Question about Cell Phones
I can't connect Verizon Gleam SCH-U700 to Parrot CK3100
When I try to pair the 2 devices, the Parrot says "pairing successful", but the phone doesn't. The phone finds the CK3100 in it's search but won't pair up. Phones pairs ok with laptop and Motorola headset. I downloaded latest firmware to the CK3100. Any ideas?
  • Anonymous Mar 31, 2014
    Was working fine pairing with my phone until I downloaded an app to listen to a radio station. Now it won't pair with phone and gives me a message that a password is needed.
This solution came from Parrot Tech Support and it worked for me:
We were able to get the two to pair using the following steps:
The phone will stay saying pairing, then the parrot will say pairing successful, pull the battery on the phone, when you turn it back on, the phone will display PARROT CK3100 WANTS TO PAIR, ACCEPT? Say YES.
Posted on Mar 12, 2008
I paired my SGH-U700 phone with the CK3100 kit, however, when it tries to connect, the phone automatically turns off then back on...5 seconds later, it goes off again and back on...while the CK3100 just says "SGH-U700 DISCONNECTED"? Please help!
Posted on Jun 25, 2008
Will not connect to phone
Try deleting all paired devices first, Menu / settings / paired devices. The remove the battery from your mobile phone for ten seconds. Then try pairing again, this should do the trick, if not the parrot may need a software update.
Nov 24, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Paired backberry 8520 with parrot ck3100 but contacts will not syn with parrot. tried to transfer contacts to parrot but message just says refer to handsfree maunal .have looked into this with no luck...
Hello chicks,
Pairing both devices from the Parrot Product:
Select Setting / Advanced Settings / Pair with phone / Other phones
* From the phone:
* Select MENU / OPTIONS / BLUTOOTH / ADD DEVICE / SEARCH
* The phone will search for available devices
* Select the Parrot Product name from the list, and enter the PIN code '1234'
* The phone will pair with the Parrot Product and auto connect
Sending contacts via Bluetooth For all contacts sending
* From the phone:
* Select MENU / MANAGE CONNECTIONS / BLUETOOTH OPTIONS
* Select the Parrot Product from the list of paired devices and go to OPTIONS / TRANSFER CONTACTS
May 07, 2011 | RIM BlackBerry Curve 8520 Smartphone
When pairing my nokia e71 to my parrot ck3100 it keeps coming up memory full
> there are number of devices that can be paired up on your parrot Ck3100.
> try deleting some of those paired devices that you are not using already and then pair your E71 phone.
Aug 29, 2010 | Nokia E71 Smartphone
I have a new phone nokia 6303 and tried pairing with my parrot ck3100 and it will not connect. It asked for a passord on the phone I typed in 1234 but it comes back with pairing rejected by other device?
you need to go to settings / paired devices / delete any old phones that are still stored as the parrot will only allow 5 paired devices. then try again. You may want to check your software and if your software is over 12 months old it will be a good idea to update your parrot, try parrot.com/support for more.
Dan
Mar 02, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Memory full on Parrot CK3100
turn ignition on in car push and hold green and red buttons together fro 10 seconds, the kit will say memory erasing in progress, then please pair device, then pair phone..
Sep 06, 2009 | Parrot 3000 Evolution Advanced Bluetooth...
Pairing a Parrot CK3100 to Iphone 3GS
My iPhone 3G is now connected. Did 3 things:
1. Deleted every existing paired device on the Parrot CK3100.
2. Pressed all 3 buttons at once. Parrot CK3100 screen lit up and buttons lit up after about 5 secs. Turned car engine off. Parrot switched off. Turned car on again.
3. Went to settings, advanced settings, pair device (and also switched on iPhone bluetooth) and tapped Parrot CK3100 on the iPhone screen (which had now appeared) - phone connected.
After about a minute sync iPhone phonebook appeared on Parrot.
Hope this is helpful.
Jun 27, 2009 | Apple Cell Phones
Nokia 6500 will not pair with Parrot ck3100
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Parrot device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 28, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Pass code parrot ck3100
what is the code for my parrott ck3100 for my sprint phone
Apr 28, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Connection
Try deleting all paired device from the parrot and your phone, remove battery from you phone to reset it. Then follow below instructions from Parrot.
Pairing Devices: ** From your car kit:
** Select SETTINGS / ADVANCED SETTINGS / PAIR WITH PHONE / OTHER PHONES
* From the phone:
* Select MENU / SETTINGS / BLUETOOTH / MY DEVICES / SEARCH NEW DEVICE
* Select CK3100 from the list of available devices and enter PIN code \"1234\"
* Phone and CK3100 are now paired. Wait for auto connection
Feb 04, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Cell Phones Logo
721 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
