Question about Vivitar ViviCam 5386 Digital Camera
Won't work vivitar vivicam 5386 lens error won't open all the way was not dropped batteries have been checked
  • Anonymous May 19, 2009
    I have the same problem but I actually dropped mine the other day and I don't understand, cause I have dropped it before n ow it wont come out at all..is there anything i can do for this?
    Problem Solver:
  • 13 Answers
Sounds like dirt or something is preventing the lens from opening up. Your best bet is to get a can of compressed air and a fully charged set of batteries and while the lens is oopening, spray the air into the lens opening. If after a dozen tries, then you may need to have the camera checked out. Keep in mind that the cost of a high end tech (taking apart a digital camera is about as difficult as open heart surgery!) may cost more that just buying another one.
Posted on Mar 22, 2008
SOURCE:
Manual for vivitar vivicam 5386
Hi Don:
We have find two choice to doanload this document with information about Vivitar ViviCam 5386 Digital Camera:
- filedetail.php/vivitar-vivicam-5386-manual-eng-zip
The second choice is contact us in this link or clicking over image to send download instructions: Digital Cameras User Manual
I hope this helps; keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 27, 2011 | Vivitar ViviCam 5386 Digital Camera
5386 when you power on it comes up lens error and shuts down?
If the camera hs recently been dropped it may have lens damage that requires professional repair. If it hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Dec 01, 2009 | Vivitar ViviCam 5386 Digital Camera
Lense will not fully retract or extend pics are blurry
hello.
One of these reasons Causes the Problem:
  • Usually it's sand or grit interfering with the lens extension mechanism.
  • camera's been dropped with the lens extended.
  • he camera has been powered on, but the lens had been blocked preventing its extension.
  • the battery ran down with the lens extended
In Order to do somthing about that read this article.
Do It Yourself Digital Camera Repair: Fixing a Lens Error ona Digital Camera.
Thank you.
Good Luck
Nov 03, 2009 | Vivitar ViviCam 5386 Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 02, 2008 | Vivitar ViviCam 5386 Digital Camera
Lens Error
It sound like your lens is either jammed or the motor that causes the lens to open has a problem. First try spraying a can of compressed air around the lens while you turn it on. Also make sure that you are using high output batteries. Digital camera's require high capacity batteries to operate properly but if you are getting a error message then that means that the camera is turning on. Usually if you use regular batteries the camera will just cycle on and off but the lens will come out and go back in. Has this camera been dropped?
Mar 17, 2008 | Vivitar ViviCam 5386 Digital Camera
Blurred pics
you could try 2 things..
check the configuration if its been changed.. the best thing you could try is do a factory reset... there must be an option to set your camera to default values..
the other thing is cleaning the lens with something really smooth, otherwise you could scratch the lens..
hope that works
Jan 30, 2008 | Vivitar ViviCam 5386 Digital Camera
Vivitar 5386
i suggest that you take your camera to a profesional camera shop, like Jessops, and see what they say. if they cannot fix it then just buy a new camera.
Dec 24, 2007 | Vivitar ViviCam 4345 Digital Camera
My Vivitar 5386
have u checked battery? and otherwise i duno
Apr 01, 2007 | Vivitar ViviCam 5385 Digital Camera
Vivitar vivicam 5386
I have had that problem too. All I had to do is change the battery. But don't mix match batteries good luck.
Mar 03, 2007 | Vivitar ViviCam 5385 Digital Camera
Vivitar ViviCam 5386 Digital Camera Logo
127 people viewed this question
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
