Question about Cameras
Formating your sandisk
How do you formate a sandisk for your camera? When you don't have a cord for camera to pc, & you don't have instructions from your sandisk package. I just bought a sandisk for my digital camera, & it's telling me that my disk needs to be formated.
Yeah i have a PhotoSmart camera and it wont format but i been looking at every website to learn Formating my SanDisk to my camera how do you?
Posted on Jun 12, 2008
Why does new card say it needs formating
This is not unusual. There are many different formats that could be put on your SanDisk, but you must be sure to put the correct one that is compatible with your camera. Consult your Kodak manual or phone a Kodak agency. Common formats are FAT16, FAT32, NTFS, EXT3, but there are many others. A lot of cameras that I have used use FAT32. If the SanDisk has the wrong format for your camera or a corrupt format, you will get this error message.
Most cameras can do the formatting required for the SanDisk, Again check manual or Agency for HOW TO. If the camera cant, you can format it on a PC, a Tablet, or a Laptop provided you know what format your camera requires. It is not difficult. Good Luck.
Aug 04, 2014 | SanDisk 8gb Memory Card For Kodak...
SD card format ng no card
  • 1 Insert your SanDisk 8GB memory card into a card reader connected to your computer.
  • 2 Double-click "Macintosh HD" on your desktop.
  • 3 Click on the "Applications" folder, then the "Utilities" folder.
    4 Double-click "Disk Utility". Look on the left side to locate the drive that says "SanDisk.
    5 Select the capacity of the drive on the left side of the window. The capacity will state "8GB" or "8,388,608 kilobytes." Click on the "Erase" tab to format the memory card. When you see "SanDisk" listed as the device's name, the capacity will be located above. You need to select the capacity and not the device.
    6 Select the appropriate "Volume Format." Under the "Volume Format" button, select the format you wish to use. Select "Mac OS Extended" if the SanDisk 8GB will only be used on Macs, or "MS-DOS (FAT)" if you will share the card between a Mac and PC. Select "Erase" to complete the format of your SanDisk 8GB memory card.
    Mar 07, 2012 | Panasonic AG-HVX200A Mini DV Camcorder
    I transferred my data from the micro sd card to my pc & formatted the micro sd card.but after re-transferring the data,mainly images, it is not being displayed.it seems the card is hang up.
    Where do you use your SD card? If you are using it for a digital camera, you should format it using your camera. Don't format it using your computer.
    Sep 22, 2011 | SanDisk 2GB microSD Memory Card
    I have a 8 GB sandisk sdhc card that up until yesterday worked in both my computer & camera. Now it errors and is unreadable and it says to format. Any program in which I can get the photos off of it...
    When you pull your card out of your pc do you eject it or do you just pull it out, sometimes a card can become unreadable if its pulled out before its finished writing. Unfortunately I don't know of any program that can recover those files.
    Jun 02, 2011 | SanDisk 2GB microSD Memory Card
    Fat is corrupted please device connect to a pc recover the fat
    Plug this into a computer and if it shows up as a device under My computer; right click on it and choose FORMAT.
    You can also try these steps here outlined by Sandisk: http://kb.sandisk.com/app/answers/detail/a_id/270/kw/format This is to format it without a computer.
    Here are the Mac instructions: http://kb.sandisk.com/app/answers/detail/a_id/203/kw/format%20sansa
    **Note, you will lose all your data from your MP3 player.
    Mar 03, 2011 | SanDisk Sansa Fuze MP3 Player
    I bought a SanDisk micro SDmicroSDHC adapter my camera cannot read it says needs formated have a kodakcamera
    if your camera does not contain a format feature in the firmware, you must use a PC with a card reader and use it to format the SD card. You can do this by going to my computer and right clicking on the removable media then the format option.
    Dec 24, 2010 | SanDisk 4GB microSD High Capacity Memory...
    I have recently purchased a DMC-G1K camera. I have read the operating instruction manuel and cannot understand how to format an SD card. (page 34 in the operating instruction manuel. Where is this...
    Just incase, i wanted to point out this camera may not support SDHC cards. what this means is you cannot use any SD card over 2GB in size unless there is an "SDHC" logo on the camera. "says the manual" And one other real quick thing to check is the lock/unlock switch on the SD card make sure it's in the unlock position On page 24 there is a little more info on formating the card.if the card is currently formated in NTSC the camera wont be able to read it correctly From your PC if the card is less than 2GB you want to format it in fat12 or fat16 but if it is any size larger than 2GB you have to use fat32. on your PC open "my computer" then plug the card into the PC via Card reader or directly plugged into the camera and you will see a new drive pop up in your "my computer" window. Right click on it and select "format" and it will bring up a window that allows you to change formatting options. usually the correct options are already selected for the card size so just click the "format" button it will prompt you that everything will be deleted. once formated put it in the camera and go to the Format option again and select it. you will be prompted again that everything will be deleted select "continue format" it should take less than 10 seconds depending on the size of the card I think the reason they dont elaborate on the formating of the card is because when you click on "format" in the settings menu there isnt much that happens after that other than the prompt about everything being deleted Good luck hope i helped
    Aug 12, 2010 | Cameras
    I have a SanDisk card 2GB that was erased when I dropped my old camera. Can I use this disk in my new Polaroid camera (a544) and will it have to format the memory card? If so, how? I didn't get a user's...
    Yes you will have to format it in your new camera. In most cameras, just go into the menu and scroll to "format" and follow the on-screen instructions.
    Dec 04, 2009 | Cameras
    Tell me how to format my sandisk camera card and erase the photos
    your cam come's with data cord or USB BUS hub drive which can be easily connected to an y pc or note book pc or laptop but first see that you install the driver & software on your system for proper working or function of cam on the PC or Laptop after installing connect the cam to USB cable then it will automatically show each & every content on your PC or Laptop & their is the option of deleting every thing you need to erase so till then see your hope that it help you out ......!
    Sep 29, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
    Cameras Logo
    96 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
