Question about Zebra LP 2844 Thermal Printer
Just installed my 2844
When I print a shipping label from Paypal TWO labels come out. One prints the bottom third of the label (no address or return address) the second label prints instructions.
  • 57 Answers
Bask11,
sounds like the printer needs to regap itself. Turn the printer off, hold the feed button down and while holding the feed button, turn the printer back on. As soon as it flashes, let go. It will regap itself. When it stops moving, press the feed button once and there should be a priinted line that says 'out of dump'. The printer should be ready to go then.
Posted on Apr 19, 2008
SOURCE:
Why is the text printing on Zebra LP 2844-Z label incorrectly spaced?
Zebra printers are not really made to print PDF files, if the only option is PDF I'd recommend switching to print on a laser. Also open the PDF and see if they are correct in the original doc
Oct 06, 2015 | Zebra Office Equipment & Supplies
Is it my pc or my zebra printer?
Go into printer options and select "Fit To Page"
Sep 07, 2017 | Zebra LP 2844 Thermal Printer
I have the zebra lp 2844 i'm trying to print from ebay everything is working ecept when i print the label only two line print. i did a test page and it comes out fine i have calibrated the printer and...
Check that your printer setup software is "setup" correctly (AKA printer properties in "control panel" or "devices & printers").
Look at the "label size" and orientation (portrait or landscape) in the printer setup, that may be wrong and cutting off the rest of the printout. If you indicate more printer buffer size that what there is, that to might cause problems.
Other things to check for: Do you have the correct print driver for your OS?
Make sure you have the correct printer selected in Ebay. I don't use Ebay to print labels out with my thermal printer, but I use paypal and I believe they are very similar if not the same. Also, in paypal anyways, you have to have the correct run-time version of JAVA installed in order for it to work properly. Don't know about ebay, but that might be something to look into.
Jun 15, 2011 | Zebra LP 2844 Thermal Printer
Print labels created in ms access
first check your driver for zebra 2844 it is compatible with the OS, if it's Ok may be you can find third party software that help us create label
May 13, 2010 | Zebra TLP 2844 Label Printer
Printing labels from ebay but they come out blank
If you got a blank shipping label, kindly double check first the ink of your printer. Then you can go ahead and reprint the shipping label. Please follow these steps :to reprint your label:
1. Log in to PayPal at:
https://www.paypal.com/.
2. Click the "History" link.
3. Find the transaction you want to print the label for.
4. Click the "Details" link for that item.
5. Click the "Reprint Label" link at the bottom of the page.
Feb 04, 2010 | Dymo LabelWriter 400 Thermal Printer
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
Jun 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
We just purchased a DYMO 400 label printer and I am trying to set it up so that we can print existing labels to it. We have hundreds of word documents formated to print labels on 8.5x11 label sheets. Each...
Your dymo labelwriter came with an add-in for word. just highlight the addresses you want to print, click the little label printer icon in the toolbar and it'll do the rest
Dec 30, 2008 | Dymo LabelWriter 400 Thermal Printer
TLP 2844 skips over labels
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
May 07, 2008 | Zebra TLP 2844-Z Thermal Label Printer
UPS Thermal 2844 Connection problem(USB)
Add the printer as a Local LPT1. Then go into the properties and switch the port to a USB port. Try a test label. If it doesn't print, go back to properties of the printer and switch it to another USB until it does. If all else fails there is a remove utility included with the Zebra drivers you downloaded. You can remove all zebra related drivers and printers and then reboot. The PC should redetect the printer when you turn it on.
Feb 21, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
497 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
