Question about SanDisk Sansa c200 MP3 Player
Music Input i Tried putting any music on it and it just won't work a message comes up and says 'file directory couldn't be created' i just have no idea what to do any help from anyone?
You have to put only mp3 and wma songs on it..
Posted on May 17, 2008
Trying to move downloaded music from my music file to drive ''f'' get a message that it will not work as file or directory cannot be created. How do I get the music to drive ''f''?
I take it drive 'f' is a USB flash drive. If so it should appear as a removable drine in "My Computer" If not there, Try it i another port or better still another computer. You may already have too much stuff on f drive too. Check that all the drive's capacity is available and not used up.
Apr 07, 2010 | HP Electronics - Others
USAGE OF MEMORY CARD
I am thinking that you need to put the files into a specific directory. For example, for my HTC Hero, I have to create a directory on my SD card named Music. Other brands may have different requirements for the phone to recognize your media files.
Check with your phone's manual or do a Google search.
Good luck.
Mar 23, 2010 | PNY 2GB microSD Memory Card
Mp3 files don't appear in music player, i inserted a memory card with some mp3 files and they won't appear in the music player, i tried putting them in different directories on the card and still no luck....
-try to move all songs outside the directory using your pc then test.
if still not working,
-insert your sd card to your phone and reformat it not on pc,then remove it and start again uploading mp3 songs then test.
Dec 27, 2009 | LG Vu CU920 Cellular Phone
Samsung Tocco Lite - Unable to create default folder
Instead of using 'PC studio' option while connecting, use 'media player' option for transferring the files. Check this option. If this does not work, try creating the default directory yourself manually using the phone and then try transferring the files.
Sep 19, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Can't get itunes to work
The error message “The folder iTunes cannot be found or created”. It was referring to the My Music directory that is usually located in the My Documents folder on the partition containing the operating system. The iTunes software creates an iTunes folder in the My Music directory on first start and if that directory is not accessible it will throw the error message and fail to load.
Since this error is related to the My Music folder it is important to check the directory path of that folder in the Windows Registry. This is best done by using the shortcut [Windows R], typing [regedit] and hitting the [enter] key.
The fastest way of location the two locations that contain path information for the My Music folder is to use the search by pressing [F3] and entering [My Music] in the search box. A click on [Find Next] will start the search and reveal the two locations.
The test computer system did not have path information listed at all. This can be changed by double-clicking the My Music key in the Registry and changing the path to an valid path manually.
The two Registry locations that list the My Music path are the following two:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
Make sure both point to a valid path on the system. Once the path has been changed iTunes will create the iTunes folder in that location and start up without this error message.
Please back up your registry before doing this. messing in the registry can make your computer stop functioning.
Make sure you follow the correct registry entry.
Apr 26, 2009 | Apple iTunes
2gb SanDisk Micro SD Card only holding 500mb.
I believe the Drive has gone Bad. It does happen where the system thinks th e whole drive is there, but the internal hardware just cannot access it.
Aug 07, 2017 | SanDisk 2GB microSD Memory Card
EnV2 does not recognize MP3 files on micro SD card
This was tricky, but I was able to get MP3 files recognized on my daugter's phone.
First, the MicroSD card needs to be formatted by the phone. The phone requres a special directory structure to be created. You may be able to do this manually, but I did it by letting the phone initialize the card. To do this, insert the MicroSD card. Make sure you push it all the way in.
Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 3 Card Memory. The phone should recognize the card and initialize it by creating the special directories for My Music, My Videos, My Sounds, etc.
Then put the card into your PC and copy your MP3 files to the My Music directory on the card. I could not get the phone to recognize sub folders, so make sure you copy everything directly to the My Music directory and not the one under it.
Now the card is ready, you have to tell the phone to use your card memory and not its internal memory for these items. Go to Menu 9 Settings and Tools. Then menu 9 Memory. Then menu 1 Save Options. Pick Pictures, Video, and Sounds and set the phone to use Card memory for each.
Now you can import the music into the music player on the phone. Go to menu 5 Media Center. Menu 1 Music & tones. Menu 4 My Music. The music player should then Import yhour music into the player and it should now be playable.
(I think these accurately reflect what I did)
You can also go to 9 Settings, 9 Memory, 3 Card Memory, 4 My Music to view your music.
Jan 01, 2009 | Cell Phones
Sansa error 0x80070052
code error x080070052 while sending document to flash usb
Feb 11, 2008 | SanDisk Sansa c200 MP3 Player
Solution: Put Your Files Where They belong without WMP
Will this allow me to arrange my songs alphabetically ?
Dec 09, 2007 | Coby MP-C7085 MP3 Player
SanDisk Sansa c200 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
