Question about Bosch 24 in. SHU43 Built-in Dishwasher
How to get to the control panel
I need to replace the control panel but I can't get to the old one. Took out 4 screws but I can't get the cover off. Any suggestions
  • dsarthur Mar 12, 2008
    I got the door off put I can't seem to get the control board out. there were two screws in inside of the panel that I took out but I don't want to force the old control board out for fear of breaking a piece that is needed to put the new one in. What is holding the old control board in place?
    I have the door off but know I can't get to the control board What is
    hold it in place? How can I get the front control panel off that is
    covering the control board? I don't want to force anything for fear of
    breaking something.
    Novelist:
  • 131 Answers
Bosh is very tricky. You will probably have to remove the outer door panel first. #15 Torx screws all around the inside of the door panel. Support the panel with your feet while you remove the bottom two screws. (Do those last!) Close the door. Then slide the door panel down about 1 in and pull away at the bottom. Notice the two plastic blocks near the bottom of the door and how they fit onto the door frame (they never stay in place!)
If the console is not loose already, remove the two #15 Torx screws on the upper sides of the door panel.
When putting it back together, put in the screws across the top of the console first, then the door panel, then the rest of the screws.
Posted on Mar 11, 2008
Bosch SHE55M16UC/64 Dishwasher replacing control panel fascia or cover. How to remove chrome handle cover from old part and reinstall it?
You will have to take the door apart. Be very careful not to break any clips. The screws for the handle are on the inside of the door.
Mar 13, 2014 | Bosch Dishwashers
Driver side mirror replacement
Instructions1.
    • 1
Remove thedoor panel. Refer to your Honda Accord repair manual for theinstructions in removing the door panel. Unhook the rods and connectors on theinside of the door panel and set it on the floor.
    • 2
Remove thefilm covering the access to the side mirror. It's difficult to avoid damaging thefilm while removing it so you will need to purchase a new piece of filmcovering when you buy a new side view mirror.
    • 3
Reachthrough the service hole into the mirror housing with a screwdriver. Loosen thescrew that holds the mirror. Twist the screw out with your hand.
    • 4
Reacharound the door and support the mirror with your other hand. Continue to twistthe screw out, then catch the mirror as it drops out when you remove the screwcompletely. Put the screw in a safe place so you don't lose it.
    • 5
Installthe new side view mirror by positioning it where the old mirror was. Insert thescrew you took out in Step 4 and twist it in with your hand. Insert ascrewdriver into the service hole to tighten the screw.
    • 6
Replacethe film covering that was damaged when you took out the old mirror. Push itinto place in the indentation on the door.
    • 7
Sit in thecar seat and adjust the mirror so you can use it properly.
Jul 06, 2012 | 2005 Honda Accord
How to replace belt on samsung dv218ae
Hello & Welcome to FixYa
Please follow the step by step instructions for belt replacement given in this video:
Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Samsung DV218AEW Electric Dryer
How do you put on a power supply board back on correctly
you need to look at the connectors that are from the other boards that you removed when you took the old board out. then just place your new board in and screw in the screws and plug in the connectors
Jun 19, 2010 | Akai LCT3201AD 32 in. LCD Television
I need to know how to get to the dashboard lights to replace them
Project: Replace dashlight behind odometer (PRNDL) light. 2001 Ford Escape.
Time: 10 to 30 min.
Tools: Nut Driver 7mm or (small 7mm socket, socket wrench and small extension)
Cost: $1.50 to $4.00 (cost varies due to location - or so I was told, mine was $4.00)
Screws to remove: only 6 on the 2001, all the same head size, thread size and length)
1. Remove two 7mm hex screws on display panel cover (top, underneath)
2. Put on parking brake, engage key (do not start), move PRNDL lever to L to get out of way.
3. Pull the bottom part of display cover straight toward you (there are 2 clips, one on either side of the steering wheel behind the display assembly cover that will snap free - takes a little force - Do one side at a time) Remove and set aside. This reveals the four display unit screws.
4. Remove the four 7mm screws on the actual display panel. (fyi: all screws in this project are the same head size, thread size, and length)
5. Tilt top of display panel toward you and remove the three top connectors (they come out easily and are in a cable harness so you can't put them back wrong) You will need to squeeze the middle gently, unlocking connector and pull)
6. Pull out display - which includes "glass" covering - this never gets removed! (adjust steering wheel to lowest position if needed)
7. On the rear of the panel you will see several (little grey) knobs. Find the one right behind the odometer and using a pliers, twist counter clockwise 1/4 turn and remove. The little light bulb is encased in these little knobs and is included as a one-piece replacement for the $1.50 to $4 bucks.
8. Replace bulb assembly by inserting the bulb and turning clockwise 1/4 turn.
9. Assemble following reverse instruction of above.
* This all sounds a lot more complex than it actually is. These steps each only take a minute or so. The most difficult part for me was pulling out the display assembly cover. Took me a few minutes to figure out that there were clips on either side of the base of the display cover and what pressure was needed to pull them free. (it does take a little effort at the base of the display to pull free)
All in all this took me about 15 minutes to remove and about 10 minutes to replace, but I had to find socket size, snap locations of cover, etc etc....
Please feel free to cut and paste this article to any other boards with the same question. I hate to see people getting "ripped off" for a simple 4 dollar job anyone can do.
