Have an lcd2010a wharfedale colour tv since 2005. It is out of warranty. Problem. switch on tv obtain sound and picture for 1 to 2 hours or even less 45 min. Then suddenly no picture, but sound or nothing no sound or picture just the button led flashing red> It is connected up for freeview. q: has tubing gone, Is it the freeview box although it is knew and most of the leads are connected through tv. pls advise i am a uk disabled person who relys on tv
  • 4,889 Answers
Try removing and re-installing the lamp cover on the back.
its a known issue with whaferdale tv's during manufacture, the lamp cover is not seated properly causing the safety switch to not engage all the way, when the lamp cover heats up and expands, it fall away further from the switch tripping it, shutting the set down.
when you remove and re-install the lamp cover, after you take the single ***** out, tilt the cover out and forward from the top about 3/4 of the way out and then tilt it back into normal position and put the ***** back.
Posted on Mar 11, 2008
  • eagle338
    eagle338 Mar 11, 2008
    sorry there seems to be a problem.. ***** = s c r e w
Wharfedale tv
That sounds like the backlight is switching off. It might be faulty. If this is the case the screen still shows a picture but it's not lit, all black.
May 09, 2014 | Televison & Video
We have a samsung 933hd. when we switch on, we get a picture and sound but lose picture after 1 second. Can't get anything on screen even using remote. Switch off then back on and same again , sound ok but...
This is a power supply problem. If the set is under warranty, exchange it.
If you warranty is expired, you can take it to a repair shop and get an estimate to see if it is worth fixing.
Feb 10, 2011 | Samsung 933HD+1 19 in. TV
Wharfedale 42f1080p faulting?
Replaced any swolen capacitors on the power board.
Sep 01, 2009 | Televison & Video
Wharfedale lcd2010a
The TV is Manufactured by a company called Vestel in Turkey and will operate on the AK45 chassis remote control,if you try the codes for Bush or Alba one will operate it nut not of course menu functions but no problem there is a menu button on the side of the set.
audiovservices@fsmail.net
Apr 18, 2008 | Televison & Video
Wharfedale wh hdd160hdmi freezed
I have the exact same problem, did u figure out why? plz email me at nishalin@gmail.com
Apr 13, 2008 | Wharfedale Televison & Video
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Tv problem
  • you can check voltages on screen control ckt & adjust it which is located on flyback transformer.
  • if it does not help then your crt has gone weak & needs replacement.
  • good luck.
  • hope this will help
Oct 21, 2007 | Televison & Video
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
