Question about Vivitar Cameras
Vivitar vivicam 5385 digital camera problem lens error won't open all the way not dropped batteries checked
Wont power on even with new batteries please email m e with suggestions www.aol.com
Posted on Oct 17, 2008
SOURCE:
Vivitar ViviCam 5385 Digital Camera drivers
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Sep 01, 2011 | Vivitar ViviCam 5385 Digital Camera
My camera lens won't extract in ?.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Vivitar ViviCam 5385 Digital Camera
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2008 | Vivitar ViviCam 5385 Digital Camera
ViviCam5385 digital Camera
Hi, hi52 - You can download a copy of your Manual from "vivitar.com/en-us/Support.aspx" Just specify your Vivicam 5385 as the Model (drop down and find it). It is 66 pages in A5 format. Before I knew it I was downloading in error and now have it on my Computer!
Apr 27, 2008 | Vivitar ViviCam 5385 Digital Camera
Won't work
Sounds like dirt or something is preventing the lens from opening up. Your best bet is to get a can of compressed air and a fully charged set of batteries and while the lens is oopening, spray the air into the lens opening. If after a dozen tries, then you may need to have the camera checked out. Keep in mind that the cost of a high end tech (taking apart a digital camera is about as difficult as open heart surgery!) may cost more that just buying another one.
Mar 11, 2008 | Vivitar ViviCam 5386 Digital Camera
Lens Error/wont open
Does it experience accidental dropped, or may be it may need a battery recharged..
Mar 06, 2008 | Vivitar ViviCam 5385 Digital Camera
Vivitar 5385 digital camera
Mine was doing this and now it won't even turn on. It turns on, says lens error, then turns off.
Feb 26, 2008 | Vivitar ViviCam 5385 Digital Camera
Lens error
The lens mechanism is damaged.Replace lens assy.
Sep 21, 2007 | Vivitar ViviCam 5385 Digital Camera
Vivitar vivicam 5386
I have had that problem too. All I had to do is change the battery. But don't mix match batteries good luck.
Mar 03, 2007 | Vivitar ViviCam 5385 Digital Camera
Cameras Logo
122 people viewed this question
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
