Cooler Master (RS-430-PMSR/P) (RS430PMSRP) 430-Watt Power Supply Logo
Anonymous Posted on Mar 22, 2010
How to check if my power supply is already not ''at the limit''?
I will be installing some more hardware (HDDs, graphic card and RAM) and how can i see if my power supply will be able to handle it easily?
My power supply is Cooler Master RS-430-PMSR (Regular), 430W.
Anonymous
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Mar 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
5025
Points
47
1 or 2 extra hdds and ram does not require much extra power and your coolmaster should do the job. But if you intend to use a newer graphic card you should check the requirenments for wattage at your new card manufacturer product specification webpage. I am pretty sure that almost all newer graphic cards require at least 500 watt to run without problem. My advise is to buy at least a 550 watt psu although i don't know what is your hardware. Try to post your hardware specs and calculate for each component (cpu wattage+graphics wattage +etc) your power supply need to be over 50 wattage. Hope that helped!
What are some mid to high end compatible GPUs for this motherboard
instead of assuming a comparability issue, have you considered a power supply issue?
have you disabled the onboard video?
have you exchanged the card? have you tried a different brand
according to your boards tech support:
  • Some PCI Express graphics cards require more power.
  • Remove and reinstall the new card to make sure it is fully seated in the slot.
  • Try the card in a different slot, if possible.
  • Make sure other devices and cables inside the chassis were not disturbed or loosened when you installed the new card.
Desktop Boards Computer Does Not Boot After Installing New Hardware or...
additionally, you need to make sure that you have more than 2 gigabytes of system ram; although, wwith an i7, i would expect yo have that already covered.
1helpful
How to make it run on windows vista
I have never played this game but I think I know what the solution is.
So this game is designed to run on Windows 95, 98 and ME so this means that the graphics are 16 bit. Vista uses 256 bit graphics. First thing to solve this problem. You will need a Graphics card that can support Graphics from 8 bit to 1024 bit Graphics. You can do this one of two ways. Either buy a 2 pound graphics card from years ago that will most likely require a Mother board with an AGP slot and only support 8 bit to 16 bit graphics, or buy a really expensive Graphics card for 2600 pound that requires two PCI-E slots, a power supply capable of supplying 1800 watts or more and a DUAL CPU Motherboard capable of taking two AMD 16 core processors and a minimum of 16 GB of RAM. The Mother Bord would cost about the same as the Graphics card, the Power Supply would cost around 160 and the RAM would cost around the same as the power supply for the DDR-3 model, which is what you would need.
The Hardware required to run an expensive Graphics Card capable of running 16 bit Graphics is not capable of running the software required for 16 bit Graphics on cheap graphics card.
This is the same if you reverse the scenario.
A Cheap Graphics Card will not run 16 bit Graphics software with cheap hardware.
What you need to do this is both Cheap Hardware and Cheap Software or Expensive Hardware and Expensive software.
Old fashioned software will not run on modern Hardware and it is the same for the reverse.
I need a vedeo card that supports ecs livermore8
The Motherboard is considered the 'Building Block' of the computer.
From it all hardware components are supported.
Processor, Ram Memory, Harddrive, Optical Drive/s, and add-on expansion slot cards.
A graphics card (Video Card) being one.
You need a graphics card that the ECS 945GCT-HM,
or also stated as HP's Livermore8-GL6; will support.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01237572&lc=en&cc=pt&product=3632125#N33
The motherboard chipset is an Intel 945GC,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
According to Intel came out the first quarter of 2005,
http://ark.intel.com/products/34505/Intel-82945GC-Graphics-and-Memory-Controller
The year PCI Express 1.1 technology came out.
PCI Express 2.0 technology didn't come out until 2007,
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_1.1
Will the ECS 945GCT-HM support graphics cards based on the PCI Express 2.0 technology?
YES!
PCI Express 2.0 technology IS backward compatible, with PCI Express 1.1 technology.
You just won't get the full capability of the PCI Express graphics card; based on the PCI Express 2.0 technology.
Will you notice? Doubtful.
From what I have seen listed in reviews on the graphics card, I would not suggest a graphics card based on the PCI Express 2.1 technology.
Reviews suggest it doesn't 'play well' with a motherboard using the PCI Express 1.1 technology.
There is another thing to consider; Power Supply
Most decent graphics cards require a minimum Power Supply wattage, of 400 to 450 Watts.
This Power Supply requirement isn't just for the graphics card.
Graphics card manufacturers base it on a test computer system.
One they put together with a powerful Processor, high performance motherboard, 2GB's of Ram Memory (At least), optical drive/s, harddrive, and the graphics card. (Plus allowance for computer case fans, etc)
If you're running a 300 Watt power supply, this = No.
