Olevia 332-B11 has cable TV potential. However, it requires a VCR or other device to be used as a TV! It is a wonderful computer screen though! Currently, I have a Magnavox Star Sight that enables the use of the TV with limited cable. The Olevia and the Magnavox are hooked up to a Marantz AV Surround Receiver SR4600 as well as a Marantz Super Audio CD/DVD Player DV7600. The monster problem is that The sound is less than satisfactory... ie It sounds as if it is not receiving the sound signal and when ot does it is corrupted with interference. After an hour or so the sound is fine. How does one get the sound to work immediately without burning up speakers??? ...Occasionally, there is a smell of burning plastic!!!! Please help!?!?!?
SOURCE:
SOURCE: I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Posted on Feb 29, 2008
SOURCE: magnavox dv225mg9 dvd/vcr player. Hooked
I had the same issue. You probably have your unit connected with the newer cables that are red, blue and green. These are more sophisticated and offer better quality for the DVD portion. However, they will not carry the video for the VCR, only the audio.
You need to connect a *yellow* Video Out cable from your DVD/VCR to the Video In on your TV, this should carry the video for the VCR! Hope this helps!
Posted on Jan 05, 2009
  • 6 Answers
SOURCE: need to know what wall bracket is compatable with
any bracket that is made for a 32 in will work or what ever size TV you have only difference is if it tilts or moves in any way
Posted on Nov 02, 2009
budmrtn
  • 11361 Answers
SOURCE: I have an Olevia 332 b11 LCD tv. I want to mount
There should be at least 4 mounting holes (VESA mount), and they should be used.
Posted on Dec 17, 2009
  • 11 Answers
SOURCE: PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Posted on Dec 22, 2009
I'm looking for an owners manual for an Olevia 332-B11 it is approx. 10 years old. Any help?
Free User Manuals and Owners Guides ManualsOnline com
Try this site. It goes faster if you have the serial number and the make handy.
hope you find your manual,
kolbrun
Feb 01, 2015 | Olevia Televison & Video
Hi, My Olevia 42 inch, model342-B11, has a problem with its picture. At first I had vertical lines running down the screen, then it turned into small squares. What do you think is wrong with it?
Parts are hard or impossible to find for this brand but it sounds like the "main" board which processes all signal in and out of the display.
Apr 30, 2012 | Olevia 742I 42 in. LCD TV
How do connect antenna lead to a olevia 332-b11 set??
Either via the cable fitting or via the av jacks from a box.
Mar 14, 2012 | Olevia 332V LCD TV
32 in olevia 332-b11 tv and the color is going bad how do know if it's the master backlight inverter or the other one
It is neither. Your inverters do not control your picture color. All they do is power the back-lights. If your color is going out, odds are it is in your main board.
Apr 11, 2011 | Olevia 332V LCD TV
Analog to Digital converter
Ur tv a LCD or Plasma tv?No,LCD and Plasma Tvs have a Digital tuner inside the tv to recieve free air DTV.Not require a Digital coverter box,if u have a LCD tv or a Plasma tv.U must have good antena thought like a roof or a digital antena,so ur tv picture don't cut in and out very often.
May 29, 2010 | Olevia 332V LCD TV
Dec 17, 2009 | Olevia 332V LCD TV
Need to know what wall bracket is compatable with olevia model number 332-b11
Nov 02, 2009 | Televison & Video
How can I get the firmware update for Olevia 32 in. 332-B11
you need the firmware flasher and the usb driver, I have both from a long time ago
Oct 16, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 337-B11 how to connect to a TV
Unfortunately, This hdtv can only use with receiver. There is no cable connection back of it. You may connect it using with HDMI cable.
Nov 30, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
1,073 people viewed this question
Top Televison & Video Experts
Ekse
