Question about HP LaserJet 4si Printer
Laserjet 4Si printing trouble
The printer says it is out of paper but after filling it with more paper it does not change and it won't print.
    New Friend:
  • 159 Answers
Check the paper sensor
Posted on Mar 12, 2008
Our printer CP3505n is having trouble recognising paper size although it is standard A4 this then results in a jam
Try specifying the paper size in the drivers. When you go to file print; click on either properties or printing preferences and change the paper size to A4.
Mar 31, 2010 | HP LaserJet CP3505n Printer
HP 4SI print black page
hi,,
try to replace a different toner of your printer..
Oct 29, 2008 | HP LaserJet 4si Printer
Wont print properly
63 NEEDS SERVICE ليزر جيت 4
Jul 17, 2008 | HP LaserJet 4si Printer
HP 4si keeps jamming
This pdf might be useful, it will show you how to change the rollers. Hope this helps and let us know if you need further assistance. if the pdf does not open you can find it at this link, it will be the very first link which will open the pdf.
May 30, 2008 | HP LaserJet 4si Printer
How to cancel job in buffer
Hi Try disconnecting printer cable and printer power cable for at least 1 minute.
Should reset to default.
Good Luck!
Tinteiros (Ebay)
May 29, 2008 | HP LaserJet 4si Printer
Print from MS Word 03 & e-mail to P2015dn trouble
This could be due to incorrect paper size. We have letter as default paper size in the driver, however, A4 paper size into the application.
Please try the latest drivers (Universal Printing Driver) from www.hp.com/support/ljp2015
- Nikhil
Apr 14, 2008 | HP LaserJet P2015dn Printer
HP 4si not printing.
the printer have a problem.........
Feb 11, 2008 | Office Equipment & Supplies
Hp 4si
Your post is correct that error 53 refers to bad memory board or at times defective SIMM only. Since you have replaced them and no change, you may want to try to do a Cold Reset of the printer. This is done by powering on the printer while holding down the GO or Online button. Additionally, you may want to check/reset your NVRAM settings which can be done manually through the Service Mode.
This page lists most of the HP Laser Printer error codes. This link displays most HP LaserJets - Cold Reset Instructions.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | HP LaserJet 4si Printer
Won's print pdf files
Trouble with the HP Laserjet printed output may be solved by using the following settings (or similarly named ones): "Use raster Graphics" (instead of "Use vector graphics"). This may fix the problem of "reversed" text (white on black background) not printing, as well as other problems. "Download TrueType Fonts as bitmap soft fonts" (select "bitmap" instead of "outline" or "graphics"). This may remove the overlapping of text on the printed document. "Graphics dithering" select "coarse" or "fine" (instead of "none"). This selection may improve the quality of images contained in the document. You can find all these settings in your printer properties. Go to File, Print, click Preferences, in Printing Preferences, click one by one all the top options, and change one of the top solutions, one at the time, checking your printing output. Always check if you have the latest version of Adobe Reader Program. If not download the latest version from Adobe, it's free. Is this the first time that you have the problem? or with the same printer (HP 4si), did you were able to print PDF files in the past?
Sep 10, 2007 | HP LaserJet 4si Printer
Hp 4si laser jet prints the page with heavy dark toning on both edges right & left . Lately toning dark over the entire face of the page , makes otherwise good printing hard to read . The edge toning is...
Hi, When I've worked on printers with this problem in the past it usually comes from the high voltage power supply going bad. There is also a low voltage power supply that runs everything except the actual printing so your printer will still operate without any errors but the print quality will go bad. The high voltage power supply is located under the bottom of the printer and it's too hard to replace. I can't advertise for any place on this site, but if you type in the part that you need into a search engine and look for parts on everyone's favorite bidding web site you should find the parts you need. Good luck.
Sep 04, 2007 | HP LaserJet 4si Printer
Open Questions:
HP LaserJet 4si Printer Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
