FixYa.com
Tags:
Printers
Generic problem for all Printers
Toner not recognized
posted by ivanator on Mar 11, 2008
printer does not recognize a compatible cartridge.if I powers down the printer and then power it back up the printer will print my job on and then does not longer recognize it again??
Comment by ivanator, posted on Mar 12, 2008
I have cleaned the contacts this is a new Compatible Toner. I reinsert the OEM toner the printer will recognize it, however with this newer toner it does not. I don’t see a chip so what else could it be?
The printer is an Lexmark Optra S 1855
Thanks,
The Cartridge I am replacing with is a Compatible Toner . as I compare the OEM with the Compatible they look identical the Contacts and all
Yes, if I power the printer off the toner will be recognized and the printer will print whatever I have in Queue. Then once it has printed I get an error saying “Change Cartridge”
By the way this is a Toner Cartridge and not Ink
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
mcuyg
Rank:Wiz Wiz
Rating: 78%, 47 votes
clean the contact point of your ink cartidge.
Comment by mcuyg, posted on Mar 12, 2008
if the toner you replace is an original? wat is the model of your printer?
did u remove the seal of your new toner b4 you insert in printer?
just remove your ink cartrigde check the inside contact point of your cartridge holder clean it with cotton, then go to diagnostic tools of your printer software run the cartrigde aligne and clean cartridge.
you need to call a technician to check that, maybe inside of your printer need to clean thers a possible inside that thers many powder been stuck inside your printer.
Rating Locked! (?) ivanator has rated this solution as Thanks for Trying
Solution #2
posted on Apr 21, 2008
Not Rated (0)
lennerd87878
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
throw away Lexmark prn. buy other brand.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP OfficeJet 6210 All-In-One InkJet Printer HP Color LaserJet 2600n Printer HP Photosmart D7260 Printer HP PSC 2110 All-In-One InkJet Printer HP DeskJet 5150 InkJet Printer HP DeskJet 9800 InkJet Printer HP Photosmart C6100 All-In-One Printer
Can you Help with these Printers problems?
Printers
error message5100
error message5100 Answer This...
Printers
need an installation disk for
need an installation disk for... Answer This...
Printers
Have Ultra Hi-Definition RX595
Have Ultra Hi-Definition RX595... Answer This...
Printers
can't get my pixma 160
can't get my pixma 160 printer... Answer This...
Lexmark Z600 InkJet Printer
same problem
connected,, but wont work,,,... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
