Question about Sanyo DWM400 DVD Player
My DVD door will not open. How do I get it open?
  • 3 more comments
  • Anonymous Mar 29, 2008
    Mine neither. Put a movie in, never got to watch it. Unplugged it, pushed all kinds of buttons, nothing in the owner's manual. Please help! It's "The Last Samurai"!
  • Anonymous May 19, 2008
    had a movie in for a few weeks and the door will not open now help
  • Anonymous Jun 29, 2008
    Not only will my DVD door not open, I can't get the darn thing to shut off either! Shall I just get a new one?
  • mmaggiemagic Jan 15, 2009
    Same kind of problems. Sometimes nothing works, won't come on, won't release the disc othertimes, I need to return this dvd to the library by 1-20-09 and this is thur.evening already let me know
  • jerday May 11, 2010
    how do i open the door? the machine will not turn off either.
MY DVD PLAYER WILL NOT OPEN. IT SAYS THAT THERE IS A DVD INSIDE, BUT I CAN'T GET IT OUT. IT WILL NOT SHOT OFF EITHER.
Posted on Nov 04, 2008
Hi im a deaf guy need speak live person about plm sanyo dvd there is ni cd in it but once i turn on then light goes off so really i need talk person live thru relay interpretor so pls give me ph nbr since i use 800 813 3435 keeps disconnecting so need speak in person for my situation call me at 866 662 1963 pls im frusated already thks tom
Posted on Jan 28, 2009
You have to open up your DVD player and unscrew the assembly that holds the DVD. Underneath the assembly is a white wheel. turn that counter clockwise, and it will manually release your CD.
Posted on May 10, 2008
My DVD is on all the time and the door well not.
Posted on Sep 14, 2008
The DVD drive does not open
There should be a tiny hole near door. Take a unfolded paper clipped push it inside.may have to push door to open
Jan 15, 2018 | The Computers & Internet
Disc door will not open
hello,
the reason the disc door would not come out is because there is a problem withe the mechanism that opens the door.
to fix this,
1. you unscrew the dvd player,
2. take off the cover,
3. plug the dvd and press open to see if the door would open, then you will see where it is getting stuck,
4. replace the mechanism that is controlling the disc door, and press open to see if the door will open.
5. once it is able to open up, you can screw back the cover.
Jun 02, 2010 | Memorex MVD2040 DVD Player
Dvd player wont open
try a paper clip opened and put on dvd door hole (small hole), and push slowly the paperclip inside and realease the dvd door to open, normaly is a defective dvd laser mec. and needs to be replaced. send to repair
Jan 03, 2010 | Panasonic DVD-RV26 DVD Player
Dvd door allways hard to open now will not open at
Most likely either the door motor is worn out or it needs to be pryed open with a paper clip, pulled back all the way, and then hit eject button to see if it retracts.
Nov 12, 2009 | GoVideo Go Video DVD/VCR Combo
DVD Drive door will not always open. No obstructions. DVD Drive light flashes, but door will not open. Is ther some software conflict?
The door drive motor may be frozen.
  1. Shut down the computer and unplug it.
  2. Open the computer casing to access the DVD drive from inside.
  3. Disconnect the cable on the DVD drive leaving only the power supply connected to it.
  4. Turn on the computer.
  5. Push the OPEN/CLOSE button on the DVD drive. If it does not open, the drive is broken or the door drive motor is defective. If it opens, push the button repeatedly to open and close the door repeatedly to release any frozen part.
  6. If the door does not stuck anymore, shut down the computer.
  7. Reconnect the cable and turn on the computer.
Oct 30, 2009 | Sony Computers & Internet
Installed a new dvd burner for Hp computer. Running Windows XP. Installed Nero 8 Software. Door doesn't always open when button is pushed or after burning a dvd. Computer also has another cd/dvd drive....
it has to do with a new hardware installation process....check IDE cable that they are correctly connected and try to check system setup so that the CMOS identifies both, primary & secondary devices....if not, u need to install a driver for the newly installed one....
Oct 05, 2009 | Computers & Internet
A dvd is stuck in the dvd player
something stuck our dvd-door.
1. open the dvd
2. remove the thing that block our dvd door (like paper, tissue, paperclip)
or
maybe our dvd mechanic door had block by dust
-----basicaly, clean it.
in my case. I knock the upper top of the dvd door hard (but not by hammer, by my hand) while i push open button (the menu open/'open' word is display at the menu). if u're lucky, the dvd door will open
Sep 29, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
Dvd door will not open
My trutech DVD player door would not open.
Jul 08, 2008 | Panasonic DMR-ES40VS DVD Recorder/VCR
My DVD Player does not reject a DVD. It gets stuck.
I had been closing the door at the DVD slot manually. I found that if I closed the DVD door with the close button, and then opened it with the open button, it no longer got stuck.
Jul 04, 2008 | Philips Televison & Video
Sanyo DWM400 DVD Player Logo
421 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
