Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Not letting laptop go wireless - Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
  • Louie  Role
    Louie Role May 11, 2010
    Can you pls post back what brand/make and model of the laptop as well as the OS you are using. Additionally, may I inquire if there are any other PCs being connected to the router.
    Pls post back as requested or should you need additional information.
    Good luck and kind regards.
    Thank you for using FixYa.
    Brigadier General:
  • 6,966 Answers
Hi again,
Any new development(s) or updates with your concern?
Posted on Apr 08, 2008
Wifi Signal Problem ???
You have the following options.
1. Move closer to the router
2. Purchase and install a wireless usb adapter that plugs into your usb port from Tiger Direct at: http://www.tigerdirect.com
3. Try using another client to manage your wireless. Usually there are 2 ways to manage your wireless on the laptop. You can use the software that came with your internal wireless card or you can use Windows (zero config) to manage your wireless. Which ever one you are now using, switch to the other. Open the software that controls your wireless and look through the tabs searching for where it will say something like "Let this tool Manage the Wireless" or "Let Windows Zero Config Manage the Wireless". Which ever one it is using switch to the other by checking or unchecking the box. Most times one will produce a better and stronger signal than the other.
Jun 01, 2012 | Dell Inspiron 1420 Laptop
Laptop says i am connected to internet but it won't let me online
Limited connectivity
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Nov 06, 2011 | IBM ThinkPad T40 2373 Notebook
My laptop wont let me set up a wireless connection
Does your laptop already have a wireless utility or program to manage your connection?
Lot's of times, there's a button on your keyboard that can toggle your wireless adapter on/off. It's normally along the top on one of the F buttons. Try pressing it to see if your computer tries to connect to the internet. Let me know if that doesn't work.
Jul 20, 2011 | Computers & Internet
Doesn't let me click on the wlan on 'Wireless Status Option'
Please try re installing your operating system. (Genuine windows xp or vista recommended)
If the problem still persists feel free to get back me @
deepuunni1985gmail.com
Jul 16, 2009 | Fujitsu AMILO PC Laptops
Wireless lan networking for toshiba satellite 1900
Not enough info per problem description. Not all 1900 series laptops have wireless cards installed, and not all 1900 series laptops are ready to handle wireless cards, either. Need to know what model your computer is, what wireless card you're using, ... C'mon. Let's have it...
Mar 19, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
Wireless connection to router issue
Let me clarify to make sure I understand the problem: You set up your wireless router with a WPA 20 digit wireless key. You have a laptop which cannot connect with the 20 digit key specified. If I have misunderstood your issue, please let me know.
The first step always in this situation is to check and re-check your wireless key and make sure that you are entering it correctly. I will assume that you've already done this.
From there, you have 3 options to rectify the issue:
1) Set up the wireless router with a WEP wireless key.
2) Download a firmware update for your wireless adapter in your notebook to allow it to use WPA encryption.
3) Purchase a PCMCIA wireless card for your notebook that works with WPA encryption.
Please let me know if I can help any further.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 13, 2009 | Gateway 4024GZ Notebook
No Internet Connection
Hi kathy
I believe you are connecting to the internet using wireless. Are you using this laptop to connect to a home wireless network or you connect using a cable. This will be a good way to analyze your problem
Post the ip address that you are getting.
You can get the ip by
start -run-type cmd enter
you will be in the black command prompt
just type ipconfig
and let me know what you get under ip address.
Also let me know the wireless router, your Internet Service Provider and also how many systems are there are at your home if you are connecting to a home wireless network.
Also let me know which is firewall or antivirus program that you have.
thank you do let me know if this works and do share your experience.
thank you
rakesh
Expert in Dell
Jan 05, 2009 | Dell Inspiron 6400 Notebook
Hp wireless assistant 3.00 C2
hp support page let them detect ur laptop aand they will give u everything u want
Aug 16, 2008 | Compaq Presario Notebook
Wireless
- Let me know wha is the Operatiing System of your computer?
- Let me know what is the brand of your Laptop?
- they have some keys to turning On your wireless connection.
Aug 03, 2008 | Samsung V25 XVC 2800 Notebook
Laptop Wireless Connection Problem
I have previous experience with this wireless connections. I'm not familiar with AT T GSM device. In my experience I found that the manager can play up, but you can switch to windows manager depending on what windows you have. In Windows XP go to your control panel. Click on network connections, then select the wireless network connection. On the screen a window with the network connections should appear. Then on the left hand side down the bottom it will have Change advanced settings, and click on that. Then another screen appears with Wireless Network Connection Properties. Click on Tab Wireless Networks. On that page click on "Use Windows to Configure my wireless network". Once done, click okay or apply if appears. Restart computer and see if windows picks up you wireless connection provided you have WIFI on your laptop! Try that, let me know if you need more help!
Jul 30, 2008 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
15 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
