Question about Sharp EL-531VB Calculator
Standard Deviation I'm not sure how to calculate the standard deviation on this calculator.
  • 1 more comment
  • steve135 Sep 22, 2008
    i DONT UNDERSTAND THE MANUAL SO CAN ANY1 TEL ME HOW TO FIND STD DEVIATION
  • Anonymous Nov 22, 2008
    I have a problem with finding the standard deviation (Sx) on EL-531WH. It says to use "data" after having set mode to "stat", but the only "data" I can find is silver about ' ) ' and it doesn't seem to work.
  • gemzy3 Jan 18, 2009
    how do you do this?
  • Sharp Master
  • 7,993 Answers
You must first enter the data you are doing statistics on.
After you finish entering the data, do as the figure below describes.
Hope it helps.
Posted on Sep 20, 2009
Where is s on the ti-30xa calculator
If you mean the standard deviation, there are two shifted keys on the third row marked with a lower-case Greek sigma. sigma_xn is the population standard deviation and sigma_xn-1 is the sample standard deviation.
Nov 12, 2013 | Texas Instruments TI-30XA Calculator
How do I use the standard deviation function?
  1. Calculator must be in SD mode (standard deviation mode) :Press [MODE] [.]
  2. However, if [FIX] or [SCI] appears on display you must press [MODE][9] first.
  3. Data input always starts with [SHIFT][SAC], to clear the registers of old data.
  4. Type a number and press the [DATA] key, it is the [M+] key at the bottom right of keypad.
Press [SHIFT] [9] (sigma n-1) to get sample standard deviation
Press [SHIFT][8] (sigma n] for the population standard deviation
Press [SHIFT] [7] (xbar) for the mean
Press [SHIFT] [6] (n) for the number of data entries
Press [SHIFT] [5] (capital sigma x) for the sum of values
Press [SHIFT] [4] (capital sigma x to y) for the sum of squares of the values
For additional information you might consider taking a look at the calculator manual.
Apr 30, 2010 | Casio FX-260 Calculator
Does this calculator comes with a standard deviation or population standard deviation button
Yes. The sample standard deviation is 2nd [sigma x n-1] and the population standard deviation is 2nd [sigma x n].
Apr 02, 2010 | Texas Instruments TI-30XA Calculator
Is there a formula for standard deviation problems
Of course there are formulas for those calculations. You find them in books on statistics. Do not worry, the calculator has been programmed to use them. All you have to do is learn how to get the calculator to give you the results.
If you still want to see the formulas with your very eyes, I suggest you go to the local library, ask a math teacher, an accountant, or launch a Google search for them.
Hope it helps.
Aug 05, 2009 | Casio fx-300ES Calculator
Standard Deviation
Press 2ND [CSR] to clear the stat data.
For each data point, enter the number followed by SIGMA+
If you have grouped data, enter the number followed by 2ND [FRQ] followed by the frequency then SIGMA+
Press 2ND [sigma x n] for the population standard deviation or 2ND [sigma x n-1] for the sample standard deviation.
May 25, 2009 | Texas Instruments TI-30X-IISTK Scientific...
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
Oct 05, 2008 | Casio FX-115ES Scientific Calculator
Standard Deviation
I want to calculate a standard deviation on BA II plus
Apr 23, 2008 | Texas Instruments BA-II Plus Calculator
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Nov 15, 2007 | Texas Instruments TI-86 Calculator
Standard deviation
StdDev( {1,2,3,4,5,6,7,8,9,10} )
with your list inside the curly braces.
Nov 10, 2007 | Texas Instruments TI-30 XIIS Calculator
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Sep 07, 2006 | Casio FX-7400G Plus Calculator
Sharp EL-531VB Calculator Logo
846 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