(Yes, even though AMD ATI Radeon graphics cards, are touted to use less power; 400 to 450 Watts is still the limit for a decent graphics card, from them. Unless you want to run a simpy PCI expansion slot graphics card, or budget/starter, PCI Express graphics card)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4501123&CatId=7387
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2555929&CatId=7387
Regards,
joecoolvette
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5344843&Sku=T925-3014
GPU hardware not recognised
Hello the homepage is here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=583#dl
Try to download a manual if you don`t have it.
If any drivers for the mainboard is missing install them.
Install the newest NVIDIA graphic driver from here:
http://www.geforce.com/drivers/results/49949
This is the 64 bit version.
Check also if the graphic card is properly insertet
in the slot on the mainboard.
And the graphic card has to support PCI-E X16
This graphic card needs extenal power
from the power supply to work
the power supply has a wire with pci-e stamped in did you connect this ???.
Try to disable the onboard graphic in the device manager.
Good luck
1helpful
Will this graphics card work with my computer?
1) HP xw6200 Workstation desktop computer,
http://h18000.www1.hp.com/products/quickspecs/11975_div/11975_div.HTML
Power Supply: Maximum rated Wattage - 500 Watts.
XFX ATI Radeon HD5750 graphics card,
http://www.ebay.co.uk/itm/2GB-ATI-Radeon-HD-5750-1GB-HDMI-1080p-BluRay-EyeFinity-Gaming-Graphics-Card-/120973408169?pt=UK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW&hash=item1c2a93b7a9&_uhb=1#ht_4735wt_1080
Yes.
1) Install the software F-I-R-S-T, then physically install the graphics card.
Windows running, put the Installation disk that comes with the graphics card, into the CD/DVD drive.
Load all software. The drivers, and Catalyst Control Panel.
Windows will NOT use the software until the graphics card is installed, so don't worry about not having graphics in the meantime.
2) Computer unplugged from power FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer, AND before removing any parts out of their anti-static bags, or cartons.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
3) Physically install the graphics card.
(The Lock Lever on the PCI-Express x16 slot, goes UP to install a graphics card, or to remove a graphics card. It looks as though you should push down on it)
http://www.txcesssurplus.com/servlet/the-9225/HP-408544-dsh-001-xw6200-WorkStation/Detail
Looking at the black PCI-Express x16 slot, with it's green Lock Lever, it looks as though there should be room for the graphics card.
Looking to the right of the green Lock Lever, look at the 4 gold colored Choke Coils. It may be tight, but the graphics card should clear the first two.
Areas of concern, though;
1) Power Supply:
The XFX Radeon HD5750 graphics card, requires a minimum of a 400 Watt Power Supply.
The graphics card doesn't use 400 Watts, of course. This is the minimum power requirement by the graphics card manufacturer, and based on the power the card needs, and the rest of the computer.
XFX, just like all graphics card manufacturers, uses a computer system set up to the maximum, for a test unit.
Gamer style motherboard.
Powerful Processor, that is probably a dual core, or quad core.
Maximum amount of ram memory.
Two optical drives
Two or more computer case fans.
Two or more harddrives.
You get the picture.
Power consumption has to be based upon what each individual hardware component will use, AND the graphics card.
Power Supply:
Problem is, the computer has some age on it. From searching it seems to have been made in 2004. Makes it 8 years old now.
Makes that Power Supply 8 years old now too.
A) Pre-built computer manufacturers, such as HP, Gateway, Lenovo, Toshiba, etc., have their components made by someone else.
The Power Supply is one such component.
Usually a generic Power Supply manufacturer, such as Bestec, or HiPro, or Delta, for HP computers.
Low quality electronic components are used in these power supply's.
Isn't a big deal usually, until you start to tax the limit on the Power Supply, such as installing a powerful graphics card.
Power Supply manufacturers also had a great tendency, to overate their Power Supply's back in the day. Made the Power Supply sell better, 'fudging' the actual Wattage rating.
Wattage was actually more like 60 to 70 percent, of what was stated.
300 Watts (60 percent) to 350 Watts (70 percent) is more actual.
The XFX ATI Radeon HD5750 also requires a 6-pin PCI-Express power cable, coming from the Power Supply, and connected to it.
The maximum amount of Wattage a PCI-Express x16 slot can deliver, is 75 Watts.
The 6-pin PCI-Express power cable delivers an additional 75 Watts,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
"This cable is used to provide extra 12 volt power to PCI Express expansion cards.
PCI Express motherboard slots can provide a maximum of 75 watts.
Many video cards draw significantly more than 75 watts, so the 6 pin PCI Express power cable was created.
