Question about Frigidaire FRS26F4C Side by Side Refrigerator
No water in ice maker
I have a frigidaire that quit making ice. I noticed that there is no water in the freeze tray so I reversed the solenoids to see if I could get water to come in. It did when I pushed the water dispense switch after switching the solinoids. So the solenoid feeding the ice maker is ok. What else could cause no water to come in to the freezing tray?
  • rcline662003 Apr 07, 2008
    no water going to ice maker
  • Anonymous Jun 04, 2008
    I have a Frigidaire FSR26HF5A side by side. Ice maker not making ice, no water in tray. Water to solenoid valve, continuaity accross solenoid terminals.
    President:
  • Frigidaire Master
  • 2,651 Answers
The ice maker itself sounds like its not calling for water, you would need to replace ice maker, not field servicable. did you switch the solenoid? or the wire(s) leading to solenoid??? by switch the wire(s) when you depress for water the ice tray will fill with water. reason i say that is possible that the solenoid is energized, perhaps the valve post its sitting on is no good
Posted on Mar 11, 2008
Ice maker quit making ice but the water dispenser still runs water. what is wrong
Is the solenoid that supplies water to ice maker working? If there is ice in tray, perhaps the heater is not working so the ice in tray can be slid off and into ice hopper.
Jun 19, 2017 | Refrigerators
The ice maker stopped ejecting ice. Now no water going to icemaker
hav u cleared the ejection area for any debris and the like?
Jun 14, 2008 | Frigidaire FRS23H5AS Side by Side...
The ice maker is not working
are u getting water to the tray if not the water solenoid valve needs to be replaced.
Jul 12, 2014 | Frigidaire Refrigerators
Frigidaire ice maker
My Samsung would freeze up periodically especially when I didn't change the filter. Contaminants will cause frost or freezing in the line. The result was a tiny frozen blockage near the solenoid.
UNPLUG the fridge and run a hair dryer directed at the ice maker. Being careful to not allow plastic parts to overheat.
Sometimes you may even hear the tiniest crack when it lets loose. probably only take 20 minutes or so. depending how much of line is frozen.
Oct 28, 2017 | Refrigerators
Hooked up water line and ice maker, water working notice maker. Any ideas?
Make sure wire loop extending out from the ice maker over the ice bin is pushed down. Up turns the ice maker off.
Without more info, I can't diagnose further.
Stick finger in ice tray where ice freezes. Is there water in there. No, check solenoid valve and water line to ice maker (kinks). Is there ice cubes in ice tray? Is ice maker pushed fully in? All wires to ice maker on back and underneath connected?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker does not fill with water
If your model has a water
Filter, that may need replacing. If that isn't it, the water valve most likely is the problem
Oct 19, 2017 | Freezers
My whirlpool ed27dqx refridgerator quit making ice immediately after I had my reverse osmosis drinking water system upgraded. I replaced the ice maker unit and the dual water valve. I have always had water...
The pressure from a reverse osmosis system is not sufficient to operate the ice maker water valve. A water valve requires a minimum of 20 pounds of pressure without a refrigerator water filter, and 35 pounds of pounds of pressure with a refrigerator water filter. Manufactures do dot recommend installing an R/O system on the water supply to a refrigerator. The pressure may have been higher from your old system.
Apr 28, 2009 | Refrigerators
Frigidaire Side by side Leaking water from Behind the dispensor
You may have a defective water inlet solenoid valve. replace water inlet solenoid valve for ice maker. Contact Frigidaire Dealer for part by Model and serial number. Replacing the part is reverse of removing old valve located behind refrigerator on right side facing the back. You may have to remove bottom back cover to access. Make sure you reinstall the cover for proper operation.
Apr 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
Sub-Zero Under Counter Ice Maker not making Ice
ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Feb 20, 2008 | Freezers
Frigidaire FRS26F4C Side by Side Refrigerator Logo
240 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
