Nokia N72 Cellular Phone Logo
Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nokia n 72 was hang & also airtel sim is not valid in my phone.
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Mar 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
515
Points
10
If you have warrenty u better take it to a nearest nokia customer care centre..........
Anonymous
Level 2:
  • Expert 184 Answers
  • Posted on Mar 22, 2010
Anonymous
Expert
Level 2:
Answers
184
Questions
0
Helped
68949
Points
577
You have complaint about your handset in your nearest nokia care he can help you and you have satisfied with nokia care service.
Thanks.
Aman.
  • Anonymous Mar 22, 2010
    please go in your nearest nokia care and ask your problem he will solve your problem and then your phone is start it.
    Thanks.
    Aman
Nokia c7 dont show airtel network with airtel sim
No point contacting contacting airtel customer care, because your SIM card is working perfectly on different phone so I'd suggest you to reset your mobile phone once, that can fix the problem for you. If the issue is same, take your mobile phone to nearest Nokia service center.
What is pin code of nokia 6070 of airtel sim. I have enterned PUK code and the PUK code is on now they are asking for 'New PIN code' and then 'Verify Pin code' so what...
Hi actually the code should be provided by the network provider,anyway just enter 0000....I hope this will solve your problem.Good luck.Thanks for visiting fixya
MY NOKIA N 72 MOBILE HANGING WHEN STRAT MOBILE
Dear Friend
If You Do Not Made A Reset Just Do Reset You PHone By Using This Hard Reset Code But Before That Copy You Contact & SMS in Sim memory because after that might be it will get lost
Switch off the phone
pull out the memory card
sim Card
& then
type this code
*#7370#
After that start the phone without memory card
sim Card & Setup Settings & then switch it off and insert all the things
(advice)
But unnecessary contain should be out from your mobile time to time and virus scan after 2 weeks it keeps you golden mobile for life time faster smoother and working
your friend
samadhan
1helpful
2answers
What is the puk code of nokia 3110c sim no 03222371504 fast fast plz plz
Few people use PIN locking system to lock their phone to avoid un-authorised access. Though this is a good option, it pisses you off sometime. Three wrong entry of PIN code will result in SIM blocking. Once SIM gets blocked, phone starts asking PUK code to enter. If you again enter wrong code for three times, SIM gets completely blocked. You have to walk into your service provider outlet to get a replacement SIM card.
PUK code is a SIM specific code assigned by your service provider. No way you can guess & enter it. So, when it asks for the PUK code, don't do anything, get the PUK code from your service provider. Airtel has a easier way of getting PUK code. For getting PUK code of a Airtel number, send PUK<space>PhoneNumber to toll free number 121. You can make use of any other Airtel number to send this message since your SIM might have been blocked already.
If the above method doesn't works or your service provider is not Airtel, call to customer care using any other mobile phone which uses the same service provider. They will ask some details about you to make sure you are the owner of the SIM card. Questions might include your billing address, email ID, numbers you recently called or messaged etc. They might even ask you number printed on the SIM card, so be prepared with all details before calling them. Once you get the PUK code, enter it into the phone & your phone will return to normal
Airtel sim not work
There are various network specification for each operators like airtel, BSNL, etc
Nokia 3110 supports GSM 900 / 1800 / 1900 so Airtel SIM card should work in your mobile.
Try using some other airtel sim cards and some other sim cards from other vendors as well. SOme times the problem with network chip may also cause this problem. so in such case, you can approach nokia service center to claim under warranty.
Please rate the solution
Thanks
1helpful
My airtel sim has been blocked 9731089716
Hi vsk, its a common problem. Dial 121 from any Airtel connection phone or use 9831098310 from other phones then select your language & talk with customer care person. They will asking you some question for confirmation about your phone no. After that they will fix it from Airtel server.
Thanks & waiting for your feedback.
4helpful
3answers
My nokia 2630 cell phone is only accepting airtel sim
check whether is locked for the network(airtel)
If you by your phone on airtel offer it might be blocked by them (airtel). You need to format the software and reinstall the software.
Airtel sim is not supported in my nokia 3110c
go to settings .. phone settings .. thn operators selection ... manual ... and u check the network ... and see if airtel is available in ur loacality .... if availble .. th ni twuld work ....
1helpful
2answers
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