Jun 18, 2010 | Cars & Trucks
No heat from driver side
The vent actuator door may have gone bad and needs to be replaced. The common problem is not the motor but the actuator gears crack and break, but try to reset the actuator buy disconnecting the battery and reconnecting it first, but make sure the radio is turned off before you do that. If the actuator lost it's position, this procedure will reset the actuator's position if it's lost and don't know where to turn the vent doors.
This is how to replace drivers side or the passenger side actuator. Passenger side difference is noted at end of this letter. My 2000-2005 Chevy Impala driver side climate control was stuck on cold, no matter where I switched it to. The light on the panel was also out. Resetting by disconnecting the battery did not work. I had to buy and replace the drivers side actuator (Part Number 15844096 - $38.46 at Chevy dealer). The passenger side actuator is also the exact same part number. They are both located under the dash, about equal height as the climate control knobs. Make sure you disconnect the positive cable on the battery before removing the switch. Drivers side actuator is accessed by removing the bottom dash cover on the drivers side. Two easy clips to disconnect the dash cover, remove the floor courtesy light by twisting, and the cover comes right out. The drivers side actuator is harder to work on than the passenger side, due to room. But I replaced my actuator with only having to take off the bottom dash cover. There are two screws holding the actuator on. I used a 1/4 hand driver with a 3" extension, a 1/4 universal joint for the 1/4 socket (and the universal is needed), and a 7/32" socket. These were the only tools I needed. After unscrewing the two screws, I pulled the actuator off of a small arm it is connected to which switches the flap for the climate control system between hot or cold. I then was able to let it hang down, and disconnected the wire running to the actuator. Room was an issue, and I did some of this by feel. Now comes the tricky part. The new actuator has to slide back on the small arm, but it is flat on two sides, with rounded ends. The new actuator has to match the flat ends to the same position as the old actuator. I hooked the wire onto the new actuator, and let it hang down. I held the old actuator up by it, and had my wife hold the battery connector to the battery to get power. The new actuator will rotate when the connection is made, and stopped rotating when I had my wife pull the connector from the battery. It took a couple tries, but I finally got it to stop at the same position as the old actuator. I then lined up the new switch, and got it on the control arm. This took a few minutes and tries, as I had to do it by feel. I then put the two screws back in and tightened them down. Again, tricky due to room. Once done, I put the cover back on, reconnected battery, and warmed up the car. Was very happy to find that I now had heat on the drivers side, as Canadian weather is cold this time of year.
The whole job took me about an 1 1/2 hour to do.
Also, note if you have to replace the passenger side actuator, you need to remove the passenger side bottom cover on the dash. You then remove the glove compartment door by removing the five screws on the bottom of the door. Slide the whole glove compartment door out of the car. You will be happy to know you have much more room to replace the passenger side actuator, so it should be much easier and quicker than the drivers side.
Good luck and you may want to inspect the passenger side actuator also.
Dec 11, 2009 | 2004 Chevrolet Impala
Remove/replacing side view mirror on a jeep grand cherokee
    Remove the Old Mirror
  1. Step 1 Disconnect the negative battery cable before you take off the grand Cherokee front door trim panel. Remove all screws and clips.
  2. Step 2 Detachthe window trim cover screw, and control lever screw beforedisconnecting the entire mirror trim cover. Remove the rubber coverinside the mirror cover, and disconnect the electrical wire.
  3. Step 3 Remove three nuts from the power mirror using a Torx® star-shaped screwdriver.
  4. Step 4 Pull out the outside rear view mirror. Guide the power wire through the hole in the door.
  5. Install the New Mirror
  6. Step 1 Replace the old mirror. Put the new power mirror in place. Push the new wiring through the hole in the door.
  7. Step 2 Install and tighten the three retaining screws you took off when removing the old mirror.
  8. Step 3 Connect the power mirror wiring to the connection located on the door panel. Replace the rubber cover and interior mirror cover.
  9. Step 4 Put the front door trim panel back in place by securing all clips and tightening all screws.
  10. Step 5 Connect the Subaru Outback's battery cable to restore the power.
i will recommend i site where you will get all the information you need to remove and replace your side mirror
http://www.wjjeeps.com/mirrors.htm
Sep 10, 2009 | 2004 Jeep Grand Cherokee
Frigidaire FEF369CGSA ramge- replace clock overlay/control labels
Hi Dagmail543
You can only access the old unit by removing it from the back of the panel.Some screws and clips (base at the two sides) The clock is usually secured with screws. - remove old unit replace with new - no peel or scrape usually necessary
Regards
Aug 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore 90 Series Washer
this came from my research of the web...
Lid switch broke off (plastic housing broke in half at the screws). This definitely gets easier after doing it just once. Took me a while to figure out I needed to pop off the plastic caps on the sides of the top control panel, to expose the two screws that others mention. Remove the two screws, lay the control panel forward exposing the two metal clips on top holding the cabinet in place. Unhook the clips, voila. The plastic connector of the replacement switch didn't exactly match the old one so I cut and splice (wire nuts and tape). Cleaned everything well while I had it all apart. If I ever have to do this again, it should take a fraction of the time.
im sure its the same as yours.
tnx 4 using fixya,
drcool
Sep 23, 2008 | Washing Machines
How do i change light bulb for my oven
Here is a simpler method from the same website mentioned in solution #1:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
By the way, the bulb is Osram 64405S. It's available online for about $2.00 plus shipping.
See more info. at: http://www.howtomendit.com/answers.php?id=51232
Mar 13, 2008 | KitchenAid KEMC378KSS Electric Double Oven
Bosch 24 in. SHU43 Built-in Dishwasher Logo
291 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
