Question about Dell XPS™ 600 PC Desktop
XPS 600 serious Boot up Problems!
Heya!
I have a Dell XPS 600
sli - 7800gtx, 2gb ram..etc.
When turning the main power on the comp will boot up and start running, then makes all the fans will run (loud) and the screen will turn to standby after 2 secs.
The diagnostic light is on 4, cant find anything on what it means..
I have disconnected and tested everything..works fine on other systems.
Any ideas..i need to try and get this fixed asap for coursework..more info can be given
  • 3 more comments
  • josh_gib Mar 12, 2008
    the power supply is fine and is still running as it did..but the heatsink shroud fans are going nuts..they are completly clean as is the heatsink its self..i have also disconnected the heatfink fan shroud from the main processor heatsink but this still didnt solve the problem..i have however, noticed that the northbridge heat sink has come lose..possibly due to heat, this exposed the nvidia chip..is it worth applying themal paste stuff to make a connection again..this is only an idea tho as im not sure it had any applied in the first place...or is the motherboard faulty? also note that no overclocking and other problems have happened.
    Cheers for the reply!
    The heatsink (processor) is held on my a clamp..the paste that was there has completly dried up.,..i was able to wipe it off with a cloth...the same with the memory (nvidia) heatsink..But would a lack in the thermal paste cause a break in the connecton for the whole motherboard?
    thanks again
  • josh_gib Mar 13, 2008
    many thanks for the reply, i think it does mean a new motherboard..dell even offered to replace the board for £50! which is far to high for what it is!
    why they use plastic screws on a heatsink confuses me!
    thanks again..
  • josh_gib Mar 26, 2008
    dell motherboards are pretty expensive..so tbh i wouldnt bother getting one..search around for a socket 775 sli and it also would be more up-to-date with wireless etc..im seaching now so if i find one i'll let you know..also to note my warenty also has just expired! seems alittle odd!! i would also avoid computer shops as they seem to charge the earth and thats just to look at it!
  • mitchmanthe Sep 09, 2008
    Great, I don't hold out much hope of getting mine working anytime soon. My XPS 600 just died last night. All I get is a slow, yellow flashing Power switch. It was running one minute, and the next thing I know, everything went blank. I just had the main fans replaced two months ago just before the warranty ran out. I also replaced the graphics cards. Guess I should have checked out the power supply and motherboard, too. I followed the directions on the Dell support website about turning off the PC, unplugging it, waiting 10 seconds, and trying to power on again. No luck. (Yes, I did plug it back in again.) ;-) Also did the next solution offered. Unplug all peripherals, unplug, wait 10 seconds, and try the power-on again. Still no luck. I've got an old Dell 8250 that is more reliable than this XPS 600! I'd replace the power supply myself but can't figure out how to remove it from the main chassis. Any tips?
    Sergeant:
  • 349 Answers
Sounds to me like the fan is on the way out ,and if the cpu gets too hot the pc will shut down.
check that the fan is not obstructed,clean it if it is full of dust, replace it if it is not working as it should.
also listen to the power supply fan, is it working ok,this could cause the same type of problem but for different reasons.
good luck
Terry
Posted on Mar 12, 2008
  • terry Mar 12, 2008
    well thermal paste is used on a cpu and heat sink, while the heat sink is held on by a clamp,
    the thermal paste will not hold the heat sink in place on the northbridge by its self ,unless it has a clamp,it sounds to me that the motherboard is on its way out.
    Note: thermal paste is toxic.
    sorry im all out of idea's now
    please rate my efforts
    good luck
    Terry
    well heat is poison to motherboards & cpu's ,the heatsink that was on the northbridge may have been off for a long time damaging it ,sorry i cant heip you .looks like a new board is needed.
    cheers
I have the same problem with my Dell XPS 600. i took it to a PC shop and they tlod me it was the mother board. I called dell and they told me it would be $280 for a new mother board. this happend 1 month after the warenty exired. I wish i could buy my own now mother board from a 3rd party vendor. Does any one know where i can get one or does it have to be the dell one.?
Posted on Mar 26, 2008
You can get these for $159 here. A new motherboard is the common solution to diagnostic light #4 with orange power button (no boot).
http://www.impactcomputers.com/gc375.html
Posted on Oct 03, 2008
Dell xps 600 will not display any picture at all, beeps six times lights 2 and 3 are lit on front diagnostic display. Replaced memory with working ram from another pc, replaced pcie graphics card with...
sounds like youv'e covered all the possibles i would. could be the boot files got corrupted or the monitor is bad(have you checked it with another pc?) check the motherboard for swollen capacitors(those barrell looking objects randomly scattered over board. if the tops that have little crosses on them (+) are popping up/out unlike others, then your board needs replacement or new pc. cannot fix those. happened to a friend of mine. would not boot up to show windows.
Nov 03, 2013 | Dell XPS™ 600 PC Desktop
I have Dell XPS 420 , with windows home server running for some time. I tried to insall/upgrade RAM from 3 gb to 6 gb. So, i found the right RAM (2x2GB) and removed the two old 512 mb from the slot and...
According the the dell specification you can only install up to 4gb, so I don't understand you saying that you were upgrading from 3gb to 6gb. Make sure that all the ram that is installed is of the same brand and speed (667 / 800 MHz Dual Channel Dual DDR2 SDRAM). The fact that it is saying no boot device also would suggest that it is possibly something wrong with your harddrive, whether it was corrupted or damaged while you were changing the RAM, if you have a spare harddrive try installing and booting from it. If that doesn't work it could be a motherboard issue, which the BIOS should be update, all the jumpers on the board should be checked etc. Its rather hard to diagnose a problem such as this, and the fact that after you installed the new RAM, even the old RAM would not work, suggests that you may have damaged something while messing around in the computer.
May 19, 2011 | Dell XPS 410 PC Desktop
My asus m2n32-sli motherboard won't start up; runs for 4 seconds then shuts off. currently hooked up to the mobo: have a 500W power supply; AMD 3300 64 processor; zalman cpu fan; 2 patriot 2GB DDR2...
The only thing i can suggest is remove one of your RAM sticks and see if the machine will boot. I had this problem with mine and it turned out that one of my RAM slots was faulty and would not boot if both RAM slots had RAM in them.
Nov 04, 2010 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Dell xps 600 won't boot
hard to say but you can try to repair the os turn your pc on and start pushing f8 it should open a restore panel one of the options should be repair try that
Feb 20, 2010 | Dell XPS 600 PC Desktop
Upgraded Studio XPS 435/9000 Ram - Now No Windows 7 Start
Check speed settings in BIOS, make sure that the sticks are the correct voltage for your motherboard. If the specs are correct, try a program like memtest86. This will tell you where the problem is, but it is up to you to find which stick that location is :) Might take some trial and error before you find the defective one!
Dec 15, 2009 | Dell Studio XPS Desktop Computer
Dell xps 730 does not boot
I think it is a problem with your RAM memory. If you have 2 dims extract one and try to boot if not work extract the other one and try.
Jul 18, 2009 | Dell XPS 730X Desktop Computer
Low system battery
Try to make first boot device as harddisk and in the main menu disable the primary or secondary IDE/SATA that are not used...
Apr 05, 2009 | Dell Dimension XPS 600 PC Desktop
Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Mar 17, 2009 | Dell XPS 600 PC Desktop
Added more ram from 2gb to 8gb but still say only 2gb
1fb3933.jpg the above will help u..the OS will not support the RAM you have hence its not showing..hope it heps!
Nov 23, 2008 | Dell XPS™ 600 PC Desktop
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
Dell XPS™ 600 PC Desktop Logo
2,061 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
