Question about Cuisinart BFP-703 SmartPower Work Top Blender
My Cuisinart blender start leaking after a few months of use.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
Here is a list of things to check for:
1. Make sure the blender base (black plastic) is tight to the jar.
2. Make sure you have installed the rubber washer between the blender blade assembly and the jar.
3. Make sure your rubber washer is free from any crud that may have accumulated and dried on. You may have to soak the washer and gently scrub with a scrubber sponge. If it's really cruddy you may have to repeat as necessary.
4. Make sure you have not caught any water (or other liquid) when filling it between the base and the jar. When you pour out the contents it will appear as if it is leaking.
Posted on Oct 12, 2017
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
Posted on Apr 30, 2009
SOURCE: Cuisinart BFP-703CH Chrome Blender does not start
Where do I find the vase bottom gear for a cuisinart model 703ch?
Posted on Oct 29, 2009
SOURCE: how to operate the cuisinart dual blender?
I used the blades in many differents ways until I found out the correct way.
Thank you for your help,
Mrs. Rivera
Posted on Nov 01, 2009
  • 4102 Answers
SOURCE: cuisinart blender cb600sa blade holder
Hi, it does happen from time to time but the chances are been as your buying a new part you should be ok, alot of people dont bother buying a new part and end up buying a new machine, most people never have a problem with it so the chances are the part that has broke may have had a flaw in it as this is not a very common fault, it does tend to happen more if people stick it in dishwasher to clean it or wash it in boiling water should it need washing so if it needs cleaning just use warm water and not hot as hot water causes the plastic to expand and shrink when it cools and this causes little fractures in the plastic then you get the problem your now having.
so to answer your question it shouldnt happen again you either had a part that had a flaw in it or you have washed it using water that is to hot and this has caused it to go brittle.
let me know how you get on or if you need further assistance ok
Posted on Feb 23, 2011
Blender Base is stuck and won't budge
Please use the WD-40 and let by 1 hours, and ready.
God bless you
Nov 06, 2013 | Cuisinart SPB-7CH-LR Blender Jar Base
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Cuisinart model # SPB-6 (tx) leaking when unit is together, seal is in place, still leaking. Unit is not damaged, please advise.
Check if leaking at the bearing for the blade.
If the bearing has worn, dis-assemble and coat shaft with food-safe grease and re-assemble. Also coat the seals with the grease.
Sep 09, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Leaking cuisinart smart power 7-speed electronic blender
Apr 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Problems w/ my cuisinart smart blender
Here is the link to the manual; http://www.cuisinart.com/share/man/9_man.pdf Page 4 should tell you what you need. Hope this helps :)
Dec 05, 2006 | Cuisinart CB-18 SmartPower Basics Work Top...
Cuisinart BFP-703 SmartPower Work Top Blender Logo
625 people viewed this question
Top Cuisinart Blenders Experts
eyecam
Gil Shultz
ray gallant
ray gallant
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
