Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Taking off shell of washing machine
Can not figure out how to open the shell to work on it
    Novelist:
  • 131 Answers
Remove the shell:
nplug the machine. Remove the end caps on both sides of the console by putting a flat screwdriver in the top of the end caps from the back and gently prying up. Remove the two Phillips screws holding the corners of the console down. Lift the console and gently fold back. Unplug the lid switch. That's the 3-wire quick disconnect below the timer. (If you have a high price model, you'll have three hoses under a plastic cover on the left. disconnect those hoses before going further.)
Using a flat screwdriver remove the gold clips holding the cabinet to the back. Place the blade of the screwdriver in the indentation closest to you and tilt the handle of the screwdriver back.
Open the lid. Lift and tilt the entire cabinet toward you. Look down through the hole to the front bottom edge of the cabinet. It is hooked under the front edge of the washer frame. Remove the cabinet and place it aside.
Replacing the shell:
Pick up the cabinet, hook it under the front of the frame, and tilt it back into place. Push the sides of the cabinet in as you are tilting it back to make sure the hooks in the frame (back, sides) line up with the cabinet. You can know it's in place when the edges of the cabinet line up evenly with the edges of the back.
Re-install the gold clips. Hook them into the back panel, put them into the slots in the cabinet, and push down until they snap into place. Re-connect the lid switch. Lower the console. Replace the screws. Replace the end caps - bottom first, then snap them in at the top.
Happy washing!
Posted on Mar 11, 2008
How do you get to the drive belt?
Some washing machines are not accessible without taking the whole outer shell off!! But most if.you.empty then lay it on.side u maybe able to get to the belt or some.have an.access plate on back good luck
Oct 11, 2014 | Washing Machines
The spinning part is loose where do I open the washer to repair it? take all the screws out of the back???
If the bowl is loose you needed to replace the bearings, first take off the to part with the knobs, then you should be able to remove the while body our shell of the washer to get to the meat of the washer, this us how you get inside.
Jun 08, 2011 | Kenmore 24032\24036 Top Load Washer
Disk stuck in j drive, no pin hole
GO TO DEVICE MANAGER AND SEE IF THE DRIVE IS WORKING.IT MOST LIKELY IS SO TURN POWER OF PC OPEN THE SHELL ON PROSESSER AND TAKE DISC OUT,KNOW BEFORE YOU PUT SHELL BACK ON TURN POWER BACK ON DO NOT TOUCH ANYTHING EXCEPT THE DRIVE SEE IF IT OPENS OR CLOSES.IF IT DOES NOT,SHUT POWER OFF AND UNPLUG DRIVE THEN PLUG IT BACK IN.PUT SHELL BACK ON AND SEE IF DRIVE OPENS.IF NOT THE DRIVES FAULTY...HOPE THIS HELPS
Nov 30, 2009 | E-Machines emachines (emachinees) CD-ROM...
Whirlpool LSR7233 How do I get the outer shell off to fix??
There are screws on back top and back bottom that have to be unscrewed for the panel to pull off
Jan 16, 2009 | Whirlpool LSR7333 Top Load Washer
Need to remove outer sheel to get access to drain pump
first remove the two screws that hold in the control panel and tip it back, then there two clips that the shell is locked onto undo them and pull the shell away from the unit. remember to shut off the power first. remove any wires that are hooked up aand the replace the pump. good luck
Jan 11, 2009 | Roper RAX4233PQ Top Load Washer
Spring not hooked on to fram
is this the spring in the back if so look in the very back center bottom and you will see where the hole use to be but it probably rusted out just take like 1/4" drill bit and make another hole Please rate my solution
Jan 05, 2009 | Washing Machines
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
I took the cover off to wash it but now can't figure out how to put it back on. I think it is a 5 point connection system model 8465wsr3
Its a GREAT seat! I have the same one!
Assuming you removed the harness.
The easiest way I have found to do this is , place the seat on the ground and put the cover on the seat. There are some elastic fastners that are loops on some models, that go onto small plastic poles. IF you don't have this, it is ok.
Then clip the harness together at the chest clip, and at the buckle. This helps you not get so twists.
Put each of the top shoulder straps through the hole in the seat cover AND the plastic of the shell of the seat. For this rear facing seat, the straps should be At or BELOW the shoulders of the infant riding in the seat. When both straps are through the plastic shells, you slide them onto the metal flat mushroom shaped piece on the back of the seat that is attached to the adjustor strap.
Pass the middle strap (the buckle) through the hole in the seat cover and shell. Pull to ensure it catches.
NExt, take the small metal cliped bottoms of the harness, and pass them through the seat cover and seat shell in the bottom of the seat, they are in the crease of the side/bottom of the plastic shell. Once they are passed through, give them a good pull to ensure they catch. Repeat for the other side, and you are good to go!
If you washed the harness, in the machine, it needs to be thrown out, call Graco for a replacement.
Jun 17, 2008 | Graco SnugRide - Giselle Infant Car Seat
Screw inbetween the drum and the outer shell
if you take the rubber empting tube off the bottom of the drum you can work the screw down to the bottom and out of the hole. ensure all electrics are un plugged obviously.
Jun 14, 2008 | Tricity Bendix AW1400W Front Load Washer
Bissell Big Green Machine Model 1672 will not pump cleaning liquid
have a Bissell Big Green 1672, the older canister model. Went crazy trying to figure out how to get to the pump. Finally figured it out. The top green "shell" covers the motor & pump and is separate from the "grey" plastic housing. Using a screw driver, insert it between the small gap between the top "shell" and the housing. If you look at it with it laying down on the top, you will see the small 1/4" gap. Gently pry in between the two and work your way around. It will start to lift up and then you can easily work your way around and it will pop off exposing the motor and pump. Note that the wires to the on/off & pump switches will sill be attached to the top shell. If you take them off note where they came from and make sure they are all on when you put the top back on. I have had my Green Machine for years, what a work horse! To bad they don't make them anymore, the new ones that replaced them just don't have the same durability and power as the older Green Machines.
Dec 19, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
321 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
