Di novo keyboard repair
Blue tooth transmitter in di novo keyboard stopped working is this repairable as logietech will not replace now
  • no18ray Mar 11, 2008
    its the keyboard its self that has a problem not the receiver that plugs in to the computer the media pad and moue still work
  • no18ray Mar 20, 2008
    Any other suggestions welcome
    President:
  • 778 Answers
No18ray,
You should be able to obtain any USB Bluetooth dongle to replace the OEM Logitech one that failed. You might want to verify that the transmitter is the problem before replacing it though (if you haven't already of course). Replacing one with and after market/generic one is relatively inexpensive though.
Good Luck.
Posted on Mar 11, 2008
  • Frank  Fernandez
    Frank Fernandez Mar 19, 2008
    I would say that replacing the keyboard would be the easiest way to go, as I don't think you'll easily find a transmitter to replace yours with. If the transmitter is the problem?
SOURCE:
Can i pair my logitech y-x5a77 keyboard with my samsung galexy tab a tablet?
Blue tooth by definition should be able to connect between any units that are Blue tooth capable. Make sure the Blue tooth is turned on on both units and both can be identified.
Some setting you have is incorrect.
Semper Fi,
Z
Feb 14, 2018 | Logitech Computers & Internet
Can i use an external keyboard to access my nextbook with a cracked screen?
Perhaps, when you can setup the blue tooth connection and don't need to install any app before starting the keyboard.
Mar 16, 2015 | Nextbook Tablets & eReaders
My fosmon keyboard case worked with my old router which packed up working but it wo'nt wok with my new router ??
I can't believe the keyboard ever worked with a router. The keyboard worked with blue tooth to your tablet, or with a WIFi or blue tooth dongle in the computer..
Jan 22, 2015 | Computers & Internet
How do I hook up my blue tooth headphones to my onkyo SR 605
You cannot rig up a blue tooth headphones to this receiver with out a blue tooth transmitter ( the Onkyo does not have one built in ). If you have a transmitter it can be plugged into the headphone out socket of the Onkyo ( in front ), just remember that it will cut out the sound from all your speakers when you insert the headphone jack . The advantage though with this connection is you can control the headphone volume using the Onkyo remote.
Mar 12, 2011 | Onkyo TX-DS656 Receiver
My kensington wireless keyboard stopped working. It is part of a desktop set. I have changed the batteries. mouse is still working. all the things I read for trouble shooting says to reset the buttons...
here is what you do, shutdown windows, and start back up, the reset button might be hidden, look under the little tabs that angle your keybord, my reset or connect button is near the battery opening
Jan 25, 2011 | Kensington PilotBoard Wireless Laser...
My Aspire 5100's keyboard, mouse, and USB ports stopped working a while ago... I've read up on this common issue and have tried everything. Its not the battery, I've taken out the keyboard and put it back...
Maybe you can just hit the "connect" button on the bottom of the keyboard an mouse. The infrared USB transmitter/receiver for wireless keyboard/mouse should light up blue.
Aug 13, 2010 | Acer Aspire 5100 Notebook
Lost and cannot regain connection between keyboard and transmitter
If the mouse is still working and only the keyboard is having a problem, then there's no problem with the transmitter.
Here's what you need to do:
1. Try to replace the batteries with fresh ones.
2. Briefly press the connect button on the receiver (if there is), and then press the connect button on the keyboard for 5 seconds.
If same problem occur, hold down both connect buttons (on the transmitter and on the keyboard) at the same time for 5 seconds, then release it.
If nothing happens, then you need to send the keyboard and transmitter to the manufacturer for repair. There's a hardware defect on the keyboard.
Thank you and good luck!
Jun 13, 2010 | Logitech Cordless Desktop MX3200...
Have new lap top [toshiba satellite] have connected tomtomgo 520 twice and on both occasions my wi fi connection has been disabled
Built-in FM Transmitter to transmit sound over own car stereo and lets not forget Best hands-free calling> Best guess is that your computer is finding and trying to connect to the blue tooth connection since Toshiba has blue tooth capabilities, also you could be losing the wifi signal just because the FM transmitter is overpowering the the wifi signal. If i had to guess though i would go for the blue tooth connection as being the problem. Hope this helps
Apr 26, 2010 | Tomtom GO 520 GPS Receiver
My dell wireless keyboard just stopped working. I
if your mouse is working. it would be the keyboard it self.. cause dell has bout wireless mouse and keyboard.. do you have warrenty on your system.. dell can replace the keyboard for free..
Dec 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My dell keyboard with blue tooth connection
If there is no light on the Bluetooth keyboard it means there is a problem with it.
If the Bluetooth keyboard is not responding try to do the following:
1. Change batteries
2. Go to control panel
3. Click Bluetooth Icon
4. Delete the Bluetooth Keyboard
5. Click on Add new wireless device
6. Press the pairing device on the keyboard
7. Bluetooth keyboard will be detected
8. Follow the onscreen instructions
Hope this helps, Tried it several times and it works perfectly
Nov 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Open Questions:
Aol verizon tech support -*+1*{855~536~5666}.*'- -Aol verizon Toll free Number- Nvnb Aol verizon is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Aol verizon email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Aol verizon support number When you are using the Aol verizon for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Aol verizon support number and ask for the help. Once you dial the Aol verizon customer support number, you come in contact with a team of experts at the Aol verizon customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Aol verizon support phone number will help you with that simply and quickly. This is Aol verizon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Aol verizon agent. Features of Aol verizon support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Aol verizon customer support phone number. Here are some of the features of customer service: The Aol verizon customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Aol verizon customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Aol verizon provides you the facility of Aol verizon support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Aol verizon. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Aol verizon Customer support number team.
Oct 18, 2019 | HIS Computers & Internet
Computers & Internet Logo
147 people viewed this question
Ekse
Alun Cox
