Question about Archos 605 WiFi Digital Media Player
Out of control!
Whenever I turn on the unit, the different menu options are selected by themselves at rapid speeds as though the right direction button is being held in place. Also, when playing, it doesn't skip ahead or track so it cannot be the button being held down phisically however, little black flasing squares appear accross the screen.
Help me top experts, you're my only hope...Thanks.
  • 24 Answers
Try going into the setup menue and revert back to default settings might do the trick.
Posted on Mar 17, 2008
How to fix rapid flashing turn signal when all bulbs are OK?
Easy way to find the location of the flasher unit: Turn on either the RIGHT or LEFT indicator, and listen for the click under the dash. When you find the source of the click, THERE'S THE FLASHER UNIT! :)
May 13, 2015 | Cars & Trucks
How can i unlock my keyboard
Recognize that you have a locked keyboard.
If your PC computer is not responding to keystrokes or is responding very slowly, you could have a locked keyboard.
Use your mouse to move the pointer over the "Start" button.
Use the left-click button to bring up the "Start" pop-up menu.
Position the pointer over "Settings" and use the left-click button to select. T
hen select "Control Panel." On some versions of PC operating systems, you can select "Control Panel" directly from the "Start" menu.
Select "Accessibility Options" to bring up another menu, then select "Keyboard."
You'll see three options that have check boxes.
Make sure each check box does not have a check mark in it.
The three options are "StickeyKeys," "FilterKeys" and "ToggleKeys."
Note that these options can become checked if the keyboard operator has repeatedly depressed the "Shift" key in rapid succession--or if the "Shift" key is held down for longer than eight seconds.
If the keyboard is still not responding, the problem could be that the computer has lost communication with the keyboard.
Turn off the computer.
Disconnect the power supply.
Remove and then reconnect the keyboard cable, then reconnect the power supply.
Turn the computer on.
This will reboot the computer, allowing it to recognize the keyboard.
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
Werfault.exe -application error\r\n
You can try to disable this service by following the below steps:
Step 1: Open your computer's Control Panel by selecting "Start" > "Control Panel" from your computer's Start menu.
Step 2: Choose the "System and Maintenance" > "Problem Reports" menu option from the Control Panel menu.
Step 3: Select "Change Settings" > "Advanced Settings" from the Problem Reports program menu and turn off the automatic problem reporting feature in Windows.
Step 4: Exit the Problem Reporting application by selecting "File" > "Exit" from the File menu. Werfault.exe will now only run on your computer in the event of a catastrophic application problem.
If disabling the application does not work, y
ou should keep in mind that many malware programs can show up on your system as seemingly legitimate files by using file names that are very similar to those of legitimate files. Whenever you are in doubt about a particular file, always scan your system for viruses.
Jun 10, 2010 | Dell Dimension 4400 PC Desktop
How can I adjust the speed and size of my Logitech USB Mouse.
Depending what version of Windows you are using, you can go to:
A. Start Menu
B. Select Control Panel
C. Select "Mouse"
From here you can play with lots of settings for the mouse, including speed, size and more. (The layout of these options, and many of these settings are different from one version of Windows to another. All of them allow you to change the speed and icon though)
If you are using a Mac with OSX, you can find similar options in the System Profiler.
Good Luck
Apr 25, 2010 | Logitech Cordless Mouse
The computer does not show the internet connection in the monitor. Before I reinstalled the windows it shows the message: no connectivity or limitated connectivity. The comcast modem was damaged so they...
Even though it does not show the connection on your monitor, the connection may still be working. Did you post this problem from the same computer? If yes, then you are fine.
Dec 29, 2009 | Dell Dimension E510 PC Desktop
How to decrease volume
Your audio drivers should provide an icon in the lower right corner of your screen (normally). If you hover your mouse pointer over it, most of them will identify themselves. Once you have found it, there are a couple of different ways to proceed. Normally, a double click will open the volume control, since that is the most common use. Alternatively, you might right click on the item and select one of the "open" options from the pop-up menu. Usually that gives a more complete view with more options than just the volume control.
Dec 15, 2009 | Dell Inspiron 6400 Notebook
How do I program speed dial?
Now the process is different for different phones... What i'll do is write generealized steps here If these don't work then just tell me the exact make of your phone and i'll direct you properly.
SOLUTION 1: Go to menu-->contacts. Scroll down till you find an option that says speed dial. If it doesn't exist then go to options (usually the left or right select key; top-left or top-right key) and search for speed dial. Solution 1 should mostly work for you.
SOLUTION 2: On your home screen just dial any number (except 1 and 0). Now press the top-left key. An option that says assign should appear. You'll want to try both the keys (left and right) individually.
Either of these methods should work. If not give me the brand and model name and i'll direct you.
Further if solution 1 works you'll come to a screen which has digits from 1 - 9. Go to any digit and select it. You can assign one number to any contact from your phonebook. Assign how many ever you want and then use options--> save and you're done.
Just go to the main screen now and press any number and call. It'll call that perso instantly,
Sep 06, 2009 | Cell Phones
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
RCA F32450 TV
Question?
Whenever I turn on the television, the GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes on.
Answer:
The GUIDE Plus+™ or GUIDE Plus+ GOLD™ on-screen program guide automatically comes up when you use the TV button on the remote to turn on the TV. There are several ways to turn off this function if you wish, depending on your model.
Option A:
Select the GUIDE Plus+™ Menu from the Main menu.
Select Setup.
Select Options.
Select Off.
Option B:
Select GUIDE Plus+™ Auto Display from the GUIDE Plus+ menu.
Select Off.
Option C:
Press GUIDE on your remote control.
Select the Menu bar.
Press the right arrow button to select Setup.
Choose Review Options.
Select Off.
I know Option C worked for me!!
Given the many TV models, it's possible that accessing control of this feature in the Program Guide menu may differ on your TV. For specific instructions for your model, see your owner's manual.
Oct 27, 2007 | RCA F32450 32" TV
Guide plus flashes on the t.v.. how do you turn it off
you are that clear
but if you are talking about flashes on the t.v then it is due to sparking is taking place in your plug & socket.
if it is ok then there is a sparking in high voltage section in tv which is called fly back section.
good luck.
Oct 17, 2007 | GE 32GT740 32" TV
Archos 605 WiFi Digital Media Player Logo
23 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
