Question about Dryers
Maytag mdg8400aww will not advance during intellisense dry and the display doesn't represent laundry conditions {wet/damp/dry}.
  • DBKiss Mar 27, 2009
    I have the same issue. I have replaced the timer and cleaned the sensor with alcohol. I am not really sure where to go next. The unit does heat and the drum spins, the interior light and door switch work. I really think it is either a bad sensor or a bad electronic dry control board. The problem started because the timer would not advance and it still won't after a new timer. Any thought would be greatly appreciated. I do have a volt ohms tester but I am not very good with it. Thanks in advance.
    President:
  • 1,314 Answers
Try cleaning the sensor bar in the drier drum cavity with alchol and let me know what happens we will go from there some drier sheets can coat the bar and it wont sense should be two silver strips on the front or back inside the drier
Posted on Mar 11, 2008
What does moisture monitor do
It measures the dampness of the clothing by delivering a very low powered electrical charge through the drum. The wet laundry conducts the charge telling the sensor that it is still damp. As the clothing dries the charge is conducted less and less until finally the sensor indicates no moisture.
Sep 27, 2014 | Maytag Dryers
I have a Maytag Epic Z washing machine that stopped working after a severe cold snap. We had the laundry room closed off because it's drafty, and it may have gotten below freezing in there. Ever since,...
the main board might be damaged due to the damp and cold. the boards don't like wet and damp places as it can damage the copper on the boards causing them to go green and be eaten away, you may be able to repair the board using bridges and repairing the damage.
Jun 05, 2017 | Maytag EPIC MFW9700S Front Load Washer
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
Whirlpool duet dryer - when using the settings that automatically sense if the clothing is dry the dryer is saying the clothes are dry but the clothing is still damp
Easy fix: Look inside the drum below where the filter goes in. You will see two metal strips. They sense the wetness. Now get this: the dryer sheets rub against them and a thin wax buildup on them prevents the controls from properly determining wetness. The control has no clue the clothes are still damp and thinks everything is kosher; so it advances to the end. Solution. Clean the stuff off of the sensors so that they can sense the true wetness once again.
May 22, 2010 | Whirlpool GEW9250 Electric Dryer
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool AWZ410 Washer/Dryer Washes But Will Not Dry!
I have the same problem. The half load / drying button is pushed in; the drying time set; I've reduced the load to almost nothing, but it won't dry. I've tried numerous cycles. The clothes spin, but are still damp at the end.
How would I go about checking my lid switch or fixing my clutch, if that's the problem?
Sep 04, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Ignition problems during wet weather
Replace the distributor cap, rotor and ignition wires with Genuine Nissan Parts and you should be ok.
Sep 07, 2008 | 2000 Nissan Frontier
Dryers Logo
151 people viewed this question
Top Dryers Experts
