Question about Sony KP-57HW40 57" Rear Projection Television
6 yrs old went dead
6-8 Sharp Green Flashes then one last bright green flash and went dead.
Wait a while and it comes on and repeats the same thing.
Will I be worth fixing or should I just buy a new one?
  • Sony Master
  • 8,617 Answers
Try unplugging the green CRT circuit board making sure the board isnt touching anything then try powering up the set. If it doesnt shut down the green crt is shorted. about 350 for a new tube.
Posted on Mar 24, 2008
SOURCE:
TV wont start up, blue power icon flashes 3 long and 1 short flash repeatedly
You need to reboot the tv. you've had a signal drop which locks up the tv. call sharp techicon1.png support and they will talk you through a reboot.
Apr 19, 2014 | Sharp Aquos Televison & Video
My Sharp Aquos TV went off whilst we were watching it and won't come back on. The red power light flashes twice per second and the green OCD light flashes three times every second. Is there a re
Tries tv unplug replug the tv back about an hour later,might resetting the tv back factory setting and should work again.Still have the problems,the main board it is shorted and dead require changing.The main board that board were the incoming broadcasting signal wire plug into it.U have some basic machanic skills like take things a parts and putting it back together again.Should have no problems change this board at all..Tried websites like Shopjimmy.com,eBay.com to buy a refurbish main board for the replacement.
Feb 24, 2013 | Sharp Aquos Televison & Video
Sharp LC -46SB54U will not turn on. The green power light flashes twice, then the green power light and green OPC light flash once together. This pattern then repeats itself over an over again. The tv is...
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Do take care.....
Jun 16, 2011 | Sharp LC46SB54U 46 in. LCD TV
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Canon i350 printer won't print; alternates flashing green/orange.
Sounds like the printer head is clogged or damaged.
I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
Hope this helps.
Oct 25, 2009 | Canon Office Equipment & Supplies
Philips 42pf7621d/10 dead
One of the circuit boards should be replaced inside, probably the power supply, the good thing is that screen is ok and it's a most expansive part, you can take it to the local repair shop for diagnostic and repair.
Oct 10, 2009 | Philips Televison & Video
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Jan 26, 2008 | Audio Players & Recorders
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Sony KP-57HW40 57" Rear Projection Television Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
