Question about Polaroid i733LP Digital Camera
I733 POARIOD PICK CAMERA.
I733 POlARIOD PINK CAMERA. LENS STUCK HALF WAY OUT AND WON'T TURN ON. SEEMS TO BE A COMMON PROBLEM, I NOW HAVE 2 OF THESE I733s WITH THE SAME CONCERN. CAN THIS BE RESOLVED? CAMERA WILL TURN ON BUT THE LED BLIPS ONCE AND GOES OUT. LENS STUCK HALF OUT. TURNED THE CAMERA OFF JUST AS THE AUTO-SHUTDOWN FROM LOW BATT WAS OCCURRING AND THE LENS STOPPED WHERE IT IS NOW. CAMERA 1 YR OLD, SECOND UNIT 1.5 YRS OLD, BOTH SAME ISSUE. **** AT POLAROID WILL NOT ASSIST. ANY HELP?? KS
  • 11 more comments
  • cinderelish Mar 14, 2008
    Exaclty the same problem. Lens is stuck open and looks slightly crooked. When I turn the camera on, it beeps and momentarily displays out of focus on LCD then shuts off.
  • spaztech Mar 18, 2008
    Camera a few months old, when daughter's friend dropped it. It won't turn on, and the lens is most of the way extended. Batteries fully charged. No signs of damage on the outside. Good products don't fail after one moderate drop. No LEDs come on, no beeps, no display.
  • amy meylian Mar 26, 2008
    i have the same problem the batteries went dead while i was taking pictures and the lens is stuck out crooked.and it will not turn on.i still have warrenty but i dont have the recipte so they will not fix it.
  • emily l Apr 20, 2008
    help me please!! i got this camera last christmas (07) and have only used it a couple times. i put it down a month ago and picked it up again yesterday, and it WILL NOT TURN ON!! the green light flashes, there are three low beeps and the lens won't extend. i replaced the memory card and batteries and still nothing. when you look at the front of the camera, the part of the lens that opens and closes is lopsided. ( the top left corner is higher than the top right corner.) I LOVE THIS CAMERA CAN SOMEONE HELP???
  • Anonymous Apr 21, 2008
    I have the same problem. green light turns on and lenses is stuck out and is crooked
  • loveya1616 Apr 27, 2008
    I have had my camera since christmas and i used it the most at a concert. at the concert it said replace batteries. so i did with brand new ones. it still says the same thing and gets stuck completely out! when i turn it on the camera either goes black but the picture is still there but frozen or it says replace batteries and goes black again. the lens are actually fully stuck out. I tried doing what ppl say to do but it doesnt help. i called polariod and they said i need the reciept but i dont have it it was from christmas! i dont know what to do and i dont have the money to repiar or buy a new one!! HELP!
  • kiele
    kiele Jul 07, 2008
    same here! dropped only twice 7 mounths old. touch while hand was damp. new battieries are put in and lens stuckout all teh way.
    hot pink
  • modymo Jul 28, 2008
    Yeah, we have the same problem. Went to change the batteries and the lens is now halfway extended and is crooked. Comes on, beeps and then turns itself off. Called Polaroid, unless you have the receipt and it's under a year, they won't even talk to you. Tried the retailer I bought it from and explained problem but they are "sure" that it was dropped (it wasn't!!). So tired of fighting "the system" I just went and got a new one!! Really too bad since we really did like this camera but just can't seem to figure out how to fix what should be a simpel problem!!
  • Anonymous Aug 24, 2008
    the lens is stuck
  • Anonymous Oct 11, 2008
    I was at a concert and kept getting low battery signals. I changed them twice and on the final time the camera turned itself off and now the lens is stuck. I won't really turn on. This is my sister's camera and she is going to KILL me. This isn't my fault in anyway is it? I see a lot of people with very similar problems....
  • dedikiss Oct 15, 2008
    i had low batteries i changed them..N then it turned on and the green light flashes and it made some beep sound like 3 times and then turns back off..its been like this for a couple months now and im past warranty is there anything i can do?..or am i gonna just have 2 break down N geta new 1! uh
  • maranda price Oct 27, 2008
    went to go change the batteries the lens is halfway out and crocked. when i try to turn it on the light blinks the picture that appears before you us the camera shows up for a few seconds it beeps 3 times and then shuts itself off.
  • Anonymous Jan 12, 2009
    my polaroid camera lense is stuck halfway.I changed the battery but it just makes a weird noise but won't turn on.