These high-power cards draw most of their power from the 12 volt rail so this cable provides only 12 volts."
(Yellow wires are 12 Volt wires. Red wires are 5 Volt wires, Orange wires are 3.3 Volts. All are DC voltage. Black wires are Ground wires)
Will your Power Supply have a 6-pin PCI-Express power cable?
I doubt it.
In the Playtool link, see the 6-pin PCI-Express adapter power cable, shown on the right?
Takes TWO 4-pin Peripheral power cables,
(Commonly misnomered as a 'Molex' power cable),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
If you are going to use one of these power adapter cables, you NEED TWO 4-pin Peripheral power cables!
HAS to have TWO Yellow 12 Volt wires going to it.
Will using a 6-pin PCI-Express adapter power cable, and One 4-pin Peripheral power cable work?
Most of the time yes.
PROBLEM is,
Over time the;
1) PCI-Express x16 slot contact pins -> BURN
2) Gold plated contact pins on the bottom of the graphics card -> BURNS
3) Connection on graphics card for the 6-pin PCI-Express power cable - BURNS
4) 6-pin PCI-Express power cable's connector -> BURNS
No if's, and's, or but's; it WILL happen.
Result is usually throw the motherboard away, and the graphics card.
So you may be looking at getting a better Power Supply.
Here is one example that will work,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899124&CatId=1483
A) 600 Watts. Gives you an additional 100 Watts of power. Less strain on the Power Supply.
B) 120mm fan. A larger fan turns slower, therefore makes less noise.
Puts out more air flow than an 80mm fan, even though it turns slower.
C) Has all the power cables required, plus more.
D) Has TWO 12 Volt power rails.
12 Volt 1 is capable of 23 Amp's.
12 Volt 2 is capable of 20 Amp's.
Total combined Amperage for the two 12 volt power rails is 43 Amp's.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01463539
http://h20464.www2.hp.com/media/278E215F-8E76-416C-BBE2-32F7B25FB1A1/xw62_FRU_video_powersupply.htm
Gamer computer?
Not IMHO. Uses ECC ram memory.
That is Error Correcting Control ram memory. The ram memory runs the data through it twice, in order to make sure everything is correct, before using the data.
This is the type of ram memory a Server computer uses.
Could be wrong, and it could be used as a gamer computer, though. We will see when you are done, IF this is the intent.
[ http://en.wikipedia.org/wiki/ECC_memory
Reasons for not using ECC:
"A performance decrease of around 2-3 percent, depending on application, due to the additional time needed for ECC memory controllers to perform error checking;"
Regards,
joecoolvette
1helpful
Can i run new ati radeon 512mb video memory with 5.0 shader card on acer ACER AST690-U-P925A
1) How much Ram Memory do you have installed? If I have the spec's right, your motherboard's maximum amount of Ram Memory is 2GB.
(PC2-5300 would be best, but the amount is what matters, not the 'speed')
2) What is the Maximum Wattage for your Power Supply?
Takes power for each hardware component in the computer.
Motherboard, Processor, Ram Memory, Harddrive, Optical Drive/s, Graphics Card, etc.
When purchasing a graphics card, this is one of the minimum system requirements you need to know.
Spec's I looked up indicate a 300 Watt power supply.
This is the problem. That, and power supply's Acer uses are low quality.
If you had at least a 400 Watt power supply, you could use this,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=41125&Sku=E145-0550
Slap that game around, and make it bark.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276573&CatId=1483
You could also run this if you had the above Power Supply,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2048679&Sku=M452-7770
[Note*
No. It does not matter if you are using DDR2 Sdram ram memory, and the graphics card has GDDR5 graphics memory.
A graphics card runs independent of the system resources.
(Processor and Ram Memory ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
P5p800-mx display problem but power on for this what can i do?
Hi dear, be a professional if you are not, so first of all you should check the RAM(s) and replace them or check it another PC. Secondly, you should check VGA card or graphic card. I hope your problem will be solve.
In the end or last, put away of unplugged RAM(s), VGA card or graphic card if it is not builtin, unplugged all its data cables and main power supply cable and other power connections (with hard disk and cd-rom). Wait for 2 hours and then replace or joint or binding again. It is most possible your problem could be solve if there is problem with your hardware including RAM(s) and graphic or VGA card.
Good Luck
Fails to go to "Setup", does not show on Screen.
1.make sure your monitor is plugged on the video card.
2.check *********** board manual for videocard slots.
3.check your videocard if they nid extra power from four(4) pin
female power cable or six pin female power cable.
4.try using another monitor.. or TV XD
Top Cooler Master Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Cooler Master Computer and Internet Expert? Answer questions, earn points and help others
