Question about Airnet AER114 Router
Haveing problem using my router
I am not able to use my router its not letting me get online or hook up my computers to it at all. Can someone please give me call and let me know what the problem is.
Thanks, roxie ortiz 281-762-8401
  • Anonymous Dec 13, 2008
    same s above
How do i hook up my linksys wireless-g broadband router wrt54g-someone disconnected it
Disconnect the power to each unit (except computer, shut it down). After you connect the modem,router and computer, power up the modem,then the router,then the computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Hook it up per this diagram:
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 20, 2011 | Computers & Internet
My netgear router gives off wifi but it doesnt let me on it says problem applying profile
Please check that you can go online with your modem,
once you can go online with modem then connect modem to router and router to computer with cable
and reconfigure
after that you would be able to go online w/l
Hope this will help you
Jun 26, 2010 | NetGear WNR1000 Router
Please help me install the above router. I bought
First connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
If you cant access it with above link then reset it to defaults.
For that check in back panel of router you find reset button press it for 10 seconds so all settings goes to defaults.
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page for router.
Enable dhcp if you want to get ip from router.
check wireless settings .
Check wep password if it is enable for security.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless on my desktop,trying to use another computer in dining room that has a router or rooter dont know what it is, cant get online please help,the wireless rooter is connected to my main...
You do not need 2 routers to connect to the internet infact you need only 1. having 2 conflicts with pcs and causing them not to work.
From the wall you have your cable fro your internet that plugs into your modem, from the modem it plugs into the router by ethernet cable to the uplink slot and then your computers connect to the router. Most routers can connect 4 computers at once. If running them all wirelessly just reboot them and they should connect automatically. If your wiring them plug them into the back by an ethernet cable in the slots 1 for the first PC, 2 for the second so on and so on. You may have to cold boot everything at first meaning shut down all the computers, unplug the router and modem. Then Plug in the modem let it boot up, plug in the router let it boot up then the pcs.
If you need more hook ups if 4 isnt enough yo uneed a switch or access point not another router.
Let me know If this helps and if I can help further.
Joe
Apr 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
Trying to get online but cant
You have to make sure that the router isn't still loading, to unload it you need to hook the internet to a local computer in your house. Just get on any website and then hook it up to your PS3 and it should work.
Jan 30, 2009 | Sony Playstation 3 (PS3) Console
Router not hooked up properly
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed.
then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Hook up
Hi Cheryl,
From your cable/dsl modem please take the cable that comes out of it that looks slightly larger than a phone cable and plug it into a port on your NetGear Wireless Router that is labeled either Internet or WAN. After that is done, unplug the power to both your cable/dsl modem and your wireless router. Plug the power back into the cable/dsl modem and wait about 30 seconds then do the same with the wireless router.
Next on your computer, there should be a wireless icon by your clock near the bottom right corner of the screen. If you double on it, you will see a list of connections, yours will say Netgear and should have a good signal strength. Double on it and give it about 10 seconds to connect. Voila, you should be on the Internet.
Please let me know if this solves your problem.
Thanks,
Adam
Nov 28, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
DI 624- Cant connect from router to computer
Hi mark - please don't rate this til it's fixed. Hook it up the way you had it. i.e. modem>router>pc. Try it, probably won't work. Unplug the power on your modem and the router. After 60 seconds plug in your modem. When all the lights return to normal (except the activity light), plug in your router. Give it 20 seconds or so. Try it and let me know what happens. Thanks.
Jeff
Aug 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
G wireless router
First connect your Laptop via wired LAN before you attemp Wireless, then you will easily be able to pin
May 25, 2008 | Computers & Internet
Router
Yea, if you have your initial run CD, use that but here is how you do it.
MODEM-ROUTER-COMPUTER
I
Other wireless devices.
You plug the ethernet cable going from the modem into the plug on the router labeled internet. Then give it a cable from ethernet slot 1 to the computer. You should be good 2 go.
May 23, 2008 | Linksys Wireless-G Broadband Router
Airnet AER114 Router Logo
60 people viewed this question
Top Airnet Computers & Internet Experts
Ekse
Alun Cox
Are you an Airnet Computer and Internet Expert? Answer questions, earn points and help others
