My shuttle XPC SK41G shuts down when using it it dose not do it all the time sometimes when i put a programe inthe cd rom it gose so far then shutts down all i can do remove the power supply and restart the computer can you help me thanks
  • 1 more comment
  • geckoman Mar 11, 2008
    hi i dont get any message on windows the power on the computer just shuts down and you cant restart unless you take out the power supply and plug it back in it then starts the fan on the shuttle is going ok not stoping the cpu is about 56c and the sytem is 50c so i dont no what the temp should be
    regrards peter
    hi i have checked in my shuttle i have a cooling piped unint made by shuttle and hats the onl fan except the fan on the power supply
    no i only have one fan unit was it on the cpu its specal unit supplied but shuttle its a piped heatsinc
  • 19,396 Answers
If Windows shuts down itself giving you message'windows is closing down' etc. then it is a windows problem, and probably you will need to reinstall windows.
If power goes down suddenly then most common cause is power adapter, you should test it, or try a different power supply.
Another commn cause for sudden shutdown is overheating. Check your cpu temperature and check that fan is working.
Posted on Mar 11, 2008
  • 4 more comments
  • Ginko
    Ginko Mar 11, 2008
    Here you can download a program to monitor your cpu temperature.
    regards
  • Ginko
    Ginko Mar 11, 2008
    click on softpedia secure download or external mirror to download speedfan
  • Ginko
    Ginko Mar 11, 2008
    Well, the fan speeds up when tempeature ranges from 40°C to 52°C, if you have 50 all the time then there may be a problem with temperature, check tha the fan and plate are well in place. If the temp results fine then is probably the power supply, in less frequent cases a faulty motherboard or internal device may cause shutdown.
  • Ginko
    Ginko Mar 11, 2008
    Here is some interesting stuff from shuttle, including a document on checking temperature from bios.
  • Ginko
    Ginko Mar 11, 2008
    Try spedfan and monitor temperature for a while, when idle and when you work, the utility shows you if temp is too high. If temp is ok then PSU is frequent cause , To test the rest I'd need to put my hands on the shuttle
  • Ginko
    Ginko Mar 11, 2008
    The shuttle when not busy should work below 48 C the critical temperature is 56 when 56 shuts down , monitor temp. while you work, see if before turning off temp was near to warning level, so that you know if it is overheating.
  • 4,889 Answers
  • 4 more comments
  • eagle338
    eagle338 Mar 11, 2008
    It clearly indicates an over heating problem.. Check the heatsink and see if its seated properly.. Also check if all the three coolant fans are working properly.. Check this and post back..
  • eagle338
    You can possibly check the cpufan speed in your BIOS.. I strongly feel its an overheating issue because you are able to start it after 20 mins(after it cools down)
  • eagle338
    Also the normal temperature for most modern PCs is, 35-50 °C
    Warning temperature is 50°C.
  • eagle338
    oh.. you mean only one coolant fan was running?
  • eagle338
    The normal rpm of the coolant fan varies from 2100 RPM-2700 RPM
  • eagle338
    Well then i guess its time to get a new heat sink..Thats the only reson i can see for the unit heating up so fast despite of the fan running at the normal speed. Looks like its damaged and needs replacement.. Your system is getting alarmingly close to the danger zone of 60°C. Try not to switch on the system till you replace the heat sink..
    PS: This will be covered under warranty (assuming its still under warranty..)
  • 37 Answers
I had a similar problem with one of my computers at home. It actually turned out to be a virus on the computer, what I did to fix it was, called the customer support for my system with happened to be a dell and through tedious work they talked me through how to fix it. But it sounds to me like your problem is a virus, possibly a trojan horse that got in there somehow. You want to be careful though because I was told that each time the computer shuts off the virus spreads.
Good Luck,
Chris
After i changed my power supply (due to short circuit), i cant hear any sounds in my audio. i checked to device manager but no problem in my audio controller, no problem in speaker also. i formatted my PC...
Hello Roydgreat, short circuits unfortunately can cause more damage than just the power supply. There may be a chance that it has damaged your sound card or a portion of it. If you can borrow a friends sound card you could double check to see if that is the issue. They aren't very expensive if you were considering getting a new sound card to install into your computer. It's not a guarantee that the sound card was damaged in the process but it is a possibility and if you can grab a friends audio card and install the drivers for it and then see if it works, it'd probably be the easiest way to test this theory. Hopefully this helps, have a great day Roy!
May 15, 2011 | Shuttle XPC SK41G (XPC-SK41G-SHUT) PC...
Non functioning CD/DVD drive on Shuttle SN41G2 PC
Does Windows still detect the drive? If you were to go into My Computer or Computer (depending on the version of Windows) are you able to see the drive?
Place a DVD or CD (Software or Multimedia) that you have tested on a different system and then use Windows Explorer to browse the drive.
To launch Explorer right click on My Computer (Vista/Win 7: Computer) and then select explorer. Select the DVD drive and see if you are able to view the contents.
If Windows still detects the drive and you are unable to view the contents of a tested DVD or CD then it would most likely be the drive.
Apr 13, 2010 | Shuttle XPC SN41G2 (XPC-SN41G2-SHUT) PC...
Location of cmos in shuttle
the CMOS battery is on the motherboard. it is the size of a quarter dollar, silver is color and it look almost the same like the watch battery
Dec 11, 2009 | Shuttle XPC SN41G2 (XPC-SN41G2-SHUT) PC...
Shuttle shut down problem
go to BioS set up..
see to it if the CD Rom Drive has been detected..
if Not,,, try to connect again
...back to BIOS SET up
if it detect..save it...
then boot the computer until it pop up the windows environment..
double click "my computer " icon
if CD ROM has there..
your computer normally shut down..
Oct 19, 2009 | Shuttle XPC PC Desktop
When i prest the reset button it dint do nothing when i turn on the power nothing happens the monitor is black
The rest button Will Only Work when the computers Running.
When You Say " Nothing Happens " What do you Mean ????
Are There Any lights on the Front Panel ???
Can You Hear Any Sound Or noise ????
Does The Computer produce Any Beeps ???? if So How Many ????
Have you Plugged It In ????
Has The Fuse In The plug Blown ?????
How do you expect suggestions, From such a Simple Question ???
Mike @ Compurepair.
Who Thinks Fixya, should Vet the questions and the Questioners, Rather Than The Experts :-)
Aug 19, 2009 | Shuttle XPC SK41G (XPC-SK41G-SHUT) PC...
What happens if i accidently prest the reset button
it will reset the Computer ?
which will shut Down, And restart.
Mike @ compurepair.
Shuttle xpc suddenly turns itself off
Could be overheating.
Suggest you check the Processor Fan is working, usually you can hear it.
If it stays on longer when starting from cold then that could indicate fan trouble.
Most PCs have onboard sensors which can be monitored by programs like Speedfan see http://www.almico.com/sfdownload.php then click on SpeedFan 4.39
Good Luck
Jul 28, 2009 | Shuttle SG33G5 (XPC-SG33G5) Barebone
Computers & Internet Logo
302 people viewed this question
David Payne
David Payne
