Tv remote codes
Cannot turn tv to video no codes or remote
  • 3 more comments
  • b luv Mar 11, 2008
    please help me
  • granny P Apr 22, 2008
    I have a ProScan ps27115 27' tv. I want to hook up DVD and game system for grandkids. There is no tv video button and I only have an RCA universal remote. It does not have video tv option. There are jacks in back for adding components and it even has a place for S video. Please help.....
  • mileyboomer May 05, 2008
    factory remote to ds31520 sanyo tv will not work since batteries were out too long. need code for remote
  • drw1251928 Oct 17, 2008
    SPECIAL CODE FOR THIS PRODUCT
  • priyabb21 Oct 24, 2008
Check av button&av voltage from function ic
Posted on Mar 12, 2008
Need remote code list for my element tv
Element TV remote codes
Codes to operate your Element TV:
Newer codes 5 digit:
11886
10178
11687
12183
Older codes 3 digit:
046
005
028
043
048
076
096
155
004
051
127
151
153
154
231
236
238
247
252
168
121
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your Element TV can be controlled with a universal remote and work with RCA remotes, Comcast, DirecTV, Charter, and more.
Jan 29, 2018 | Element Televison & Video
Need help programing my vizio tv to a blackweb universal remote
You don't program the TV to the remote, you program the remote to the TV
Find the Vizio codes on the paperwork that comes with the remote. There will probably be several codes. You need to try each one. Before programming turn the TV on manually. After put in each code try turning the TV off with the remote. Then try to turn back on and try volume up If OK everything else should work. Occasionally 2 different codes will turn off the TV in the test above. Use the one that allows the most functions to work
FINALLY not every "Blackweb" remote will control every TV You may need to get another one that specifically says it can control Vizio.
Jan 11, 2018 | Vizio Televison & Video
Program my remote to my tv
FINALLY not every universal remote will control every TV You may need to get another one that specifically says it can control Vizio.
Jan 11, 2018 | Televison & Video
I have a Sharp GA535WJSA remote , need codes for OLEVIA , LCD Multi-media Display MODEL LT27HVX
Remote codes for OLEVIA TVs: 1610 11610 12272 11240 11331 11144 11858.
OLEVIA multi-brand remote codes for TV's.
1 - Turn on TV.
2 - Press and hold the TV key and enter the codes for your brand.
3 - If your TV turned off then you entered the right code and setup is complete.
(If not repeat with a different code.)
Dec 19, 2017 | Sharp Televison & Video
Code for my coby TV with an rca remote
Did the television come with a code?
Jun 27, 2017 | RCA Televison & Video
Can I program a Samsung AR 6052 remote to work television
Press the MODE button to make the TV
indicator on the remote control flash.
2 Press POWER button to turn on the TV.
3 Point the remote control toward the TV.
4 While holding down POWER, enter the code
corresponding to your brand of TV.
• If the code matches the TV's code, the TV will be turned off.
• If there is more than one code listed for your TV in the table,
enter one at a time to determine which code works.
Example: For a Samsung TV
While holding down POWER, use the number buttons to enter 00,
01, 02, 03, 04, and 05.
• You can use the POWER, TV/VIDEO, VOLUME, CHANNEL, and
Numeric buttons (0~9).
5 Pont the remote control toward the TV and press
POWER. If the TV turns off or on, the setting is
complete.
Oct 04, 2015 | Samsung Televison & Video
Comcast remote codes for apex digital dt502
Brand: Apex Digital
Most likely code: 10765
Others to try:
10748, 10879, 10767, 10890, 11991, 10889
To program your remote:
  1. Turn on your TV
  2. Using the code list, find the first five digit code that is listed next to the name brand of the TV that is to be programmed
  3. On the Comcast remote, press and release the TV key
  4. On the Comcast remote, press and hold the SETUP key until the TV mode key blinks twice then release the SETUP key
  5. On the Comcast remote, enter the first listed five digit code
    Note: If this number is entered correctly and is an accepted TV code, the TV mode key will blink twice. If the code is entered incorrectly or is not an accepted TV code, the TV mode key displays one long blink and exits programming mode
  6. Aim the remote control at the TV and press the POWER key once
  7. The TV should turn OFF - if it did not turn off, repeat steps 1-6 with the next TV code listed, until a working code is found
Nov 03, 2013 | Apex Digital DT502
Need the remote code for controling a daewoo tv
Hi
The remote code for controlling your tv can be found in your remote's instruction booklet.
1. Turn on your TV,press and hold the CODE search button until the indicator light illuminates.
2. Enter the code using the number buttons,The indicator light should turn off
3. Then your tv should respond immediately to show that the code is correct.
THANK YOU
Jul 13, 2010 | GoVideo Go Video DVD/VCR Combo
Need codes for programing a hitachi tv
The codes are, 0145,1145,...Step 1. Turn the TV on. 2. Press the TV button. 3. Press and hold the SET button until the LED blinks twice, then release. 4. Enter one of the four digit codes, the LED will blink twice. 5. Aim the remote at the TV and press the POWER button, if your remote does not have a power button, press PLAY, the TV should turn off, if not, try steps 1-5 again using a different code....hope this was helpful...
May 22, 2010 | One For All URC-3021 Remote Control
Sanyo DS31520 TV
I am relentless when it comes to problems like this. I had the same problem with my TV being stuck in video mode. I found out that there is a reset button......It's on the @*&#^&^ original remote!!!!! So I tried programming my Time Warner Scientific Atlanta AT8550 remote for the TV to see if the "video source" button would work. IT WORKED!!!! You have to use code 1062. Instructions are:
1. Turn the TV on.
2. Press and hold select and the TV keys until the lights blink twice.
3. Enter 1062. All mode keys blink twice to indicate that the code was accepted.
4. Point the remote at the TV and press power to test the TV.
5. You can then successfully use the "Video Source" button on the bottom left of the remote to change the video mode. VOILA!!!
If you don't have a Scientific Atlanta AT8550 remote, I'm sure you know someone that does. They're everywhere!
Feb 10, 2008 | Sanyo DS31520 31" TV
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
