Mikomi ak-808u keyboard
I pressed the power button on my mikomi ak-808u and now my computer keeps powering off and wont stay on for longer than 15 min how do i stop this problem as when switches off says moniter going to sleep and wont turn back on for about a hour
  • 655 Answers
When you press your power button your system goes to sleep mode as per your system settings. To awake your system just press any key or 'Awake Key' (if its present on your keyboard), then your system will be back. No need to wait.
Thanks
Iqbal
Posted on Mar 12, 2008
SOURCE:
Acer AL2671W wont turn on
Sounds like a problem with the power supply board, typically power surges will cause fuses and capacitors to blow. If you go to tvrepairkits .com you can find a power supply kit with instructions that will allow you to repair this problem yourself. They also have coiled solder which works really well...hope this helps.
Oct 20, 2012 | Acer AL2671W 26 in. LCD Television
Etouch android wont charge
switch off.wait for 5 mins.
connect to pc or laptop with usb cable.
press & hold power button till it turns on then off.
press power button for 3 secs.it should work.
if no luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
Jun 27, 2012 | Tablets & eReaders
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
My S350 powers on when I press the power button, plays for 5-7 seconds and then powers off. What is wrong?
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Mar 19, 2010 | Grundig S350 AM/FM/SW Radio
Screen locks on start and computer does not
ur OS may be corrupted...
u need to reload OS or
try to do this...
power off the machine
switch off power supply/remove power cable from wall outlet.....remove the power cables...from PC power slot.......keep pressing the power on button in the PC for 3-4 mins....WITHOUT POWER....and/or
press the PC switch on button and release it after few seconds many times.....
Power in RAM is locked...and it's locked ur Windows DLL files....
Dec 14, 2009 | ASUS Motherboard P5GC-VM Intel 945GC...
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
My desktop doesn't recognize my keyboard
Try a different keyboard on your computer.
If that works, try your keyboard on a different computer.
If it fails, then replace the keyboard.
Sep 10, 2009 | Gateway 2520915 Keyboard
Screen wont turn on
You are going to have to ty a hard reset. Don't worry about things being deleted from the phone, as your phone auto syncs with Gmail when you enter your account info again.
To hard reset...turn the phone on while holding home and back. Follow on screen prompt.
If that doesn't work try..
Hold home and power buttons
once phone is on, open keyboard and hold alt first + w
Feb 27, 2009 | HTC G1
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Open Questions:
Computers & Internet Logo
183 people viewed this question
Ekse
Alun Cox
