My pc restarts by itself and i cannot log on? it will not let me enter safe mode to restore the system, because it restarts before it gets to that point
  • Anonymous Dec 23, 2008
    my pc restart by its self and i dono know what is the problem please help
  • 4 Answers
This problem happen when the power supply failure, Ram problem and Os infomation file missing..
restart the computer and go to bios setup... check if it restarts when u r in bios it doesn't restart u r operating system is the problem.......
Posted on Mar 12, 2008
Dafina zeqiri supernova
What sort of a problem ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points.
Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Aug 24, 2013 | Computers & Internet
Tip
How to run System Restore from the Command Prompt?
Here's how:
  1. Restart your computer to boot your system in to Safe Mode.
  2. Go to Start>> Turn off computer>> Restart.
  3. When the message "Please select the operating system to start" appears, press F8.
  4. Using the arrow keys, highlight the option "Safe Mode with Command Prompt" , then press <Enter>.
    Note: If your system is a dual-boot or multi-boot system, choose the appropriate installation using the arrow keys, then press Enter.
  5. Be sure to log on to the computer with the account that has administration privileges.
  6. Enter the following in to the command prompt: %systemroot%\system32\restore\rstrui.exe
  7. Press <Enter> on your keyboard.
  8. Follow the onscreen instructions to restore your computer to an earlier state
on Jul 05, 2010 | Computers & Internet
Acer
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. if this hails to fix the problem http://support.microsoft.com/kb/307545/ restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download you could select the option start with command prompt you should be in DOS mode black screen type chkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive you should have no input while chkdsk utility is in progress any input might further damage your hard drive
Apr 06, 2013 | Acer Aspire One Zg5
My pc was restoring with tun up360,restareted,and now windows dose not work
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Jan 05, 2013 | Computers & Internet
Can u restore a emachines pc from the bio or boot logshelp
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
I believe my pc has a virus , i cant get to the windows page so i can log on and get to start, and i am not sure how to fix this problem
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option
select an earlier date when you did not have a virus
hope this helps you
Nov 03, 2011 | Dell OptiPlex GX260 PC Desktop
How to restore your windows 7 in command mode
1. Restart your system
2. When the system first boots, type F8 to bring up the boot menu
3. Select the Safe Mode with Command Prompt option
4. Log-on as administrator if needed
5. At your command prompt type %systemroot%\system32\restore\rstrui.exe
6. Hit Enter
6. This will open the system restore wizard...
Sep 28, 2010 | Computers & Internet
My window xp doesn't get restore ?
The System Restore feature will work only if the Windows System Restore feature is enabled.
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
The System Restore should work from SafeMode
Jun 30, 2010 | Acer Aspire One D2501413 Notebook
Compaq Presario SR1000 won't boot up completely :(
Hi Thanks for your question
I would suggest to enter "safe mode" and then do system restore again. To do this you need to follow these steps.
1.Turn your PC on and press F8 on start up. This should take you to the screen asking what you want to do. 2. Choose safe mode from the list and press enter. 3. Once safe mode loads you should be asked if you want to restore your system to previous state. Just press no to run system restore and follow steps (you already know how to do this)
Shutting your computer down without closing operation system properly may cause start up issues like this one.
I hope this helps you. Good luck
May 26, 2010 | Compaq Presario SR1000T (568657) PC...
When I log into my computer it says "loading personal settings" then immediatly logs back off? what do I need to do to fix it without reformatting
Try to boot your windows to SAFE MODE use the steps below:
How to start System Restore by using the Command prompt loadTOCNode(2, 'moreinformation'); Note You must be logged on to Windows with a user account that is a computer administrator to complete these steps. To verify that you are logged on to Windows with a user account that is a computer administrator, visit the following Microsoft Web site: http://support.microsoft.com/gp/admin (http://support.microsoft.com/gp/admin) If a new program has made your computer behave unpredictably, and uninstalling the new program did not help, you can try the Windows XP System Restore tool.
Important If you have not previously set a restore point in System Restore, you cannot restore your computer to a previous state. If you are not sure, or if you have not previously set a restore point, contact Support.
To start System Restore using the Command prompt, follow these steps:
NOTE: IF THE PROBLEM STILL PERSIST AFTER SYSTEM RESTORE OR YOU HAVE NO RESTORE POINTS AVAILABLE. YOU MIGHT NEED TO REFORMAT YOUR PC.
Thanks.Cheers!
Apr 21, 2010 | Dell Latitude 110L Notebook
Computers & Internet Logo
409 people viewed this question
Alun Cox
David Payne
David Payne
