Question about Apple iPhone Smartphone
Wont boot starts boot process then stalls on same boot
  • Anonymous Jan 30, 2009
    i have a tmobile dash. last night it froze while browsing the internet, so i had to take out the battery to disconnect power. i even took out the sim card in case that did anything. after letting the phone sit disassembled overnight, i reinserted the battery and sim. now, the phone is stuck in a start-up loop between the 2 tmobile screens and the windows mobile screen. it seems to be shutting itself down and retarting itself continuously.
  • 38 Answers
Restore the firmware with itunes:
hold down the power and home button for 20 seconds, then release the power button while continuing to hold the home button until it saysto plug into itunes, Hook the iphone up to your computer, itunes will say it's found your phone in a restore modeand click restore firmware.
Posted on Jan 13, 2009
My swift wants to start but wont kick over?
which engine? of the many and want country. ?
some are even diesel.
there are 3 phases to this.
cranking robustly
starts
and runs. and may stall soon after. or not.
at what point does this process fail.
if it dont crank we diagnose th starter system.
it fails to start (we check spark , then fuel) if both ok we check for lost compression (cam timing belt slipped>?)
if it stalls, lots more test.. over 50 causes.
this is what a tech does, diagnose. saving lots of time guessing and buying un-needed parts.
tell more, get more. but what engine.'
Dec 09, 2014 | 1998 Suzuki Swift
I turned off my tablet during an update. when it powered back on it wont fully come on. it is stuck on a screen. how do i get it to work again?
need more info ...what screen is it stuck on? what does the screen say? is it an error screen ?what update was the system doing at the time ? .... there are too many reasons why a boot process can stall at a specific time.
Nov 02, 2013 | Samsung Galaxy Tab Tablet PC
Not rebooting
Okay, each OS has it\'s own problems when it comes to this. In most cases it\'s not rebooting (presumably you\'re clicking the "restart" button in windows or reset function in the Mac OSX "xx"). First check to make sure that no software is stopping the process of rebooting. Most often software updates may order the computer to do something that you\'re not expecting, either stalling or even stopping a proper reboot as the new updates are installing. This is especially true of Mac OSX which will update the computer automatically without telling you and then not completely install them until the computer is restarted from a total shut down. The process may produce a blank screen while the updates are installed.
If this is the case you\'ll hear HDD spin up or see the HDD in use light flash (with both SSDs and HDDs). Don\'t interrupt this process or you\'ll create more headaches. Now if it stalls, restart. You\'ll know it\'s stalled because the HDD light will stall and not flash any longer.
If this isn\'t the issue, run diagnostics on your computer. Install and run CCleaner if you can. If it\'s a window\'s computer start up the computer and hit either Tab, F2, F10, or F11, and on the rare occasion Escape to get into the bios and confirm that the hard drives are recognized, the boot order is correct, and that he correct power and control settings are in place. If you can\'t do even that turn on the computer and check to make sure no media is trying to boot. Remove all peripherals from the computer; like CD/DVD/Blu-Ray disks that may be in the optical drive, USB thumb drives and connected external hard drives, any usb connected phones. If you have a non-OS hard drive connected remove it too. Then try to boot. If it then boots you know that either one of the peripherals were interfering with the boot process or that the computer was trying to read from the wrong hard drive which has be set as primary.
If none of these steps solve the issue, start with hardware; check for correctly seated connections, RAM, cables, etc. Look for damaged ribbon, heat damage on the motherboard. Check the power supply. Flash the bios by removing the CMOS battery for a day and then replacing it and restarting the computer.
Check that the hard drives are working and not damaged or faulty. This can be done by connecting it to other computers.
Attempt to start the computer with another medium, like a live CD or USB of Ubuntu.
If the live CD or USB boots, then you can safely assume it\'s a peripheral or hard drive, and not the power supply, ram, or main board.
Lastly, always check the simplest things first. Make sure that the computer is plugged in. Make sure that the monitor hasn\'t been connected to the wrong video output. Make sure the monitor is plugged in and working and on when you start the computer.
There is the best answer I can give you.
Oct 15, 2013 | Computers & Internet
Acer aspire 5736Z wont boot on any recovery options
Try starting up in Safe Mode (Console mode) and type in
"SFC /Scannow"Once its done you should be able to do recovery options.
If not, boot from the windows 7 recovery/install CD and choose "Repair".
Go through the recovery process using the CD and it should all be fine!
Dec 26, 2012 | Acer Aspire 5736z 4460 Laptop
Stalls on boot up
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Dec 30, 2010 | Acer Aspire One PC Notebook
I'm trying to install Vista for a friend of mine on his computer. It uses vista boot loader 2.1.1 (or something similar) The first time it will boot just fine - vista will boot after first start and...
one check the crack make sure it is for what your installing ( i mean ver and sp) if all else fail try a differant crack you know as well as i do they dont all work all the time and check you registry cant tell you here but look in registry file
Sep 24, 2010 | Computers & Internet
Computer stops during start up process to check file system C:
Boot the PC in the safe mode ( Press F8 during the PC start up) and from their launch the command prompt and do CHKDSK /R.
Aug 02, 2010 | HP Pavilion dv6000z Notebook
Emachine starts boot process but stalls, no beeps
most likeley if you see something on the screen but it wont boot it is a mem problem, does it load bios, if so it is prob not memory
Nov 17, 2009 | E-Machines eMachines Desktop PC
Windows xp wont start
start your computer in safe mode by pressing f8 repeatedly during the booting process, then check, if it boots then restore your pc to some previous date where its working fine
Oct 26, 2008 | Evesham Computers & Internet
Booting problem
One beep is normal during the boot process.
Apr 18, 2008 | Computers & Internet
Apple iPhone Smartphone Logo
468 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