    Problem Solver:
  • 12 Answers
This is a common problem with the camera. I have been dealing with fixing cameras for awhile now and have a good solution for this model. First, Polaroid cameras have a problem with certain brand batteries. Some batteries are marked "alkaline" but have a carbon base, because of this they will not power camera on properly or they do not have enough power to keep power on, sometimes causing the lens barrel to get stuck out and tilt. Recommendation: only use Energizer Lithium or Duracell Power Pix. You will get your moneys worth and you will not be spending a fortune in batteries. You can also look into rechargeable batteries (strength of 2000 mAh or higher). If the lens barrel gets stuck outside of camera, the camera will not power on. You DO NOT WANT TO PUSH THE LENS BARREL INSIDE, if you do this you will no longer be able to use the camera. Usually the lens barrel will tilt slightly, if this happens, GENTLY pull the lens barrel up and in the opposite direction of the tilt, you will hear a slight click sound and the lens will now be straight again. Now, insert NEW batteries (as recommended above), the camera should power on and the lens will retract back into the camera. This is the only time you should be pulling on the lens, remember DO NOT PUSH THE LENS INSIDE.
Posted on Oct 10, 2009
I just dropped mine last night and the lens got in this funny bent position, so I popped it back to where its suppose to be. Now the camera turns on and off without the low battery signal but the lens doesn't retract or do anything by itself anymore. I can hear the little motor running that retracts the lens, but the lens itself doesn't actually move when I hear the little noises. So now, I have a wonderful camera with the lens stuck out. I should state that I have the i631. It's just like the i733 but one megapixel smaller. I've the receipt from the retailer that I bought it from so I'm hoping polaroid will at least look at it. I bought it back in June! It's only 4 to 5 months old!
I'm not sure if this will work for all of you, but try plugging it into your computer. When I had this issue for no apparent reason, plugging it into my computer seemed to awaken my camera out of the protective sleep mode that it was in. Sadly, it's not working for me this time.:-(
Posted on Oct 15, 2008
This is happening way to often and it's to expensive to last as long as a disposable camera
'they ****"polaroid should be ashamed of them selves.
Posted on Oct 05, 2008
The same thing happened to me. Personally, I sent it back to Polariod. They sent me a complete new one. The new one did the same thing again! Butthis time, I do not have a reciept. Tomorrow I am going down to Best Buy and asking the "geek squad" to fix it. They seem to be the best bet.
Posted on Jul 04, 2008
Oh my gosh! i also dropped my camera and the lens wont go in or out. it turns on. but will not go in or out!!! help!!!
Posted on Jun 06, 2008
All you have to do, for my camera at least, was that i put in new batteries and all was solved...i never thought that was a major issue, its just something simple, YOUR OUT OF BATTERY
Posted on Oct 06, 2009
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
Casio exilim EX-S10 wont turn on and lens stuck out
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here is a video summary of the steps:
Nov 14, 2011 | Casio Exilim Ex-z300 Z450 Z9 Z80 S10
Some stupid person has dropped and then kicked my brand new Samsung camera and now it won't turn on and the lens is stuck out :( When I try to turn it on it makes a weird beep and won't turn on and...
You should try to get that stupid person to buy you a new camera if the following doesn't help. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Jul 09, 2011 | Samsung Digimax S730 Digital Camera
Polaroid i733 digital camera lens stuck open
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the
batteries. (obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
May 15, 2010 | Polaroid i733LP Digital Camera
My polaroid i733 turns on the beeps 3 times then turns off when the sd card is in. i have tried formatting the card and camera but it still is not working any help
Had the same problem with our i733 Pink Polaroid. Beeps three times and then shuts off. The reason for this is that the lens is stuck in the partially open position. Because our camera was long past warranty and we bought it for $40 second hand I took the brute force approach. I grabbed hold of the lens and wiggled it from side to side while trying to pull it out (forcefully but being as careful as I could not to damage it) and then there was a small "pop" and the lens came out all the way and the camera was good to go again. Hope this helps.
Jul 25, 2009 | Polaroid i733LP Digital Camera
Dropped polariod t1031 in sand. Lens is stuck.
to try and fix this(i have done it before) , pull it out when it is on , you have nothing to lose and manually assist it to open, try to get contamination out. replacing lense is probably not worth the cost
Jun 17, 2009 | Polaroid i733LP Digital Camera
PINK POLAROID I733 CAMERA LENS
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Mar 17, 2008 | Polaroid I533P Digital Camera
Polaroid i733LP Digital Camera Logo
313 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
