Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Processor upgrade i want to upgrade the processor on my dell optiplex gx1 400mtbr+ to a faster one is it possible if so which one can i use and how fast can i go
  • Matthew Haynie
    Matthew Haynie May 11, 2010
    Well, which type of processor are you currently using, and what is its speed?
    President:
  • 778 Answers
Foluwa,
You can go here: http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen&~tab=2, and enter your service tag number (would have done it for you if it was posted) and you'll get your systems configuration and should be able to determine *********** Board, Socket, and max Processor that it will support.
Good luck.
Posted on Mar 16, 2008
Best processor for a dell optiplex gx260
whats the current processor installed? it can possible handle P4 procs up to 2.0 to 2.4Ghz..
Feb 14, 2010 | Dell OptiPlex GX260 PC Desktop
Optiplex gx280 processor upgrade
eykraus,
I have some experience in upgrading your Dell.
If this gx280 was my computer and want to upgrade I'll only go to 3.0 but you need to upgrade you bios to support the new upgrade. You could also upgrade the memory as well. Put the power supply you have in so you can conserve.
Sep 05, 2009 | Dell Optiplex GX280 (99301) Motherboard
Can I upgrade a dell 900mhz p3 processor
Not really [ only possible might be to a faster P3 cpu]. Those motherboards are so old it would be cheaper to just buy a new system as Dell cases & power supplies, etc for that old a computer are all proprietary and would take major modification to upgrade to a new motherboard, ram, cpu and such. Hope this helps.
Jul 17, 2009 | Dell (6d514), 900 MHz Processor
Want to upgrade cpu
Yes, any Pentium 4 CPU should do for your upgrade.
Here is the manual for your particular model for as well
http://support.dell.com/support/edocs/systems/opgx240/en/ug/specs.htm#1106346
Please Rate Me if this Helps
Apr 15, 2009 | Dell Optiplex GX240 SFF Refurbished Small...
I want upgrade
hello, i would install the cpu you wish to use, then see how it runs. and then do a bios update. this may work,if not the motherboard may not be compatible with the cpu upgrade, (propriatory equipment sometimes does not allow such upgrades) like hit or miss! i hope this info helps,and you get the dell to accept the faster cpu. good luck! glen
Feb 15, 2009 | Dell Pentium 3, 500 MHz Pentium III-M...
DELL OPTIPLEX GX150 Upgrade to Intel Pentium 4
Upgrading to a PIII to a PIV usually requires a new motherboard. Especially with that kind of speed you want to go to. The processor uses a different socket set and requires a different motherboard to absorb twice as much heat as you are putting out of the computer right now (the faster the processor, the more heat is released). Power supply should be around 400 watts as well because you will be needing a different cooling system as well.
Jan 18, 2009 | Dell OptiPlex GX150 PC Desktop
DELL OPTIPLEX 160L
It could be that the processor your trying to upgrade with is bad, try another CPU to make sure.
Nov 19, 2008 | Dell OptiPlex GX520 PC Desktop
Dell
Well mishel, its a little yes, a little no. yes you can upgrade your processor, but not all the way to 4.3ghz, with whats in your computer now, the only processors that will fit are of socket 478, its one of Intel's older chips. There faster chips to date clock in around 3.0-3.4, and that's with four cores, if you need a faster chip, you need to get another motherboard, and with your case that can be a problem. The best processor I could find was 3.0ghz and under $100 on newegg.com. Good Luck
CoDoc
Dec 11, 2007 | Dell Pentium 4, 2.26 GHz (1W391)
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
