordingly.
Posted on Aug 27, 2017
SOURCE:
  • 28 Answers
SOURCE: DVD Recorder keps re-starting self test & will also not finalize discs.
Hi
I am surprised to hear that after you replaced the IC, machine is now dead.
I think you should check your soldering, use a magnifying glass to see if you have not broken a track or shorted something.
There are some small parts surface mounted under the board near this chip.
Next , check other soldering , especially on the chopper transformer.
Third, check if you have connected the supply output connector correctly and no pins are bent.
Good Luck
capital98
Posted on Nov 21, 2007
  • 3 Answers
SOURCE: Panasonic DMR-E50 won't recognise blank DVD's only
Bought my DMR E-50 from a boot fair for a tenner, with a broken door flap, which I repaired. It records and plays perfectly, but likes Philips and Verbatim DVD-R and Panasonic RAM for recording. As above, you can't use DVD-RW in this machine.
Posted on Jan 05, 2008
  • 39 Answers
SOURCE: Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Posted on Mar 09, 2009
TEKUSER
  • 86 Answers
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Posted on Jun 25, 2009
  • 15 Answers
SOURCE: dvd player not recognising any discs
Did You Try Taking off The Cover And Cleaning The lens With Rubbing ahocal
Posted on Jul 18, 2009
Can't record on dvd+rw disc what kind of disc do I need Thank You
There might be a firmware upgrade to allow this I would use DVD-R for full compatibility however DVD+R media from Philips is increasing in compatibility with most NON Philips and Sony players.
Feb 25, 2010 | Pioneer DVR-225 DVD Recorder
DVD/VHS Panasonic DMR ES30V.I have a "digibox which, via the Autotune facility, has input "Free to Air" stations. However,I can only record/replay digital channels 1 - 5.others e.g BBC4...
Greetings,
channels 1-5 gets signal from the digital receiver.
and the other channels are from the autotune facility connected to the TV ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Panasonic Televison & Video
Shows unformat when DVD+RW inserted
Disc need formating. While disc is in the unit press Function on the remote then arrow down to Other Function then OK button then select DVD Management then select Format disc.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't record anything....dvr won't recognize blank
Not sure, but could be as simple as switching to a dvd-rw disc. Not all recorders recognize all formats.
Mar 16, 2009 | Televison & Video
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Recording DVD-RW
Make sure the discs you are using are the same as the ones listed as compatible in the manual:
• DVD-RW ver. 1.1 / 1x / 1x to 2x, ver. 1.2 /
2x to 4x / 2x to 6x
• DVD-R ver. 2.0 /1x / 1x to 4x /
1x to 8x / 1x to 16x, ver. 2.1 / 1x to 8x / 1x
to 16x
• DVD+RW 1x to 2.4x / 1x to 4x / 3.3x to 8x
• DVD+R 1x to 2.4x / 1x to 4x / 1x to 8x / 1x
to 16x
• DVD-RAM ver. 2.0 / 2x, ver. 2.1 / 2x / 2x to
3x / 2x to 5x, ver. 2.2 / 2x / 2x to 3x / 2x to 5x
• DVD-R DL ver. 3.0 / 2x to 4x
• DVD+R DL 2.4x / 2.4x to 8x
Any brand can be used.
Jan 11, 2008 | Pioneer DVR-540HX DVD Recorder/HDD...
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
JVC DR-M100S
I have a JVC DR-MH50 DVD/HD recorder and it will only record on DVD-R or DVD-RW not DVD+R or +RW. so check your format of disk you are trying to record on it may be as simple as that.
Sep 04, 2006 | JVC DR-M100S
Panasonic DMR-T2020 DVD Recorder Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
