Question about Hitachi 53FDX01B 53" Rear Projection Television
Hitcachi 53fdx01b will be watching and the picture and sound disappear , but power is still on , have had it in to be fixed but nobody can find what is wrong they say that they cannot duplicate the fault in the shop .. getting very frustrated and is getting expensive to have it looked at and the problem is never being resolved
  • prasyv Nov 26, 2008
    I have Hitachi 53fdx01b projection tv. The sound will disappear suddenly when the tv is on but you can still see the picture. All of a sudden the sound will appear again with the speaker volume at the highest level. Basically you cannot sit in the same room at a such high volume level and the tv has to be powered off for this problem to go away. It is erratic and dangerous to have kids in the room with this tv turned on. I tried connecting an external home theatre speaker system and turned off the internal tv speakers and still the problem happens. The tv was taken for repair multiple times but this problem still continues.
  • 927 Answers
Good Day;
Try: Intermittent shut off
Cause: Turn off program timer and video input sensor. redress cabling from front control panel away from blue crt-yoke-HV lead.
Good Luck, big IRISH.
Posted on Sep 08, 2008
Samsung ps42a457 picture disappeared whilst watching,sound still present
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Televison & Video
I was watching my Vizio SV470XVT1A, all of a sudden picture disappeared, the sound is fine. I switched to other channels - same problem - on picture, sound is fine. Can you help please?
Likely a shop repair---possible power supply board or others---place to begin is test all voltages into and out of the power board.............
May 14, 2012 | Televison & Video
TV repair
Good Day;
Try resetting the TV by unplugging it from the wall. Plug back in after 5 minutes. If, no fix; call for An Authorized Service Center and have come out and give you an written estimate B4 repairs, most repairs on PJTV's avg $525.00. Good Luck, big IRISH.
Aug 25, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Rear projection tv has sound but no picture for the first hour
hello
The problem is most likely the the video processor module
bad (surface mount caps.) app. 8 to 10 of them.
If you are good you can replace them.
if not replace the module.
guy9
May 24, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Sound, but no picture
Had the same thing today. Iwas playing with the auto demonstration of on screen displays. Press and hold the power button (5 seconds) on the TV. The auto display will play. Press the power button again (TV will go off). Turn power on again. you should now have the picture back
Nov 14, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Dark picture
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 13, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Picture and sound disappeared
your red crt bulb is starting to go bad. somtimes you can tap lightly on the neck of the red and the prob. usually short term will go away. if not tube replacement is necessary. this is sometime a pricey repair. but worth it! john
Sep 08, 2007 | Akai PT4298HD Rear Projection Television
LCD HITCACHI TV
obvious your power supply internal supply blown a fuse or in shut down mode due to short. I guess since you have a light the 5v supply is working but power supply makes many voltages to work your set properly probable at least 5 diffent voltages. one or more maybe shorted ...shutting down the power supply's higher voltages. it gonna take a tech to fix it. good luck
Aug 21, 2007 | Hitachi 60V500 60" Rear Projection...
Hitachi 53FDX01B 53" Rear Projection Television Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
